Old 29th August 2005, 14:03   #1
yamdoot's Avatar
Thanked: 12 Times
Default tyre upgrade for m800
hi everybody! can anyone tell me if i can fit 145/80 r12 tyres on my m800 instead of the regular 145/70 r12 ? id read in some auto mag that its ok to fit these tyres n in a way it helps..have also seen a few m800s with these tyre sizes.. also if u can suggest a brand..im thinking of JK ultima xp..pls help me as its time 4 me to change tyres soon.. thanks
yamdoot is offline   Reply With Quote
Old 29th August 2005, 14:36   #2
Thanked: 18 Times
Welcome to tbhp yamdoot.
If you change the aspect ratio of your tires (70->80) you wold have a error of almost 6% where the odo and speedo will show 6% less kms and speed respectively that you are actually clocking (with respect to the stock tires).
You will add 14-15mm in ground clearance because of increased overall radius of the wheel.
145/75 R12 may be a better option as far as the error is concerned (less than 3% in that case).
Others can tell you about any benefits of going from 70->80 in terms of ride and handling.
manu is offline   Reply With Quote
Old 29th August 2005, 14:47   #3
Thanked: 103,472 Times
Yamdoot - Welcome to Team-BHP.
Your topic has been moved to the appropriate section (From Introduce Yourself to the Tyre & Alloy Wheel forum)
My dad's 2001 MPFI M800 - Keep or upgrade? blackasta Hatchbacks 27 30th June 2011 00:21
Fog lamps for M800. Battery upgrade required? ssengo Technical Stuff 8 13th April 2010 10:16
M800 - Mid-Budget ICE Upgrade (Re-Do) WoodenKnight In-Car Entertainment 42 15th May 2007 18:10
m800 vs ikon (what comp can a M800 be?) manaa45 Street Experiences 13 31st March 2005 12:06
