Old 21st July 2009, 12:57   #1
invincible7's Avatar
Thanked: 154 Times
Default Swift ZXI tyre help - Sidewall cut
My Swift's ZXI tyre got a cut on the side wall.
Now is it advised to use the tubeless kit for repairing the tyres, the cut is on the side wall and is about 1/2 inches.
Or should i go ahead and replace the tyre with a fresh one, how much should it cost.
The size is 185,70,14 if i am not wrong.
invincible7 is offline   Reply With Quote
Old 21st July 2009, 13:00   #2
bblost's Avatar
Thanked: 6,975 Times
Get ready to buy a new tire.
I don't think you can repair a 1/2 inch cut.
Old 21st July 2009, 13:55   #3
watashi75's Avatar
You can use the spare tyre. I don't think you can use the tubeless repair kit for sidewall cuts, and they are risky even if you could.
I too had a small sidewall cut recently and I replaced it with the spare.
watashi75 is offline   Reply With Quote
Old 21st July 2009, 14:29   #4
Nikhilb2008's Avatar
Thanked: 6,599 Times
Repairing and using a tyre that has a cut on the sidewall is not recommended at all. Please buy a new tyre.
Most tyre shops will sell you a used JK for about 2000bucks. These might have been used for about 100 kms or so before the original owner upgraded to better tyres.
Old 21st July 2009, 14:33   #5
bblost's Avatar
+1 to that.
However do check the manufacturing date information on the tire.
Its embossed on the side wall and the format is typically WEEK-YEAR
For example 02-09 will mean manufactured in the second week of 2009.
The younger the tire the better it is.
Old 21st July 2009, 14:43   #6
Thanked: 154 Times
Hmm well i will need to check whether any such tyre is available, if not will need to get a new one.
Currently i have replaced it with the spare tyre, but still will need to get an extra tyre for the need in case of emergencies.
Ok the tyre balancing was done few days back, will that need to be checked again withthe new tyre or not.
Old 21st July 2009, 14:58   #7
gopinathann's Avatar
Thanked: 20 Times
I too got a side wall burst and Maruti dealer told it could not be repaired. So I went to a local workshop to fix the tyre and they have put a patch on the side wall. I cannot run on it, however will be using it only for emergency purpose when any one of the tyre got punctured.
gopinathann is offline   Reply With Quote
Sidewall puncture in tubeless tyre naveendhyani Tyre & Alloy wheel Section 112 15th July 2018 17:07
Sidewall cut in tubeless tyre - repair possible? archat68 Tyre & Alloy wheel Section 96 27th May 2018 15:28
Bulge in sidewall of one Runflat tyre. Please Help !! FlyingSpur Tyre & Alloy wheel Section 29 27th July 2010 20:44
Sidewall cut on Good Year Eagle NCT 5 sportive_guy30 Tyre & Alloy wheel Section 29 9th October 2008 19:11
Tyre pressure indication on the sidewall!! Shan2nu Tyre & Alloy wheel Section 11 7th February 2005 15:37
