Old 8th July 2008, 15:35   #31
iraghava's Avatar
Thanked: 156 Times
Rush/Gaurav - These are the tread options available off the shelf:
Michelin LTX A/T
BFGoodrich
Both these are available in 31x10.5
While the Yokohama Geolandar is also available in 30x9.50
Old 9th July 2008, 12:12   #32
Thanked: 103,670 Times
Thanks Iraghava! I am currently running the Michelin A/T's on my Classic, albeit in a 225 patch. I am very happy with the rubber. If its available in 31x10.5, that would probably be my choice.
This size is not all that expensive, is it? I think I paid about 5 grand (would need to confirm) to Saifee for the Michelins in '03.
Old 1st May 2010, 13:48   #33
ZTE
ZTE's Avatar
3. The Classic originally came with wire wheels (attachment 1), but Mahindra replaced them with a smart 5 spoke design later (attachment 2). They are pretty robust wheels, and have been tested by Mahindra in offroading applications. Do you want to try sourcing these. Alternatively, have you seen the three spokes on mine? They'd be easier to find.
Hi GTO,
I have recently bought a classic two days back in baroda after searching for more than 2 years.I m looking for an extra alloy wheel 5 Spoke which you are mentioning as I got only 4 of them with this classic. I have tried searching here in scrap market but didnt found any.
If you can tell me any source of getting those, It would be great.
I have been silently reading your post on your mahindra classic and the modification you have performed on it but since I didnt had any jeep , I didn't wrote anything. But now when I have finally got one ,I have plenty of enquiries which I will post as I work on the classic gradually.
Brij
ZTE is offline   Reply With Quote
Old 31st March 2017, 15:11   #34
kcj3b's Avatar
Thanked: 56 Times
Default Re: Help on Rim & Tyre change on Mahindra Classic
Salikt,
Apologies for the late reply. I went through a similar situation when choosing an upsize for my Mahindra Classic (You can read more about her in the long term reviews section).
After a lot of trial and error, I found that the best fit is 225/70/15 rubber. I experimented with 235 and an 80 profile, but both were touching the chassis on full lock.
Check out Michelin all terrains. I am extremely happy with them.
EDIT: 235/75 R15 is the best tyre size for the CJ340 / Classic.
On a Mahindra Classic, Can we not use the Army style 16inch RIM with 7.50X16 sand & Highway/ Bullet Tyres?
One of my friend has them on a CJ3b and they look really wow.
kcj3b is offline   Reply With Quote
Need Suggestions - Bigger Rim & New tyre on new RE Electra zcanji Motorbikes 7 19th June 2009 16:15
Help:Tyre and Rim upgrade for OHC 1.5 adnan Tyre & Alloy wheel Section 9 3rd April 2007 18:40
Rim and tyre change for Matiz.. Su-47 Tyre & Alloy wheel Section 19 2nd November 2006 12:00
HELP!!: Hit a Stone/cement block cracked a RIM & busted a tyre aZa Tyre & Alloy wheel Section 11 15th October 2006 12:24
