Old 24th September 2009, 10:19   #1
vishnuvijay's Avatar
Default 195/55 r14 size tyre available?
195/55 r14
this size has been mentioned by kpzen as a probable upsize for hyundai i10. but i can't see this size listed with most manufacturers. is this size available? if so by which manufacturer?
vishnuvijay is offline   Reply With Quote
Old 24th September 2009, 10:29   #2
Nikhilb2008's Avatar
Thanked: 6,589 Times
Nope. Nothing available officially. If it is possible, you will have to get those Nankangs,Neuton or whatever.... Stick ti 185/60 R14. Even that is overkill, but 195/55 R14 is uber overkill.
Nikhilb2008 is online now   Reply With Quote
Old 24th September 2009, 10:33   #3
live2drive's Avatar
Thanked: 25 Times
OT: Nikhil, What are the options available in 195/60 R14?
live2drive is offline   Reply With Quote
Old 24th September 2009, 10:53   #4
thank you nikhil. i wanted to go for the maximum width possible. i could go for 195/50 r15, but then the ride quality would suffer more and i'll have to be a little more careful as to not bent the wheel. 195/55 r14 is allright but it's not available.
Old 24th September 2009, 11:09   #5
You get A drives, ES 100s, GIIIs, ER 60s, XM1+, BFG Gforce Sport and Conti CPC 1 and CPC2 in 195/60 R14.
My suggestion is this: For comfort, ge the XM1+ in 185/65 R14. For grip and handling in wet and dry, get the CPC2 in 195/60 R14.
Old 24th September 2009, 11:13   #6
live2drive's Avatar
Thanked: 25 Times
Can you please shed some light on the respective costs of Conti CPC2, A Drives, BFG GSport and ES 100s? Size being 195/60/ R14.
Old 24th September 2009, 11:35   #7
Conti: Around 4k
A Drives: Around 3.5k
ES 100s: 3.6k
BFG: Around 3.8k
Old 24th September 2009, 11:38   #8
live2drive's Avatar
Thanked: 25 Times
Thanks for replying.
Old 24th September 2009, 14:04   #9
abhibh's Avatar
Thanked: 34 Times
Nikhil by any chance you have the size chart for CPC2 ?
Old 24th September 2009, 14:15   #10
195/60 R14
195/50 R15
195/60r15
195/65 R15
205/50 R15
205/55r16
205/60r15
205/65r15
225/60r15
205/55r16
205/60r16
215/60r16
225/50r16
225/55r16
225/60r16
235/60r16
Old 9th October 2009, 19:10   #11
k_shanz's Avatar
Thanked: 64 Times
Originally Posted by vishnuvijay View Post
195/55 r14
185/50 R14 size is available is yoko s.drive. Check with that!
k_shanz is offline   Reply With Quote
Tyre UP-One Size 0f 155/70 R13 to 175/55 R14 or 185/50 R14 availability in chennai? rajeevrs Tyre & Alloy wheel Section 20 11th June 2013 23:09
Indigo XL - Tyre change - 195/60 R14 Bouncer Tyre & Alloy wheel Section 9 24th October 2009 18:48
185/55 R14 or 195/45 R14/R15 For a Zen? riffst3r Tyre & Alloy wheel Section 48 22nd October 2009 10:32
14'' alloy + 195-60-R14 on Ford IKON 1.6zxi shazikon Tyre & Alloy wheel Section 32 14th February 2007 19:21
155/70/R14 or 165/70/R14 Available? nitrous Tyre & Alloy wheel Section 11 16th March 2006 18:28
