Old 28th April 2016, 19:39   #346
heysac's Avatar
Thanked: 13 Times
Default Re: Everything about Wheel Alignment: Post your queries here
Here's the alignment report for my Swift K Series 2010 driven 21K kms.
The car sometimes seem alright but many a times pulls to the left with steering also turning left. The pulling is prominent on either roads which are not very smooth or have slight banking. Even on roads which are fine but produce a very minor jerk the car pulls to the left.
I have gone back to the car alignment guy and rechecked the machine readings in front of me, the individual camber is slightly out for both (but within limits) as can be seen from the attached report. I remember the machine showing the total camber as out and in red but the guy said the total camber doesn't matter. He also gave up saying the car is fine and I should take it to someone else if I am not satisfied. I think the car is pulling as compared to earlier.
One caveat is that the tyres on the front now came from the back for the first time and are flat but one tyre has a tube (due to sidewall puncture) and the other doesn't. Any suggestions would be appreciated.
Originally Posted by Nikhilb2008 View Post
You may need to post the alignment report
done!
Everything about Wheel Alignment: Post your queries here-2016-04-swift-wheel-alignment.jpg
heysac is offline   Reply With Quote
Old 3rd July 2016, 18:22   #347
vsathyap's Avatar
Thanked: 637 Times
Default Honda City 2014 Wheel Alignment query
Hi all, i just got the wheels of my 2014 Honda City aligned at a local wheels and tyre center. I chose to get it done outside the HASS due to the relatively better job done by tyre and wheel shops in general.
However, on checking the report, I see that there is no major change in the parameters before and after the alignment. On asking the guy he said that the wheels of the city have some moulded alignment thing that cannot be altered and hence the lack of any major difference before and after the alignment.
Can experts comment on this? I have a doubt that the alignment is done correctly. I'm attaching the report given by the wheels guy.
Thanks in advance.
Everything about Wheel Alignment: Post your queries here-20160703_184315.jpg
vsathyap is online now   Reply With Quote
Old 4th July 2016, 10:45   #348
Nikhilb2008's Avatar
Thanked: 2,956 Times
Default Re: Honda City 2014 Wheel Alignment query
Thanks in advance.
Attachment 1523795
Basically all the red readings are what are fixed. They cannot b adjusted outside the HASS unless someone has the patience and know how to dismantle the suspension, use camber bolts, etc....
You have to go to HASS and get it done.
Most outside Alignment shops only adjust the front toe which is usually adjustable. On cars with independent rear suspension, the REAR TOE may also be adjustable and sometimes REAR camber as well.
In an Innova, the rear is fixed but the front Toe, Camber and Caster is adjustable.
It varies from car to car.
On the Honda City, it is only Front Toe which is adjustable.
Nikhilb2008 is offline   (1) Thanks Reply With Quote
Old 8th July 2016, 21:43   #349
Hi Nikhil,
Due to lack of time, I am considering getting WA and WAB done in A.S.S. But its really difficult to trust these guys. Especially considering the volume of cars during the weekend. I might get it it back as is. Is there a way to verify they have indeed done something?.
Please get WA/WB done outside the service centre. Much cheaper(between 500-600) and you generally get a better service as tyre showrooms would be specialists in this.
Also, Wheel balancing is done normally every 5k kms along with alignment. You may not feel any noticeable change but every small imbalance(even if it isnt noticeable by the driver) will add to the wear and tear of the suspension.
adithya.kp is offline   Reply With Quote
Old 9th July 2016, 10:15   #350
Originally Posted by adithya.kp View Post
Hi Nikhil,
Ask them to do the wheel alignment in front of you. Beyond that, not much else.
Also ask them for an alignment report but it's easy to pass off another vehicle's report as yours.
Old 9th July 2016, 11:01   #351
Thanked: 38 Times
Hi folks. Just wanted to know. I recently got wheel alignment done. The Swift ran straight for a week but then started pulling slowly to the left again. Can the screws used for alignment become loose as a car gets old? What permanent solution is there for this?
By the way, this activity happened few days after i changed my tyres. That in itself was a terrible experience. Thread below
http://www.team-bhp.com/forum/tyre-a...wall-flex.html (Falken Sincera: Excessive sidewall flex)
naturaldisaster is offline   Reply With Quote
Old 17th September 2016, 06:09   #352
kartikoak's Avatar
Thanked: 11 Times
Hi Folks,
Planning to take my S-Cross 1.3 for Rotation, Balancing, Alignment today. Does anyone know if all factors of alignment can be done out side of MAS, I ask as some cars like Figo or the one mentioned in this thread have some parameters that cannot be fixed at an external agency.
Kartik
kartikoak is offline   Reply With Quote
Old 19th September 2016, 16:29   #353
Thanked: 13 Times
A quick question here, recently while driving my ford figo, i went over a cement brick.
Speed was in the lower 30's. I did alignment and balancing after that and they told me my camber values needs to be fixed as there is some bend.
These are my values according to them for camber
Left -1.31
Right -3.01
Target data for Left and Right -0.30 +/-1.15
They are saying it can only be done at Ford ASS. Is it true? And is it a difficult work and how much money it would cost?
If someone could answer this, it would be great.
Thanks in advance.
aneeshtn is online now   Reply With Quote
Old 21st September 2016, 14:39   #354
Left -1.31
Right -3.01
Thanks in advance.
Yes, camber/caster adjustment typically cannot be done in a normal alignment centre. You will have to take it to the Ford service centre and get it done.
Old 21st September 2016, 15:32   #355
humyum's Avatar
Thanked: 2,104 Times
Left -1.31
Right -3.01
Thanks in advance.
That looks like a bent strut. Camber is not adjustable in a Figo, they will ask for a strut replacement and if the car has done a lot of kilometers, then struts need to be changed in pairs.
humyum is offline   (1) Thanks Reply With Quote
Old 21st September 2016, 15:47   #356
Thanked: 13 Times
Thank you for the prompt reply. Even i read somewhere about figo not having Camber adjustment and it would be Struts bent if Camber value is off. Need to take it to Ford ASS as early as possible. I am not taking the car out these days, as there is already a slight inner tyre wearing out more than the outer part. I believe it is to do with this. Please correct me otherwise.
Old 18th December 2016, 20:21   #357
csr9's Avatar
Thanked: 92 Times
Hi all
I own a 2012 Skoda Superb 2.0 TDi. Until now, i have been getting the wheel alignment done at the A.S.S. Off late, I have been travelling quite a bit, so I had to get the wheel alignment done outside. I had been to many places but all of them had reference values for the 2007 Skoda Superb (Gen 1). It would be of great help if someone could share the reference values/alignment report for 2012 Skoda Superb (Gen 2).
Thanks in advance.
csr9 is offline   Reply With Quote
Old 30th January 2017, 15:01   #358
Thanked: 119 Times
I have moved from Bangalore to Coimbatore. I used to get my Duster's wheel balancing n alignment @Madhu's. Any Team BHPian at Coimbatore can recommend a good place at Coimbatore? Tnx n cheers
Waxeloquent is offline   Reply With Quote
Old 1st February 2017, 20:28   #359
Coimbatore is generally a good place for car enthusiasts. There are some very good people there who run alignment centres.
I have been to Sree Vari Aligners twice and the job was done well. Owner's name is Ganesh Moorthy. Quite a nice chap as well.
Annamalayar Tyre Service Company is also well known. Owner's name is Balganesh.
Nikhilb2008 is offline   (2) Thanks Reply With Quote
Old 14th February 2017, 00:28   #360
smrtdvl's Avatar
Thanked: 61 Times
My 5.5yr old 55000kms run Vista's right rear tyre has started developing a black mark at the outer edge. The outer edge of this tyre alone doesn't get in contact with the road. I usually maintain 32psi at the rear but after this problem tried 30psi but still the problem persists. What could be it. I am sure it's not a alignment problem cos it's a dead axle at the rear for Vista but wanted to check with you guys.
smrtdvl is offline   Reply With Quote
Wheel alignment or wheel balancing?? leodelg Tyre & Alloy wheel Section 27 22nd June 2011 00:44
Breakdown Assistance for 1 year, Wheel Alignment & Wheel Balancing just for Rs 199 Mitsun Soni The Indian Car Scene 11 8th March 2011 11:02
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
