Tyre & Alloy wheel Section Everything to do with footwear for your car
LinkBack Thread Tools
Old 12th November 2009, 15:27   #1 (permalink)
Tsixty1's Avatar
Default Several flat tyre with Indica V2 Turbo please help
I have a Indica 2006 V2 DLX which has 165/65/R14 Goodyear Tyre. But just after six months and till today I have several flat Tyre. I really lost count of the same. recently I changed (September) all the tubes with Iyengar Tyres, Bangalore(Indiranagar). They used metro tubes as they did not had Goodyear.
And already I had two flat Tyres in 3 months. I am not sure what to do?
According to TATA (Prerana) and Iyengar Techies my tyres are in good shape after 26k and there is no need to change them for another 15K KM.
Only consolation I have is I never had that bad experience during my highway trips. Last weekend I drop to Tirupati.
I am really frustrated with the situation. I am thinking to change the car in another two years. Only option is spending on new tubeless tyre and alloys but do you suggest that ?
As I might not get much for my current tyre.
Please help.
Tsixty1 is offline   Reply With Quote
Old 12th November 2009, 17:11   #2 (permalink)
debugged's Avatar
Is this happening for the same wheel over and over again? May not be the right comparison, but I had a TVS champ moped during school which used to have several flat because of some misaligned spoke or something. If it is the same wheel everytime, then you can check with some tyre shop and find out some cheap deal to buy stock rims that get exchanged with them.
If its not the same wheel, and since you say it never happens on highways, take a friend along and scour your daily drive route. Some old scrap shop or some road side garage might be the culprit.
__________________
Swift VDI (2009)
The journey is the reward
debugged is offline   Reply With Quote
Old 12th November 2009, 19:21   #3 (permalink)
Tsixty1's Avatar
Well I can not say the daily road as I moved from Navi-Mumbai to Bangalore almost 18 months back. And there is not much to complain about the daily commute.
This is not specific to one wheel.
I see suggested upgrade would be 175/60/14 but any other suggestion experts. I lost faith in tyre shop for sure.
Old 12th November 2009, 19:49   #4 (permalink)
dinu2506's Avatar
What is the culprit? Is it some foreign object always or is it the tube tearing?
What is the tyre pressure that you maintain? Try and inflate to 30 psi and checkout
__________________
What we are today is a function of the future we are living into, not our past.
dinu2506 is offline   Reply With Quote
Old 12th November 2009, 20:28   #5 (permalink)
ElantraGT's Avatar
Tsixty - as Dinu has suggested we need to know what caused the puncture. Is it caused by foreign object (like nails, small iron particles) or is it because of seems giving away?
I would recommend you to take the car to a good tyre dealer and have them check your tyre. Check for uneven thread wear and that might cause small particles in the road to puncture the tyre at that location. The A.S.S cannot be trusted in this as they are not the experts. You need the specialist to check the tyres. I wont recommend doing a wheel alignment /balancing with them. I always take my car to the tyre specialist.
__________________
Hari
"Talent is what you possess; genius is what possesses you"
ElantraGT is offline   Reply With Quote
Old 12th November 2009, 20:45   #6 (permalink)
Have you checked the tyres for any small nails/sharp objects, that could be repeatedly puncturing the tyre?
ronin is offline   Reply With Quote
Old 12th November 2009, 23:20   #7 (permalink)
Tsixty1's Avatar
As I mentioned took the car to Iyengar Tyres and they did a complete wheel rotation, balance and alignments in September. And I hope they did not a complete check of inside as they said :(
Any other place near Indiranagar, Bangalore you suggest.
Old 13th November 2009, 09:13   #8 (permalink)
Nikhilb2008's Avatar
1). As someone said, is there a nail or any foreign object inside the tyre which hasnt been noticed?
2). Have you checked the valve pins?
3). Can you 100% rule out mischief by roadside urchins and other boys?
4). When you got the punctures repaired, how big were those punctures and where were they? If they were too big, then if the tyre shop guys put a patch, it may not have held. If the puncture was on oneof the joints of the tube, the patch wouldnt have held again.
5). I've never heard of this Metro tubes. At least you could have gone for Mypol. It is true that getting Goodyear tubes in the market is nearly impossible, but Mypol is good. They are the OEM manufacturers for Ceat and Goodyear.
6). This has nothing to do with wheel balancing, rotation, alignment.
7). Are any of your tyres damaged even slightly? Because if one tyre is cut slightly from the inside, it could be rubbing against the tube and causing the tube to open up again and again.
8). How is your rim? If you rim is badly rusted, the same thing can happen. The rust can have an abrasive action on the tubes damaging them.
Old 13th November 2009, 13:06   #9 (permalink)
WasavaTyres's Avatar
Wink
I think he's bought Metro Continental tubes.Fairly good quality tubes,so no cause for worry there.
__________________
Man made booze........
God made grass.........
Who do u trust ??
WasavaTyres is online now   Reply With Quote
Old 13th November 2009, 13:12   #10 (permalink)
Aaah.... Those are decent. I thought he was palmed off one of those usual no-name tubes.
Old 14th November 2009, 12:24   #11 (permalink)
predatorwheelz's Avatar
@Tsixty1 - For complete peace of mind, change all tyres.Either the GPS2 165/65 R13s have a defective design, or for some reason they do not gel well with Indica rims. My 2005 Indica DLS came with the same tyres, and I've lost count of the number of punctures it had. I've changed tubes numerous times, but the punctures just kept on repeating.
Ultimately in 2008 I changed to Yokohama A-drive tubeless (same size). The puncture problem has completely gone away now, and the car's ride has considerably improved.
(As a counterpoint, GPS2s do not seem to have such problems on other cars. I know someone who runs 165/65 R13 GPS2s on his 10 year old zen, and the tyres are running problem free.)
__________________
Working hard in my office is a bit like peeing inside dark trousers. You get a nice warm feeling, but no one else seems to notice.
predatorwheelz is offline   Reply With Quote
Old 14th November 2009, 15:49   #12 (permalink)
nims's Avatar
@Tsixty1: I had the same problem with my indica too. I consulted with other indica owners and found out that the stock rims are totally useless and of very poor strength. I cured my problem by fitting alloy wheels shod with 185/60 r13 rubber. didnt have a puncture now more than 25k's. hope it helps you.
__________________
08' optra magnum
09'chevy Spark
06'Mitsu galant v6 3.0(totaled)
04'indica v2 k&N
91'ford laser 1.8bpt
95'Tata estate
nims is offline   Reply With Quote
Old 14th November 2009, 19:01   #13 (permalink)
One issue I heard from indica and Indigo owners is both cars used to come with poor quality RIMS. My feeling is If you want to change tyre you might need alloys too. Buying tube tyre again won't make sense.
Ravi.
__________________
My time pass Vehicle:Black Safari Exi 2003 Future: Oct. 2010 Silver Toyota Innova, 2012 RED i10 AT
ravibhat is offline   Reply With Quote
Old 15th November 2009, 20:28   #14 (permalink)
DieselFan's Avatar
TSixty1,
IMO there is no need to change your wheels to alloys. You will get lot of steel wheels for a song. better change to a new set of wheels as well as new set of tubeless tyres. This should solve your problem once and for all.
__________________
Swift Diesel VDI - Feb '07 onwards. 50K+ kms and going strong.
Santro LS- Mar '01-Feb '07(59000 KM) Sold.
DieselFan is offline   Reply With Quote
Old 15th November 2009, 20:38   #15 (permalink)
Just make sure that if the rims are bent then you get them back to proper shape.
I do not know as I have not personally seen but sometimes the tyre guys get some part of the rim welded and the problem of puncture goes away. Hope this helps.
__________________
THE FASTEST ONE
supercars is offline   Reply With Quote
Thread Tools
Any cure for tyre flat spots dj_2006 Tyre & Alloy wheel Section 4 31st January 2010 06:07
An inflator that seals flat tyre! rajesh1868 Tyre & Alloy wheel Section 33 24th October 2009 08:59
Tyre upsize for Indica Turbo V2 turbo_freak Tyre & Alloy wheel Section 29 5th December 2008 11:09
Alloy+Tyre Combo for indica Turbo v2 hell_rider Tyre & Alloy wheel Section 14 21st May 2008 09:19
had a flat tyre yesterday, Ran 30+kms DRC Street Experiences 6 8th April 2006 19:10
Powered by vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2000 - 2010, Team-BHP.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652
