Old 21st April 2017, 15:40   #16
Thanked: 375 Times
Default Re: TPMS - Tyre pressure monitoring system by Tyreprobe
I am also planning to purchase a TPMS from aliexpress.com
Please let me know if anyone has tried this. Looks like, this is very cheap and has received good comments and feedback from buyers in aliexpress
TP620:TPMS Aliexpress
gkveda is offline   Reply With Quote
Old 22nd April 2017, 01:26   #17
I too am looking for feedback regarding the same product. Would appreciate any feedback.
p_sajeev is offline   Reply With Quote
Old 22nd April 2017, 13:49   #18
mjumrani's Avatar
Thanked: 333 Times
Infractions: 0/1 (5)
An internal pressure sensor is always better than external, have a look at CareUD U912. I have got the same.
mjumrani is online now   (1) Thanks Reply With Quote
Old 22nd April 2017, 16:19   #19
rkg
Thanked: 543 Times
How long you are using them. what about the performance?
Where did you buy them and cost?
rkg is offline   Reply With Quote
Old 24th April 2017, 09:53   #20
Thanked: 375 Times
Thanks for the reference mjumrani. In my opinion, from the information I gained from the posts in TBHP, both of them have advantages and disadvantages and it is a question of what is the users' convenience and priority.
Internal sensors are a bit difficult to install and replace. In case, battery goes down, or sensors go kaput, the whole tire has to be removed to replace the sensor.
External sensors are prone to threats like thefts are petrol bunks, long time parking etc
Both of them have no major differences in terms of battery life, sensor life, or Display unit life
So, I am thinking to go with external sensors and taking a risk ! !
Old 24th April 2017, 09:58   #21
Thanked: 13,390 Times
If I can suggest, please get the internal ones.
IMO, it is a single time install and no tension of theft too. Plus after rotation re-learning is easier and one doesn't need to remove the sensors and re-fit them when going for wheel alignment job or parking at malls, etc.
Most sensors available are more or less reliable so the worry of it going bad is less unless the wheel hits a pothole pretty hard.
a4anurag is offline   (2) Thanks Reply With Quote
Old 24th April 2017, 10:44   #22
mjumrani's Avatar
Thanked: 333 Times
I got them from aliexpress during sale, cost of the product was 4295/- which includes a customs duty of 232/-.
A member here has already installed the exact same model i quoted earlier. Display unit sits on dashboard hardwired to the fuses. Sensors have battery which are user replaceable. According to interweb reviews the battery lasts 2 years. Installing them is quite easy , just remove the existing valve and use the valve which comes with the product.
Here is the link to the review by our own member sudeepg S-Cross DIY: TPMS & 12V socket installation (S-Cross DIY: TPMS & 12V socket installation)
Old 26th April 2017, 20:55   #23
rkg
Thanked: 543 Times
[/url]
It retails for $80 on Amazon.com
https://www.amazon.com/Careud-Wirele...ds=careud+u912
Old 28th May 2017, 09:31   #24
Thanked: 216 Times
Please do not buy Blaupunkt TPMS. Within few days the front of display unit came off the charger while removing from socket. Rs. 13990/- gone waste. I regret recommending it in New Fortuner thread. . I have now bought Roger Motor TPMS and installed on fortuner.
Advantages of Roger TPMS over Blaupunkt TPMS:
1. Much brighter display.
2. Display angle can be changed to suit driving position and location of cigarette lighter socket.
3. Sensor smaller and less conspicuous.
4. Display starts when vehicle moves - saving on battery in sensors.
5. 2 years replacement warrantee from Rajkot seller.
6. Displays temperature also.(in centigrade)
7. Cost Rs. 7600/- including delivery.
Negatives:
1. Roger TPMS did not include little rubber flaps to cover angle between tire nozzle and the sensor.
DwarkaDelhiWala is offline   (1) Thanks Reply With Quote
DIY Install: 'TyreSafe' Tyre Pressure Monitoring System a4anurag Tyre & Alloy wheel Section 73 17th November 2017 12:37
Review: Solar-powered Tyre Pressure Monitoring System. EDIT: Unreliable & waste of money raj_5004 Modifications & Accessories 19 3rd May 2016 10:29
TyreProbe TPMS - 6 month review joybhowmik Technical Stuff 15 16th November 2014 16:56
