Old 15th March 2010, 00:38   #46
nitrous's Avatar
Thanked: 285 Times
What is the cause of this "slight jump" in the tyre, Nikhil?
Old 15th March 2010, 09:37   #47
Nikhilb2008's Avatar
Thanked: 6,638 Times
Mainly uneven wear. Could also be a bent rim. Could be over inflation.
Sometimes, this uneven wear cant be seen with the naked eye.
We had this experience on one of our own cars for the first time after the trackday. Two tyres have a slight jump. You cant actually see any uneven wear on the tread, but mount the tyre on a balancer and you can see a slight, very slight jump.
Now, this is very slight and may not ALWAYS lead to wobbling. But if they are in the front, then there are more chances of having vibrations, etc in your steering wheel.
Old 16th March 2010, 00:04   #48
Thanked: 61 Times
Thanks Nikhil. The car has done only 5500 kms sofar. There is no bent in both the front rims. Tyre pressure is always at recommnded 36 psi in front and 33 psi in rear. However what is the solution? One of the front tyre is brand new, put on during the five tyre rotation. Is it ok if I interchnge front tyres with rear tyres?
gaddiwale is offline   Reply With Quote
Old 16th March 2010, 00:33   #49
There. That is your problem.
Never put two different worn tyres at the front.
Old 16th March 2010, 01:17   #50
Thanked: 61 Times
Thanks once again Nikhil. Tomorrow I'll interchange the front and rear tyres in a cross pattern and upload the feedback.
Old 25th April 2010, 13:00   #51
sumeethaldankar's Avatar
Thanked: 1,158 Times
Default Weights fallen off the wheel.
Hi guys,
my car's wheel's balancing weights fell off , the second one in two years,again today this morning.My question,will this affect the tyre in the long run as i am not due for a balancing for the next 8 months or so(i only get them done once a year as my driving is just 2-3k a year).I had them done last in january when i had o/h the front suspension and i have lost the weight again.
It just fell off at parking speeds thankfully in my compound.i shudder to think what would have happened had it been caught in the wheels whilst driving.I have Neo alloys on my car (800) and i have noticed the weights have fallen only afer switching to the alloys.Never had such a issue with the steel rims.
sumeethaldankar is offline   Reply With Quote
Old 25th April 2010, 15:37   #52
Nothing would have happened if they had hit your wheels. Think about it. Are you always worried about hitting a small stone or pebble? No right? Same case here.
Weights shouldnt fall off so soon. Either old, used weights were used or the weights werent clamped properly.
Old 25th April 2010, 16:16   #53
Which is the best place to get the wheel alignment in Bengaluru?
Can members give the address and Phone no?
Ramanna
Ramanna is offline   Reply With Quote
Old 25th April 2010, 16:24   #54
There is a thread running on TBHP. Please see that.
http://www.team-bhp.com/forum/tyre-alloy-wheel-section/66999-wheel-alignment-bangalore.html (Wheel Alignment in Bangalore)
See which place is close to your house and convenient for you to visit.
Old 25th April 2010, 20:25   #55
Very true,actually the 1st time the weight came off it was sort just hanging on the wheel partly.The weight actually is stuck to the wheel using some sort of adhesive instead of being clamped on probably why they are coming off.Wonder if anyone else have the same problem.
Old 25th April 2010, 22:09   #56
Well, the adhesive is very strong.
My suspicion is still that the weights are old used weights. Obviously, the adhesive will not be strong once you remove it and reuse the weight.
Or maybe the guy fitting the weights isnt putting enough pressure on the weights to make sure they stick properly.
Old 1st November 2010, 11:32   #57
Thanked: 48 Times
IS it true that in cars with independent suspension both front and rear wheel alignment is needed? When i was getting alignment done for my baleno the guy doing it told there is no 'nut' to adjust in the rear and he said he's checked the camber. I couldn't make much sense of it. My tyres have irregular wear and I am afraid it may be due to this reason. Can someone tell if baleno needs wheel alignment for both front and rear or not?
rock75 is offline   Reply With Quote
Old 1st November 2010, 23:05   #58
Thanked: 16 Times
Would appreciate advise on City ZX alignment also.
What all adjustments are possible? front/rear, toe-in/camber ?
guptavis is online now   Reply With Quote
Old 1st November 2010, 23:07   #59
@Rock75 --- It has nothing to do with independent suspension. It depends on whether there is an adjustable setting available for the rear suspension or not. Most cars dont come with adjustable rear suspension.
@Guptavis --- For the City ZX, only front Toe is possible.
Old 3rd November 2010, 00:01   #60
Thanked: 48 Times
Well here is what is mentioned on the owner's manual in Baleno
Steering
Toe in
Front 0+2mm
Rear 2+2mm
Can someone tell me what it is.
Wheel alignment & balancing in the NCR suman Tyre & Alloy wheel Section 95 26th November 2015 14:48
Wheel alignment or wheel balancing?? leodelg Tyre & Alloy wheel Section 27 22nd June 2011 00:44
Breakdown Assistance for 1 year, Wheel Alignment & Wheel Balancing just for Rs 199 Mitsun Soni The Indian Car Scene 11 8th March 2011 11:02
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
