Old 22nd September 2005, 13:44   #16
navin's Avatar
Thanked: 4,282 Times
what about a sail and an octy? where in worli-mumbai can i get this. i assume they can be self fitted.
Old 22nd September 2005, 13:59   #17
Rtech's Avatar
Thanked: 221 Times
You can get 'em at 4-Seasons. And yes, they are self fitted! A person who makes his own speakers is asking whether valve caps are a DIY job!!
Old 22nd September 2005, 14:15   #18
Mad Monkey's Avatar
Thanked: 324 Times
Rs. 690 for 4 in mumbai from 4 seasons tardeo
Mad Monkey is offline   Reply With Quote
Old 22nd September 2005, 14:22   #19
navin's Avatar
u never know if there was some thing special going on. those days of using a strobe to tune a padmini are gone. try doing that to an RS? :-)
besides building speakers is fun. it gives me a chance to get dirty with enggineering. so 4 seasons will give me these for any car? got a number ?
Old 22nd September 2005, 14:24   #20
navin's Avatar
also what i did at 19 dont apply at 40+. in college we built an amphibious car with dual trannys one for the propellers and other for the wheels. you wont catch me doing that today.
Old 22nd September 2005, 14:40   #21
k_ajay's Avatar
Thanked: 488 Times
Why don't u Buzz Turboindia.... He would be able to give u a mumbai # to contact, navin...
k_ajay is offline   Reply With Quote
Old 22nd September 2005, 16:46   #22
Mad Monkey's Avatar
Thanked: 324 Times
lalit jogani
four seasons automobiles PVT LTD
24940444
info@4seasonsautomobiles.com
Old 22nd September 2005, 19:49   #23
pranil's Avatar
Default 30 or 32 PSi for GETZ
GEtz has Tyre pressure (recommende) as 30 PSi for only two passengers on all four
and 33 PSi when fully loaded.
Do these indicators indicate ove pressure also. In above case what should be used. 30 psi or 32 PSi.
pranil is offline   Reply With Quote
Old 27th September 2005, 00:40   #24
speed0mania's Avatar
Exclamation availability in delhi??
hey anyone knows where i can get it in delhi?? and what would be the price for one for a zen !! also the company says the pressure should be 24 psi but i feel about 26 is better!!!
speed0mania is offline   Reply With Quote
Old 27th September 2005, 01:05   #25
autopsyche's Avatar
Thanked: 15 Times
Hi speedomania, you can collect a set of 26psis from me either from karol bagh or gurgaon whichever is more convinent to you. We are dealers for pete's in new delhi.
Arush
9810518681
autopsyche is offline   Reply With Quote
Old 27th September 2005, 12:27   #26
Thanked: 17 Times
Default Availability in Bangalore
Hi
Where is this available in Bangalore and which one should i buy for Accent Viva CRDi. Thanks..
Aravind
aravindr is offline   Reply With Quote
Old 19th October 2005, 14:34   #27
narasimha raju's Avatar
Thanked: 40 Times
Normally the tyre pressure for the front tyre and back tyre are different as per manufacturer's recommendation like 32psi for front and 30 psi for back. In this case
which psi cap should we buy?
Also please let us know where these are available in Hyderabad
narasimha raju is offline   Reply With Quote
Old 19th October 2005, 15:12   #28
Thanked: 23 Times
Maybe they should be sold in pairs then you could get the correct ones for front and back (I am asuming they are sold in a pack of 4 as they are in the UK).
The alternative is to find someone with the same car as you who would also like some air checkers. Then buy a pack each (one 32 the other 30) and swap two with each other.
bigman is offline   Reply With Quote
Old 20th October 2005, 01:18   #29
turboindia's Avatar
We sell them in pairs and fours so you wouldn't have a problem,
Our distriutor for Hyderabad is Stunnerz - 9346925000. Mr AMar. If you have any problems pls feel free to call or sms to our Helpline no - 9895088444,
HAVE FUN
turboindia is offline   Reply With Quote
Old 20th October 2005, 22:37   #30
v1p3r's Avatar
Thanked: 27 Times
Aravindr, for Bangalore, please check at Hot Tracks, on Residency Rd (next to Bangalore Club).
8 Valve SOHC vs 16 Valve SOHC shineshine Technical Stuff 6 12th February 2016 22:23
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
Fuel Pump Pressure valve cheatingdeath Technical Stuff 1 27th November 2004 12:05
Accords Fuel pump pressure regulatory valve cheatingdeath Technical Stuff 2 8th June 2004 11:13
