Old 31st March 2011, 16:06   #136
Nikhilb2008's Avatar
Thanked: 5,102 Times
Default Re: Everything about Wheel Alignment: Post your queries here
It could be uneven wear on the tyres. Or an improper job on the balancing.
Old 31st March 2011, 18:49   #137
SPIKE ARRESTOR's Avatar
Thanked: 757 Times
Nikhil, a query - Have you done some study / analysis / observation regarding when shimmy starts on a vehicle (due to lack of wheel balancing / fallen weights)? I mean, say a 20g fallen weight doesn't show up easily whereas a 50g weight starts showing up symptoms immediately. I know the speed at which this occurs will be different for different setups but still curious to know.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 31st March 2011, 19:35   #138
falcon009's Avatar
I hope its that. Gave it for servicing and hoping for better results.
falcon009 is offline   Reply With Quote
Old 1st April 2011, 12:10   #139
Spike
Nope. I havent done any study on this but as you said, it depends from setup to setup.
Old 11th April 2011, 19:34   #140
Thanked: 18 Times
Hi Nikhil,
I own a Swift VXI, my rear left tyre had uneven torn out with tread wearing more on the outside. MASS said it is bearing issue and changed the bearing and put stepney which was in good shape in rear left. That tyre too met the same fate. Then I did a alignment check at a tyre house couple of days back.
The report said Rear Toe as below,
Rear Toe Left -- 2.3 mm
Right -- 3.7 mm
Total -- 6.0 mm
They said it is due to some beam/chasis problem and asked to check at MASS showing the report.
Do you have pointers here?
Dinesh
ndinesh is offline   Reply With Quote
Old 12th April 2011, 16:46   #141
Could you post a scan or a pic of the actual alignment report?
Old 13th April 2011, 18:32   #142
Thanked: 18 Times
Hi Nikhil, here is the copy of the report.
Old 14th April 2011, 22:59   #143
Thanked: 18 Times
Originally Posted by ndinesh View Post
Hi Nikhil,
Right -- 3.7 mm
Total -- 6.0 mm
MASS guys say that I need to change rear spindle and it may solve the issue. If still not solved, then I need to replace the rear axle. Any suggestions? Is it the right thing to do?
Old 22nd April 2011, 22:33   #144
Thanked: 18 Times
Can anyone post alignment report of your Maruti Swift here for reference. I did not get any suggestions for my previous posts, hence would like to know what would be the optimal rear toe reading for swift. Alternately you can also PM me your report.
Dinesh
Old 2nd May 2011, 17:12   #145
Thanked: 18 Times
I heard from a tyre shop that readings in alignment report can be either in degrees or in mm. Mostly western countries use degree notation and here we use mm for the readings.
Can anyone provide more information on this aspect?
Dinesh
Old 2nd May 2011, 20:10   #146
Dinesh, absolutely right. It doesnt make any difference. A good 3D wheel alignment machine (like John Bean or Hunter) will show the standard specs in mm or degrees depending on how it has been set up.
As long as the AFTER readings are within the tolerance zone, you dont need to worry about whether they are in mm or degrees.
Nikhilb2008 is offline   (1) Thanks Reply With Quote
Old 3rd May 2011, 11:55   #147
Thanked: 18 Times
Further update on the issue posted by me earlier in this thread. I had changed both rear wheel spindles at MASS. Did an alignment check post this change and the rear toe reading has come down. Now the total toe reading in the rear is 2.0 mm. Before spindle replacement it was 6.0 mm. Tyre shop guys say now the value is fine and the tyre should not get uneven wear.
Will post the latest alignment report as soon as I get it scanned.
Old 5th May 2011, 19:05   #148
Dinesh, I didnt see your scanned pdf until now.
That report is incomplete. The Specified values shouldnt be blank for the rear toe. There should be some number there to which you can compare the before and after readings.
Old 12th June 2011, 19:05   #149
Gill's Avatar
Thanked: 12 Times
Does the change in the wheel diameter affects the wheel alignment(Alignment is of Hub).When ever I go for alignment, they punch in the car name and alignment is done on the basis of default specifications. In the report the rim diameter is mentioned as 14", instead it's 15". Won't the sensors be affected due to change in the diameter?Will it affect the Toe and Camber?
Gill is offline   (2) Thanks Reply With Quote
Old 15th June 2011, 19:26   #150
No. It wont matter. The wheel size has no relation to the readings you see on the machine. Alignment can be done without the wheel also. It has absolutely no relation.
Wheel alignment or wheel balancing?? leodelg Tyre & Alloy wheel Section 27 22nd June 2011 00:44
Breakdown Assistance for 1 year, Wheel Alignment & Wheel Balancing just for Rs 199 Mitsun Soni The Indian Car Scene 11 8th March 2011 11:02
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
