| Tyre & Alloy wheel Section Everything to do with footwear for your car! |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Apr 2005 Location: Florida,Tamps /Bangalore
| Hi All, Will be getting the Baleno Lxi delivered today. Wanted to change the tyres right away, but the dealer is quoting 8-10 K for the 14 inch tires exchange. Pls let me know what tyres are good (Looking for Ride comfort ) and also some dealers info in Bangalore would be great. Thanks in advance. Regards, Last edited by mons_truck : 8th August 2005 at 09:30. |
| | #2 (permalink) | |
| Team-BHP Support ![]() | Quote:
__________________ Samurai The notchy gearshift of GV has become buttery smooth after I started driving the Jeep. | |
| | #3 (permalink) | |
| BHPian Join Date: May 2005 Location: Hyderabad
| Quote:
1. If you want to have similar (not same) ride comfort and better grip go for 185/70 R 13..call any tyre wallah..the exchange should cost you aroung 7 K...not more.. 2. Prepared for a slightly harsher ride and better handling / grip. (very acceptable ride comfort here though not the same as stock) 185/65 R 14, 195 / 60 R 14 3. Extremely handling conscious..let the ride comfort go to dogs...195 / 55 R 15 and 205/ 50 R 15 Option 2 and 3 will also require a change of rims...(go for alloy if you need beter look...regular pressed disc..if you are on a budget). I use 185/65 R 14 and the ride comfort is pretty good...(Goodyear Eagle NCT 5). Samurai can confirm ...but I remember him using 195/60 R 14 (Yokohoma Directional tyres) 195/55 R 15 , 205 / 50 R 15 Last edited by Buffetfan : 8th August 2005 at 17:53. | |
| | #4 (permalink) |
| Team-BHP Support ![]() Join Date: Feb 2004 Location: Bombay / New York
| Thread moved, Also, check out this thread (Stock tyres on the Baleno) it should have more than enough data for you. cya R |
| | #6 (permalink) |
| BHPian Join Date: Jul 2005 Location: Delhi
| When upgrading from 165/80/13 to 185/65/13 the speedo error would be 4% which is not acceptable. When you will be traveling at 100 kmph your actual speed would be 96 kmph. On top your Groud Clearance will decrease by 12 mm and there is a great chance that your car will hit speed breakers with lower GC. Ideal upgrade would be 185/70/13 if you want to keep on stock rims. This will not effect your ride comfort at all as the profile is still very high. However this wont do justice to the looks of the car. Baleno looks are getting dated, so Alloys add a new life to the car. I personally would go for 195/60/14 or 185/65/14. The 185/65/14 will give you better ride comfort than 195 but the 195 will look great on the car. Regarding the tyre, if comfort is your only criteria than you should go for Michelin Certis. If your criteria is plain and simple performance than consider Bridgestone Potenza GIII. If your criteria is looks of the tyre, than you can consider Goodyear Eagle GSDII, GSDIII, Yokohomas etc. If your criteria is budget, than you can try any of the Indian brands like Apollo, JK, MRF, etc. |
| | #7 (permalink) | |
| | #8 (permalink) |
| Senior - BHPian | Reviving an old thread, since a few questions came to my mind. What would be the approx cost per tyre for the following ? Michelin Certis 185/65 R14 Michelin Certis 195/60 R14 Goodyear NCT5 195/60 R14 (assume all to be tubeless) When steel wheels are replaced with alloys, how much does the cost of wheel balancing come to (if any ?) Alignment must anyway be done, right ?
__________________ PIGZILNKILJBSCOMB |
| Thread Tools | |
Similar Threads | ||||
| Query : Tubeless tires / Normal Tires | nicejits | Tyre & Alloy wheel Section | 8 | 15th January 2008 01:56 |
| help me out in selecting the car | AnandPatil | Sedans | 8 | 7th July 2006 21:51 |
| Need Help Selecting a CD Changer | Technocrat | Ask the Gurus | 38 | 22nd August 2005 19:36 |
| Help for selecting Bike | pingme | Motorbikes | 28 | 21st June 2005 12:23 |
| Need Help Selecting a Car | Technocrat | Sedans | 8 | 11th January 2005 22:52 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
