Old 15th November 2009, 23:41   #16
Thanked: 32 Times
Tsixty1,
I have a 2006 Indica turbo run 116000 +. Initially for 72k kms it has run on goodyear NCT5 185/60 R14 + Alloys. I had to change the tires due to it scrapping the suspension under load. As the scrapping was very minimal nothing serious happened. The scrapping is due to the offset of the alloy wheel. I replaced the tires with Apollo Accellere 175/65 R14 & am having no problem now.
Till date no. of punctures i have faced is in single digit.
IMO you should check your rim and change to a newer rim or alloys with better tubeless tyres.
kiren is offline   Reply With Quote
Old 15th November 2009, 23:50   #17
Just to add few bucks of mine, might be repeated once since i did not go through the entire replies.
1. The tyres could be getting excessively heated inside because of its defective quality and in turn could be damaging the tube inside.
2. Check for some small pins which might get missed out with the usual way of running the palm inside the tube. When the tyres get inflated it does really stretch the tyres and in turn these small pins become significant. Check with a lens inside the tyre if possible.
3. Another thing you could possibly doo is before you put the tubes inside the tyre give another lining of old tube and put the new tube above that this could significantly reduce your problem.
4. Last thing is replacing your tyre.
Soumya_Ramesh is offline   Reply With Quote
Old 2nd December 2010, 17:33   #18
Thanked: 16 Times
Smile
Today changed to MICHELIN Energy XM1+ (175/65/R14) tubeless. Opted for Ford Fiesta rims. All done at Sai Iyengar And Sons.
Odo reading 38K dot. let's see how the ride goes for next few years
Tsixty1 is offline   Reply With Quote
Old 30th August 2011, 11:41   #19
ku69rd's Avatar
Thanked: 1,229 Times
Default Re: Several flat tyre with Indica V2 Turbo please help
Santanu,
How has your experiences been with the upgrade to XM1+ tubeless? Do let us know your thoughts, you got a good deal from Sai Iyengar?
ku69rd is offline   Reply With Quote
Indica V2 Turbo - Turbo Failure abhik Technical Stuff 15 30th November 2017 17:24
Save me from Skoda. Several Laura issues! devil_666 The Indian Car Scene 51 8th February 2008 14:09
Indica NA DLS vs Turbo DLS vs Turbo DLG greenhorn Hatchbacks 10 5th May 2007 17:20
Indica Turbo vs Non Turbo lbhavani Technical Stuff 0 5th September 2006 22:22
New Indica Turbo - is the turbo on? gakudva Technical Stuff 5 15th July 2006 23:00
