Old 2nd January 2012, 15:49   #136
rxpaul's Avatar
Thanked: 103 Times
Default re: Ford Figo : Tyre & wheel upgrade thread
Is the XM1+ 185/65 R14 not available in Chennai ? My Nephew wanted to fit them on his new Figo, which he is taking today !! Dealer says he needs to wait for 15 days for this size.
rxpaul is offline   Reply With Quote
Old 2nd January 2012, 18:29   #137
Nikhilb2008's Avatar
Thanked: 6,469 Times
Yes. There is a supply problem with 185/65-14 XM1+s.
Old 3rd January 2012, 10:33   #138
Thanked: 16 Times
XM1+ makes the steering very light at slow speeds. I use 195/60-14 XM1+ and steering has become too light than I would like, at slow speeds. I strongly suggest Bridgestone Potenza GIIIs in 185/65-14 which has better ride quality than XM1+.
Prass is offline   Reply With Quote
Old 3rd January 2012, 11:12   #139
rxpaul's Avatar
Thanked: 103 Times
Prass,
But the Potenza G III is unidirectional, so tyre interchanging is gonna be difficult ! And yes he has managed to source XM1+ in 185/65 size and will be fitting them today. Also as he is going for a higher aspect ratio 65 i feel the ride will be better. I recently fitted the BS ER 60 205/65 R15 on my Octavia and am thrilled, but sadly ER 60's don't come in 185/65 R14
Old 3rd January 2012, 11:20   #140
Thanked: 16 Times
Prass,
But the Potenza G III is unidirectional, so tyre interchanging is gonna be difficult ! And yes he has managed to source XM1+ in 185/65 size.
If the OEM spare tyre is retained, tyre rotation is not going to be an issue in Unidirectional tyres. The tyres can be swapped on the same side between front and rear. The spare tyre can be put on any side during emergencies.
Old 3rd January 2012, 11:36   #141
rxpaul's Avatar
Thanked: 103 Times
Prass,
Correct, but he plans to change the spare too, as the original spare is 175/65 and he is getting a good deal swapping all five wheels to alloys too.
Old 3rd January 2012, 12:04   #142
Thanked: 16 Times
Prass,
Nice! if possible, pls post his driving impression with the new tyres.
Prass is offline   (1) Thanks Reply With Quote
Old 5th January 2012, 11:12   #143
rxpaul's Avatar
Thanked: 103 Times
Some kind of brown powder was seen on the wheel hubs in my Nephew's new Figo when he changed over to alloys. Can someone identify ?...video att. Also will post a review after 1000 km
Old 9th January 2012, 09:19   #144
rxpaul's Avatar
Thanked: 103 Times
sorry here is a pic of the Figo alloy with the brown powder. What could this be ??
Old 9th January 2012, 14:18   #145
It seems to be rust. Nothing to worry about. Rust is quite common in those parts.
Old 15th January 2012, 18:12   #146
gemithomas's Avatar
Thanked: 138 Times
I had to settle for 175/65 size since i found it quite hard to procure 185/65. Have done 14K km on the new xm1+. Love them for the comfort and road hugging nature. But they tend to screech much more often than my earlier accellere. Not that i loose grip but the screeching sound is heard more often.
I now have an option to get 15 inch alloys. Should i get them and go for 195/55's???
Also what price can i expect for a 14K done Xm1+
Old 15th January 2012, 20:38   #147
KiloAlpha's Avatar
Thanked: 1,583 Times
I would say go for it! Definitely worth it, if you get the right tyre ...
KiloAlpha is online now   Reply With Quote
Old 15th January 2012, 20:44   #148
kpzen's Avatar
Thanked: 1,647 Times
What tire pressure are you maintaining ?
You would hardly get anything for your 14k done XM1
Old 15th January 2012, 20:56   #149
rxpaul's Avatar
Thanked: 103 Times
Hi...i don't think 195/55 is a practical option for the Figo. You car will look good, but such a low aspect of 55 may not be Ok for Trivandrum narrow roads where you often have to drop the offside tyres off the tarred roads.
Pl. also check if you will be further lowering GClearance with 195/55.
Also refer to expert Nikhil's post 127 in this very thread.
Old 16th January 2012, 00:23   #150
KiloAlpha's Avatar
Lets put some numbers on the table, and let them do the talking. You interpret these numbers according to your situation.
175/65R14 (stock)
Rolling Radius = 291.55mm
sidewall height = 113.75mm
195/55R15 (upsize)
Rolling Radius = 297.75mm (+6.2mm, +2.08% when compared to stock)
sidewall height = 107.25mm (-6.5mm when compared to stock)
Ford Ecosport : Tyre & wheel upgrade thread dish Tyre & Alloy wheel Section 239 27th May 2018 05:32
Ford Fiesta : Tyre & wheel upgrade thread anarchy_99 Tyre & Alloy wheel Section 434 19th May 2018 20:01
Ford Figo / Aspire : Tyre & Wheel Upgrade Thread arunphilip Tyre & Alloy wheel Section 168 17th April 2018 17:01
Ford Ikon : Tyre & wheel upgrade thread dkhatau Tyre & Alloy wheel Section 28 22nd February 2016 10:28
