Old 12th August 2005, 19:11   #1
pranil's Avatar
Default Aircheckers by Petes- Show tyre pressure by valve cap
Hi, Guys,
Anybody has purchased /used pete's Aircheckers,
By what I could gather from Advert in Aug issue of Overdrive is that these are valve caps with colored indicator. on Normal pressure they will indicate green. On abnormal pressure they will turn red.
So no more checking of pressure with manul gauge.
My main worry is that to get the pressure this devbice must be in contact with air inside the tube . That means the tire non retun valve remains pressed continuously. What happens if the cap becomes loose. Also what is the impact on the NRV over long time as it may damage the spring and then when u remove the cap the air will leak out
Here is the advert.
pranil is offline   Reply With Quote
Old 19th August 2005, 12:58   #2
redrage's Avatar
Thanked: 60 Times
its pretty expensive too... heard its around 400 bucks per cap...... and it might easily be pinched off.
redrage is offline   Reply With Quote
Old 19th August 2005, 14:44   #3
autopsyche's Avatar
Thanked: 15 Times
The air checkers are a replacements for your valve caps, thats how they detect the air pressure, presently available in ratings of 26, 28 and 30 psi. And yes youre right about the indication it shows green when its full air pressure and moves to yellow and red as and when the tire pressure decreases.
Also each set comes with a locking nut to prevent theft which can be opened with a special small wrench provided with the kit and can be fixed into your car's keychain.
Costs Rs.595 for a set of four pieces.
Cheers~
Arush
autopsyche is offline   (1) Thanks Reply With Quote
Old 19th August 2005, 19:31   #4
pranil's Avatar
Default Air checkekrs officail replly.
here is my queries to the company and their officail reply
Dear Mr. Anil,
Thank you for your enquiry.
Please find enclosed the clarifications to your doubts
1) You are right they change colour depending on the air pressure in your tyre and also depending on the Psi of your Airchecker
2) They are made for fixed pressures. They come in ranges from 26 PSI to 60 PSI. Depending on the car you drive and the tyre you use you need to buy the
one that suites you. In your case it is the 30 PSI Airchecker
3) The Airchecker stays Green until there is a drop of 3 to 4 Psi when it turns yellow and then a further drop of 3 to 4 psi will make it green. In your
case when you use the 30 PSI Airchecker it will turn yellow at around 26-27 Psi and it will turn RED at around 22-23 PSI.
4) The MRP in Mumbai is Rs 620/set including the locking nuts.
5) Just call Mr. Lalit @ 9820289737. He will help you
REG YOUR MAIN WORRY.
You are perfectly right in that the non return pin has to be pressed continuously for the Air pressure to be shown on the Airchecker. There is no reason why the cap should get loose if you have tightened it well and in any case once it gets loose the NRV in your tyre just seals the air like normal. And since the spring is kept pressed throughout nothing can happen to it. It is not moving at all. Hope this clears your doubts,
We have arranged to courier a set of the brochures to you,
Sumathi
Customer Services
Pete's Performance Products
The International Hotel
P B No-3563, M G Road
Cochin - 682035
Ph: +914842382006
Fax: +914842384755
www.petes.in
My question to them
Dear Sir,
I would appreciate if u furnish following information on aircheckers. I got the email from AUG Overdrive issue.
1. Functionality - I presume they change color according to different pressure
2. Are they made for fixed pressure or settable by consumer
3. This is meant for Santro ( recommended pressure on Eagle 3 Goodyear tubeless is 30 PSI) So what is the differential /hysterics beyond which it will change color ( e.g. +- 2 PSI)
4. What is the MRP
5. How can I procure the same in Navi Mumbai.
My main worry is that to get the pressure this device must be in contact with air inside the tube . That means the tire non return valve remains pressed continuously. What happens if the cap becomes loose. Also what is the impact on the NRV over long time as it may damage the spring and then when u remove the cap the air will leak out
pranil is offline   (1) Thanks Reply With Quote
Old 19th August 2005, 19:34   #5
pranil's Avatar
Default Wheel balancing required
One more query. Is wheel balancing required .
if yes does that mean that when u remove the indicator for spme reason u have to rebalance the wheel
Old 20th August 2005, 17:54   #6
carfreak's Avatar
Thanked: 179 Times
hi all,i have been using these aircheckers in my accent crdi for the past few months.bought them for around 900+ including the safety lock.i must say i am not too sure about your query of long term safety.guess pete can answer those better.but what i thought was that it is much better than the digital pressure checker i had which used to give regular wrong results.no need to worry with this as it gives a daily monitoring of pressure and one has to check it only when it goes to the yellow zone
carfreak is offline   Reply With Quote
Old 21st August 2005, 02:08   #7
EVO6's Avatar
Me too using aircheckers ... Its a brilliant product.. Specially with the new gen cars as wrong air pressure can cause all sorts of hazards including high wear and tear ... Its much better than hiting the fuel stations to check air where the gauges are not at all calibrated ... I dont see any long term wrongs with this product ... its just like a normal value cap with a pressure guage ... Doesnt weigh too much either so there is no hassle about balancing involved... You have to balance tyre only when u feel wobble in the car and advised at every 5000 km..
EVO6 is offline   Reply With Quote
Old 31st August 2005, 14:33   #8
turboindia's Avatar
Sorry for the delay guys for this reply. Guess I was not subscribed to this thread.
That is right, you needn't balance your tyres just because you have put on the Aircheckers but the next time you do balance your tyres do it with the Aircheckers ON so that you can perfect your balance. The weight is really negligible anyways.
Good to know you guys really like the product. It is a world class high quality product and we intend to keep our products that way.
Rgds,
Peter
turboindia is offline   (1) Thanks Reply With Quote
Old 14th September 2005, 17:06   #9
jkdas's Avatar
Thanked: 1,436 Times
and for a santro, how much would it cost?
Old 14th September 2005, 17:40   #10
turboindia's Avatar
Give me your number.I'll call.
turboindia is offline   Reply With Quote
Old 14th September 2005, 17:48   #11
viper's Avatar
Thanked: 9 Times
Hey Turbo,
Do you have any performance products for a Opel Swing.
Viper
viper is offline   Reply With Quote
Old 14th September 2005, 17:49   #12
k_ajay's Avatar
Thanked: 488 Times
Rgds,
Peter
Hi peter... Could you list the mrp of the air checkers for an Indica... and is it prone to getting stolen.. the last thing i'd want is someone to steal it after having spent a considerable amount on an air cap... and it is highly accurate, compared to digital pressure checkers...?
Please let me know where I can get one in Chennai... or a way in which i can get it directly from you..
AK
k_ajay is offline   Reply With Quote
Old 22nd September 2005, 12:28   #13
k_ajay's Avatar
Thanked: 488 Times
Is this thread dead??? Hellow, pete???
Old 22nd September 2005, 13:10   #14
turboindia's Avatar
I am sorry for the delay,
The MRP for a set of Aircheckers in Chennai are Rs 595. These include a set of locking nuts which answers your other question.
You can contact Dreams Auto - 04428226358
9884020728
Old 22nd September 2005, 13:20   #15
k_ajay's Avatar
Thanked: 488 Times
Thanks much! will call up the dealer you've recommended...
8 Valve SOHC vs 16 Valve SOHC shineshine Technical Stuff 6 12th February 2016 22:23
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
Fuel Pump Pressure valve cheatingdeath Technical Stuff 1 27th November 2004 12:05
Accords Fuel pump pressure regulatory valve cheatingdeath Technical Stuff 2 8th June 2004 11:13
