Old 19th January 2016, 09:58   #61
Thanked: 114 Times
Default Re: Sidewall cut in tubeless tyre - repair possible?
Took my Manza to rural Palwal for birding and got this in return - two punctures, of which one is on the cusp of sidewall. Tyres are Kenda - about 2 months and 7000 done.
If I have to change the tyre, I'd do it right now, because the other tyre is still pretty much new and both will wear out evenly. Or can I live with it?
ntomer is offline   Reply With Quote
Old 2nd March 2016, 18:53   #62
tud
tud's Avatar
Thanked: 21 Times
Originally Posted by WasavaTyres View Post
in your second image, upper left corner you'll notice the rubber has started to show cracks , signs of aging.
Yes, in fact I noticed all my tyres are having minor cracks like the drying up you had pointed. Time for a change. They lasted 42k kms. My tyre size is 195 60 r15 and I'd like to keep the same specs. Confused between Continental and Michelin. Any pointers to help me choose?
tud is offline   Reply With Quote
Old 2nd March 2016, 19:28   #63
WasavaTyres's Avatar
Thanked: 173 Times
Between the two I think continental offers better value for money and is almost at par with michelin going by reviews elsewhere on the forum. Plus I believe Conti is offering a 50% wear unconditional warranty - but do check in your city or with your dealer.
WasavaTyres is offline   (1) Thanks Reply With Quote
Old 27th March 2016, 14:48   #64
Thanked: 9 Times
Need some advice. Attached are photos of a few punctures of two my Duster's tubeless tyres, some seem to be fraudulently incited as I begin to believe now. These are the OEM supplied MRF wanderers (215). After reading so many posts I am a bit concerned whether I can continue using them. They have run 22k so far at the 3rd year. Please advise.
sunny13 is offline   Reply With Quote
Old 27th March 2016, 16:19   #65
hvishwanathan's Avatar
Thanked: 93 Times
Seeing the pictures I see that there are multiple punctures in the side wall.If it is only in one tyre, I would recommend these to be kept as spare and use the spare tyre if you dont want to immediately spend on a new tyre. However if the same is the case with other tyres as well i would recommend to change the same immediately. Even if you think of retaining this as a spare, i would suggest you use a tube inside this damaged tyre.
Last edited by hvishwanathan : 27th March 2016 at 16:21. Reason: adding some more options
hvishwanathan is offline   (1) Thanks Reply With Quote
Old 27th March 2016, 18:07   #66
Thanked: 9 Times
Thanks. There first and 3rd pic is of one tyre which is a recent one which happened(or induced) just yesterday. The 2nd pic is on another tyre which has at least 8 punctures and 2 on the threads on the side facing the road.
Old 27th May 2016, 19:39   #67
Thanked: 29 Times
I am an owner of a Nov 2014 Maruti Suzuki Alto which came factory fitted with Bridgestone tyres. The car has run approx 25000kms and earlier today the tyre was discovered to be punctured due to a side wall cut.
Do tyre manufacturers offer warranties for tyres which come from the factory and would this be covered? What are my options with this tyre now?
Knowall is offline   Reply With Quote
Old 27th May 2016, 20:25   #68
Thanked: 173 Times
The warranty is only against manufacturing defects. This will not be covered under warranty.
Old 27th July 2016, 21:37   #69
My car has factory fit goodyear gt3 175/65r15 tyres. Today in a regular waterlogged potholed road i experienced almost immediate deflation within 15-20 seconds. I believe its a sidewall shear as i see a cut. It looks similar to the big cut here.
Is it repairable? Covered in warranty? Its less than 5 years and no treadwear indicators are visible yet as the warranty states.
parulkgupta is offline   Reply With Quote
Old 27th July 2016, 21:44   #70
Anupam's Avatar
Thanked: 33 Times
Is it repairable? .
Yes very much, there are side wall plugs available for this very purpose by patch makers like Omni
I had a similar sidewall cut in my Innova in 2011 while crossing zojilla pass while on the way back from Leh, it was repaired by a local tyre guy and the tyre ran well till it's end of life
Hence go ahead with confidence and get it done, should not cost you more than few hundred
Anupam is offline   Reply With Quote
Old 29th July 2016, 23:23   #71
Thanked: 66 Times
@tud are your tyres older than 4 years ? They seem to be 'drying' up.
Even I am concerned about my tires drying rotting. However, my tires are less than 4 years old going by the date of manufacture. The two most affected tires have 0713 manufacturing stamp.
I amwondering if I should replace these ASAP, or I can continue driving around for a while. I have attached a picture of the seemingly most affected tire, on the outer sidewall.
Any help would be deeply appreciated.
P.S. I have used them for about 35,000 kilometers so far, and the wear pattern seems to indicate I may be able to use them for another 10,000 kilometers, by normally rotating them after 5,000 kilometers.
halfbytecode is offline   Reply With Quote
Old 31st July 2016, 11:51   #72
Thanked: 173 Times
Originally Posted by halfbytecode View Post
I am wondering if I should replace these ASAP, or I can continue driving around for a while.
They don't look worryingly aged. I reckon you can totter around with them for a while. Can't say how many kms since haven't seen the tread depth, but going by your judgment I guess it'll be another 8,000 kms before you get her a new pair of shoes.
Old 25th August 2016, 13:27   #73
Thanked: 38 Times
Hi All,
Recently i noticed a cut on my Baleno tyre which is just 6K on ODO. Not sure how it happened, there is no leak in air pressure. Below are the pictures :
I asked for the warranty claim, but as it is not mfg defect so advisor is not accepting the warranty claim, he told me that this is just a cut on upper rubber layer, which fortunately has not deep and tyre strength is intact. He asked me to go ahead with exisiting tyre without any worry.
For more clarification and to my satisfaction, I have even showed to two more tyre dealers for opinion. They both told me that tyre is good condition and nothing to worry as this is just a cut on upper rubber layer. No need to change the tyre.
Guys please suggest shall i go ahead with existing or buy a new one. As i cannot replace with spare beacuse in Baleno Spare tyre is steel and of small size.
THanks in advance
rajpandey10 is offline   Reply With Quote
Old 25th August 2016, 14:30   #74
Thanked: 13 Times
Originally Posted by rajpandey10 View Post
Hi All,
THanks in advance
Hello Rajpandey10,
Till the time you decide on the fate of tyre, please replace the wheel immediately with the spare wheel. Please DO NOT drive with this tyre.
I recommend that you keep this cut tyre as a spare wheel, as use it as less as possible.
JitendraK78 is offline   Reply With Quote
Old 25th August 2016, 17:14   #75
Thanked: 38 Times
Originally Posted by JitendraK78 View Post
Hello Rajpandey10,
Cant use this tyre as spare wheel as in baleno the spare wheel comes with different configuration.
Other option is to move this tyre to rear wheel.
Sidewall puncture in tubeless tyre naveendhyani Tyre & Alloy wheel Section 99 26th April 2016 17:04
Tubeless Tyre Sidewall Bulge on minor impact: Replacement Suggestions Digital Vampire Tyre & Alloy wheel Section 5 4th November 2010 14:34
GNT - Blore - Tubeless Tyre Sidewall Repair rajatmakar Tyre & Alloy wheel Section 8 15th October 2009 17:51
Swift ZXI tyre help - Sidewall cut invincible7 Tyre & Alloy wheel Section 6 21st July 2009 14:58
Sidewall cut on Good Year Eagle NCT 5 sportive_guy30 Tyre & Alloy wheel Section 29 9th October 2008 19:11
