Closed Thread
Old 16th May 2009, 21:56   #46
Nikhilb2008's Avatar
Thanked: 6,661 Times
But no one has touched the wheels of this car out side madhus for past 15k or so kms, for which i can never produce a proof any type.
You dont need any proof. You being here on this forum is enough proof of that
I do wish you knew who had done the job so that I could talk to that mechanic. Shoddy work is simply not acceptable.
Please do check your PM.
Nikhilb2008 is offline
Old 22nd May 2009, 18:12   #47
Thanked: 7 Times
Originally Posted by gkrishn View Post
After some haggling around, they mounted the front wheel and managed to put the nut back in its place, with some help from grease. Asked them to remove the nut and put it back couple of times. It seems to be ok, as of now.
Frustrati
I had read at plenty of web advices & car manuals that any type of grease or lubricant should never be put for the wheel nuts at any cost as they tend to get loosend if done so.
drkumarmp is offline
Old 8th October 2009, 14:28   #48
nemo's Avatar
Thanked: 9 Times
Default Wheel Alignment in Bangalore
Hi Guys,
I urgently need an information about a Computerized wheel alignment place around Koramangala/Sarjapur outer ring road area. The car is a Ford Fiesta and i have fitted alloys.
thanks for any inputs
nemo is offline
Old 8th October 2009, 14:32   #49
Rudra Sen's Avatar
Thanked: 4,295 Times
Mods note: Thread merged.
Rudra Sen is offline
Old 8th October 2009, 15:51   #50
Default Info needed
Hello people,
I am not sure if this sounds kinda silly, but, is a WB&A possible on a motorcycle? If so, would you know any good place in Bangalore (Bellandur / Sarjapur Rd / Marathahalli areas)?
I'll give you a brief history on this, so, it'll be clear as to why I'm asking for this......
I own a 2005 Bajaj Avenger. A couple of months back, I'd got some modifications done on my bike, and this included getting the tyres changed (110 in the front and a 170 in the rear). You may want to check out my post on this @ http://www.team-bhp.com/forum/motorb...ml#post1438504 (Modified Indian bikes - Post your pics here and ONLY here).
Now, everything has been going smooth on the bike (post the modifications), except for the wheel allignment. The rear wheel is not completely straight, because of which, my handlebar is very slightly turned to the right in order to keep the bike straight. This isn't much of an issue in city traffic, but, I know it will be on the highway.
Hence, I want to get it checked, and rectified asap. Do you think, replacing the spoked rims with mags could solve the issue in any way?
Thanks.
debaditya.nath is offline
Old 8th October 2009, 16:04   #51
wheel balancing is possible. It's called Wheel truing in most places.
Alignment is not possible. The only alignment possible is to make sure the front and rear wheels are facing dead straight. It is not done on any machine or anything. A trained and experienced mechanic can set is right.
Your problem sounds more like a bent handlebar rather than a tyre problem.
Old 8th October 2009, 16:28   #52
Well, I did think of that initially. I had taken it to a couple of mechanics, but they couldn't get that fixed.
Lemme try wheel tuning this time. Any idea there's some place in Bangalore that does a wheel tuning?
Old 8th October 2009, 16:42   #53
s.prashanth's Avatar
Thanked: 60 Times
MADHUS IS THE BEST, they are sure of their job, they do not take the car for trial like otherplaces to check what they have done. They are very good.
s.prashanth is offline
Old 9th October 2009, 10:25   #54
Was that for me, Prashanth?
Could you let me know where I could get this done?
Old 9th October 2009, 11:30   #55
Any decent mechanuic should be able to do it. Castrol Bike Zone for one.
Old 9th October 2009, 14:26   #56
Thanked: 40 Times
Default Vijay Wheel Alignment @ VV Puram Experience
My car's rim had gone for a toss after a long drive to my hometown.
So a week back i had gone to Vijay Wheel Alignment @ VV Puram.
First a person came noted down my car number and asked me to wait
A few minutes later a guy came (he told 'Giri', big fat guy) and took the car for the TD. Then he suggested me to all 4 Wheel Balancing, Wheel Alignment and 4 Rim Bends. Then he said he will just tell 2 Wheel Balancing and 2 Rim Bends to their boss and bill the same but pay some amount to them. I said ok fine no problems go ahead.
They started working and finished balancing, alignment and removed all four rim bends. Then the mechanic asked me to drive the vehicle for one week and if i found any problems you can come back again. Left the place.
Soon i found the car was pulling to left and had sheer vibrations once i reach 60kmph. Again yesterday went to Vijay and told them the problems i am facing. Then owner took my car number, verified the old bill (Free Service upto 3 weeks) and sent the same old fat guy to inspect the vehicle. Then they again removed all the wheels did balaning and did wheel alignment again.
Then at last i was asked to pay for 2 Balancing :-(. I was like stupid to pay and come out of there
People (i say mechanics) at Vijay Wheel Alignment, VV Puram are just money stealers..
CRV2010 is offline
Old 19th October 2009, 02:59   #57
swiftnfurious's Avatar
Thanked: 6,583 Times
I stay @ Madiwala. Could you tell me which is the best one near Madiwala? And direction if possible please! I am not very familiar with Bangalore roads. So please be as specific as you could be.
swiftnfurious is offline
Old 24th November 2009, 23:31   #58
rk_sans's Avatar
Thanked: 784 Times
Default WB, WA and Wheel Rotation @Madhu's
It was time to get the wheel rotation, wheel balancing and wheel alignment as the speedo had clocked 7K.
Visited Madhu's today morning and all was done in less than 20 mins.
Thanks to Nikhil +1.
rk_sans is offline
Old 10th March 2010, 08:27   #59
mathewpn's Avatar
Yesterday I've got WA done at Madhus. It was a nice experience. It hardly took 20 mins. Thanks Nikhil, and +1 to you
Mathew.
mathewpn is offline
Old 11th March 2010, 18:30   #60
Thanked: 73 Times
One more + to Nikhil. Totally recommended. It was a rather smooth experience getting my tyres changed, balanced and aligned at the Langford road outlet. An affable and professional person I must say.
Cheers!
Prajwal
prajwalkashyap is offline
Closed Thread
Wheel alignment or wheel balancing?? leodelg Tyre & Alloy wheel Section 27 22nd June 2011 00:44
Breakdown Assistance for 1 year, Wheel Alignment & Wheel Balancing just for Rs 199 Mitsun Soni The Indian Car Scene 11 8th March 2011 11:02
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
