Old 13th March 2010, 00:47   #46
Monaro CV8's Avatar
Thanked: 464 Times
Unhappy Damn wobble!
@ Nikhil: Great Info there on WA & WB!
I've been having my own set of wobble issues with my Octavia 1.9TDi.
The vibrations can be felt on the steering wheel when the odo hits 80kmph, and wane out after 100 kmph.
The car also normally tends to steer to the left on an even road (irrespective of the speed).
The Car has got new suspensions - all 4, & left tyre rod end replaced, during the last service, around 3000km back.
Thought the wobble might be coz of the old tyres nearing their life.
Have got new Alloys + tyres 1.5 weeks back; got them twice rechecked for wheel alignment & balancing.
Still the same wobble! Even the co-driver can feel the car wobble/ vibrations in his legs resting on the car floor.
Would request your advise on this mysterious issue with my car.
Am stuck with this problem now and cant enjoy my new wheels.
Please help!!
Monaro CV8 is offline   Reply With Quote
Old 13th March 2010, 01:26   #47
Raccoon's Avatar
Thanked: 105 Times
^^^Whether the tyres look fine or pretty or grotesque, they should be rotated after 5 k km!
Old 13th March 2010, 08:16   #48
p$p
The problem could be associated with linkage, suspension, wheel bearings etc.
p$p is offline   Reply With Quote
Old 15th March 2010, 14:03   #49
Thanked: 420 Times
Default Alignment blues
One malpractice I have seen while getting wheel aligned (at a prominent center in Trivandrum):-
What the mechanic is supposed to do:
1. Check alignment.
2. Unlock the alignment locks
3. Correct the wheel alignment
4. Lock the alignment locks (while the alignment is still correct)
5. Take a print out of the result.
What the mechanic actually does:
1. Check alignment.
4. Take a print out of the result before Locking the Alignment locks back in.
5. Lock the alignment locks (The alignment would have changed by this time, but the print out shows 'correct' alignment)
This makes the job easier and faster for the mechanic, but I feel the customer is taken for a ride.
jinojohnt is offline   Reply With Quote
Old 17th March 2010, 00:41   #50
Raccoon's Avatar
Thanked: 105 Times
^^^Very interesting. So its possible to take a print out with this short cut method?
My alignment was done after changing the rear bearings but the wheels still feel slightly out of alignment. It was done at Millenium. Dunno if it was done this way. But they didn't give me a print out anyway, as they said the printer is currently not working. I intend to take it back to them.
Old 17th March 2010, 01:13   #51
Nikhilb2008's Avatar
Thanked: 6,491 Times
Please help!!
Wobble can be due to bad balancing or worn out tyres. I cant say anything with certainty without looking at the tyres.
The car steering to the left can be due to an alignment issue or again, uneven tyre wear.
+1!!
1. Check alignment.
1. Check alignment.
Actually, it doesnt make the job easier for the technician. Some people do it out of ignorance. Nothing else. But yes, as you said, technically it is wrong. They should hit the PRINT button only after tightening the bolts.
When you say the wheels feel slightly out of alignment, what exactly do you mean?
Nikhilb2008 is online now   Reply With Quote
Old 17th March 2010, 01:35   #52
Raccoon's Avatar
Thanked: 105 Times
Well, the most obvious observation that the car pulls slightly to the left when you drive with the hands off the steering.
Also, I somehow "feel" that its not done right, while driving.
The misalignment is possibly only slight... but its there!
Strange thing is I was present when the job was done. They have some kind of machine that detects the alignment optically. Possibly Infra-red. And the screen has four rectangular areas (for each wheel) which change colour from red to green when the alignment was within tolerance. The mech can see this while under the car, making it easy for him. So I did see that they were all green when he finished the job. But then why isn't the job done right? Possibly the machine has a calibration error?
Old 17th March 2010, 02:05   #53
Well, maybe it's a slight uneven wear on the tyres?
Old 17th March 2010, 06:30   #54
arjunrudra's Avatar
Thanked: 13 Times
Guys have a doubt.
I'm getting a new swift and on the same day of delivery ,I'm changing the stock tires for Michelin xm+ tires.
The profile I'm going for is the 185/70R14.
I'm going to have them on the same steel rims.
Few questions I have :
1) Since im changing the tyres and upsizing on the same day of delivery should a balancing and wheel alignment be done again ?
if so will I be charged extra for the above, or will it be included in the costs of the tires?
2) Costs : he said he will take my spanking new stock tyre for 1700 rs and the new michelin costs 3850 for my profile . so toal cost will be (3850-1700)x5= 10,750. Is this a good deal ?
3) Do the mileage tires really increase the mileage a little ? and my will overall consumption increase because of upsizing ?
4) I drive everyday on the highway . how are the grip levels and the tyre in general on the highway ?
5) what are the advantages of filling nitrogen in the tires ?
Can you please advise me on the above.
arjunrudra is offline   Reply With Quote
Old 17th March 2010, 10:17   #55
Arjun,
1). Alignment is not required. Balancing is a must. He may or may not charge for that.
2). It's reasonable and fair.
3). Wont make any difference.
4). It's good.
5). Please check the nitrogen inflation thread.
Also, if you have specific tyre queries, please post it on the relevant Swift tyre thread.
Old 17th March 2010, 10:53   #56
Perakath's Avatar
Thanked: 28 Times
Originally Posted by rjalihal View Post
Hello all,
I am not sure if this is an alignment issue but is a major concern to me. Ever since I got my Zen from service i hear a sort of 'rat-at-at-at-at-at' sound every time I make a hard right, like a U-turn for instance. This happens only when I am turning right. Left is perfect.
Thanks,
Rohan
Sounds like a problem with your left CV joint. Search the forum for threads on those. Also see here.
Perakath is offline   (1) Thanks Reply With Quote
Old 17th March 2010, 17:57   #57
Monaro CV8's Avatar
Thanked: 464 Times
Post
[quote=Nikhilb2008;1786461]Wobble can be due to bad balancing or worn out tyres. I cant say anything with certainty without looking at the tyres.
Dear Nikhil,
Like I said in my post before, I've got brand new tyres, and still the wobble..
Have balanced and aligned the wheels twice.
No effect.
Got any ideas, what should I look for under the car..?
THnx in advance.
Old 17th March 2010, 18:20   #58
Get it checked at a different place.
Old 19th March 2010, 01:10   #59
Raccoon's Avatar
Thanked: 105 Times
No such wear is visible to the eye, at least. Anyway, these are fairly new Yokos. Not used much since they were installed.
Guess I better take it back to get the alignment checked again. Just not finding any time for the long drive...
Old 26th March 2010, 10:11   #60
I am taking delivery of my ANHC next week. I have asked the dealer to swap the current set of wheels with Michelin tyres before delivery, which he has agreed to. My question is do I need to get wheel balancing / wheel alignment done if all the 4 tyres have been replaced ?
Manumani
manumani is offline   Reply With Quote
Wheel alignment or wheel balancing?? leodelg Tyre & Alloy wheel Section 27 22nd June 2011 00:44
Breakdown Assistance for 1 year, Wheel Alignment & Wheel Balancing just for Rs 199 Mitsun Soni The Indian Car Scene 11 8th March 2011 11:02
Newbie questions - wheel balancing, wheel alignment. johy Technical Stuff 8 6th December 2006 10:39
