Old 17th December 2009, 16:43   #1
Default Tyre upgrade for My Qualis
Please suggest a tyre upgrade for my qualis, it has run 126000 kilometres. It is still on 14 inch rims. So i was wondering which tyre to upgrade. I recently put on new shoes for my swift vdi, it is yokohama Es100 195/60/R15.
So guys waiting for your input.
samy3660 is offline   Reply With Quote
Old 19th December 2009, 10:17   #2
v12
v12's Avatar
Thanked: 4,078 Times
Try Goodyear Wrangler DT, they've performed well on our Qualis.
v12 is offline   Reply With Quote
Old 19th December 2009, 23:01   #3
abhayshanu's Avatar
Thanked: 168 Times
Im using Bridgestone Ponteza GIII on my qualis and this was the second time i opted for these. But my qualis has also run alot , around 1.4L KMs and we have changed the tyres a total of 3 times, then how is it that your stock tyres lasted 1.2L kms?
abhayshanu is offline   Reply With Quote
Old 20th December 2009, 15:00   #4
No, we have changed the tyres before but never upgraded it to a good one. So whats the upsize you guys recommend, i like Goodyear Wrangler DT. And what other options.
Thankyou.
Old 12th January 2010, 18:57   #5
Guys i am planning to go for michellin XM1+ 195/70/R14 what do you guys say??
Please respond as soon as possible
Thankyou
Old 12th January 2010, 20:26   #6
discoverwild's Avatar
Thanked: 1,137 Times
Please note that you will need commercial radials for the Qualis. The XM1+ would be a passenger radial and would wear out faster, not to mention uneven wear. Happened to me with the Bridgestones. I think the right upgrade is 195/60 R14, don't remember exactly though.
discoverwild is offline   Reply With Quote
Old 12th January 2010, 20:30   #7
Jaggu's Avatar
Thanked: 8,671 Times
Check the load index for Qualis and see if it matches XM1's, also if you plan to use the vehicle on rough roads go with good ol Appolo or MRF's.
Old 13th January 2010, 19:17   #8
Well thanks discover wild and jaggu, so i think xm1+ is a no go. I think Goodyear Wranger DT would be a good choice, and regarding the upsize, what is the best profile??
Old 13th January 2010, 20:49   #9
vigsom's Avatar
Thanked: 603 Times
195/70R14 or 205/65R15 is a good upgrade for Qualis.
You can get both in Turanza ER60
Have seen the Turanzas on some Innovas;from reports that I have heard,they are the best blend of comfort and durability
Samy,wasn't it you who reported a Swift tyre upgrade and some steering issues?
Old 13th January 2010, 21:09   #10
WasavaTyres's Avatar
Thanked: 255 Times
Try Goodyear's Assurance in 195/70/R14 size. Just check if the unconditional warranty scheme is still on.
WasavaTyres is offline   Reply With Quote
Old 14th January 2010, 18:24   #11
Yes Visgom i reported a problem regarding swift steering assembly issue and i think now, that it was due to the loose nuts of the driver side rear wheel which i accidently found out(thank God). Now the noise is gone and i couldn't exactly say if there is any issue with assembly because even the service advisor at MASS hasn't confirmed anything.
And seeing the masses in here uses 195/65/R15 on swift i don't think that the tyre is at fault.
Thanks guys now i have 3 options:
Goodyear Wrangler Dt
Goodyear Assurance
Turanza ER60
Old 19th March 2010, 23:46   #12
montyguru's Avatar
Default qualis tyre upgrade/upsize
hi,
i want to change tyres for my qualis run 110,000... can i fit tubeless on stock rims? what would be good sizes to upgrade?
montyguru is offline   Reply With Quote
Old 21st March 2010, 10:44   #13
predatorwheelz's Avatar
Thanked: 1,122 Times
Originally Posted by montyguru View Post
hi,
Did your car originally come with 175 or 195 width tyres?
Either way, I'd suggest using 195/70 Bridgestone Turanzas. They came as OEMs on the "RS" model. Easy to source, and pretty long-lasting.
If you're going for some other tyre (someone has mentioned earlier on this thread) do remember to check out the load index to see if it matches with the recommended for Qualis.
predatorwheelz is offline   Reply With Quote
Old 21st March 2010, 20:38   #14
montyguru's Avatar
it's a 2000 GS model which has 175 bridgestone E700. i think its 175/85 R14... 195/70 sounds good, will have a look at it. thanks.
Old 10th May 2010, 14:20   #15
Just bumping this thread as i am not able to source turanzas in mumbai, looks like it has been discontinued. The dealer i am talking to has 4 turanzas tyres ready with him and he is telling me that the 5th one will be available in 2 or 3 days. Now do you guys think will it be discontinued, and if it is discontinued then will it be a problem for me?? Now please its urgent coz i am going to change it in next 2/3 hrs, what other good tyres can i opt for?? I have now only 2 options one is assurance and other one is bridgestone er88, which the dealer is suggesting me.
Thankyou.
Tavera Vs Qualis Vs Bolero Stratos The Indian Car Scene 29 18th April 2009 08:46
Toyota stops production of the Qualis!! GTO The Indian Car Scene 37 7th February 2005 21:12
Toyota Qualis sridhar24 The Indian Car Scene 1 3rd July 2004 18:17
Tavera vs Qualis toyota The Indian Car Scene 6 7th June 2004 16:28
Mods on Qualis rear windows?? v12 Modifications & Accessories 7 22nd April 2004 04:44
