Old 24th May 2006, 11:13   #16
Rtech's Avatar
Thanked: 221 Times
Will the spacers screw up anything???
Nope. Just your bank balance!!
Old 24th May 2006, 12:02   #17
Rehaan's Avatar
Thanked: 25,038 Times
Originally Posted by Edmund
People, no one seemed to have answered my query, Will the spacers screw up anything???
Hey,
As you probably know, car hubs use tapered roller bearings, which can handle very high radial and thrust loads. They are used in pairs facing opposite directions so that they can take thrust loads in both directions. (ie cornering left OR right).
Now, according to the law of moments, the force increases as you move the load further away (basically a lever). So by increasing the offset, what you are doing is basically multiplying the forces as the distance (offset) increases.
This puts a lot more stress on your bearings and other components. How much more force? that depends on how much you are spacing you wheel out.
And to draw a parrellel, the Q u ask is similar to "i am planning on putting a turbo on my car, how much will engine life reduce? "
When i put alloys on my car the change in offset caused a most noticeable change in the steering behavior. Not better or worse, just different. When you hit a different suface or a puddle with one wheel, the car definitely tried to head in that direction, so you have to be a little more alert! (Im sorry but sadly i dont know what the overall change in offset was!)
Are you planning on only using the spacers in the rear?
So there is my answer which doesnt answer your question.
cya
R
Old 24th May 2006, 21:50   #18
Thanked: 97 Times
Yup, now explain!!!! Since the suspension geometry is linear, are they any ill effects???
cya
R
At least you tried!!! Thanx mate!!!
Edmund is offline   Reply With Quote
Old 25th May 2006, 00:41   #19
v1p3r's Avatar
Thanked: 27 Times
Less (ill-)effects than Rehaan's car, I would guess, because your rear wheels are non-driven and non-steering.
Seriously, ask for something else as a gift. Like a cheap crated engine, or the mother of all mod necessities, CASH!!!
Old 7th November 2007, 14:24   #20
binz's Avatar
Thanked: 412 Times
Hello,I just borrowed a set of corrola rims from a friend and i have this issue; that is,the wheel sits inside the wheel well because of the rim's offset.Would adding spacers negate the effect of the offset(negative offset i believe)
Old 7th November 2007, 14:39   #21
kpzen's Avatar
Thanked: 1,655 Times
Corolla rims for which car?? M800???
Old 7th November 2007, 17:24   #22
binz's Avatar
Thanked: 412 Times
mclarens rims,my car
Old 7th November 2007, 19:27   #23
kpzen's Avatar
1. U both have Baleno's right?
2. Was Mclaren facing the same issue?
3. What tyres have u put on the corolla rims?
Old 7th November 2007, 19:34   #24
binz's Avatar
Thanked: 412 Times
Yup same cars.The corolla offset is slightly negative for the baleno.As a result,the wheel sits about an inch inside the wheel well.Both front and rear track are reduced and I assumed that adding spacers would bring the front and rear track to stock specs.
Advan Neovas 195/50/15
Old 8th November 2007, 14:33   #25
Sankar's Avatar
Thanked: 4,643 Times
Whoa this thread has been called from the grave. Was Rahul's car facing the same negative offset issue? The wheels looked ok on his car.
Old 8th November 2007, 14:56   #26
kpzen's Avatar
I think its a case of positive offset and not negative offset.
Old 9th November 2007, 17:44   #27
Sankar's Avatar
Why does he need spacers if it's positive offset?
Wheel spacer Parm 4x4 Technical 22 14th January 2016 13:53
Spring spacer & Spring rate question Sankar Technical Stuff 15 23rd January 2011 20:21
My Experience of using Carburetor Spacer finetuning Technical Stuff 13 15th September 2008 17:08
Need some info on steering spacer. Shan2nu Technical Stuff 9 24th May 2007 05:42
m800 vs ikon (what comp can a M800 be?) manaa45 Street Experiences 13 31st March 2005 12:06
