Old 26th July 2014, 18:58   #346
Thanked: 179 Times
Default re: Ford Figo : Tyre & wheel upgrade thread
I own a Figo and was going through this thread..I have the same dilemma as many others here as to non availability of good 108PCD wheels/tires. I am attaching here a Figo done by Pete's of Kerala which is on another thread on T-bhp. Have not seen a better wheel/tire combo on the Figo. The wheels are Borbets i guess, very expensive but stunners nevertheless.
Ford Figo : Tyre & wheel upgrade thread-red-figo-2.jpg
Ford Figo : Tyre & wheel upgrade thread-redfigo-1.jpg
car love is offline   Reply With Quote
Old 15th August 2014, 02:01   #347
fazalmirza's Avatar
Thanked: 9 Times
Originally Posted by gemithomas View Post
How would 185/70 fare on a Figo? Anyone with that upsize?
Ford Figo TDCi
185/70 R14 Goodyear:
34 months, 86000+ kms. These are my second set of this tire size setup.
Brilliant ride and superb ground clearance.
We, in Kanpur consider ground clearance on par or often at a greater level than fuel efficiency. Rides like a Cross-Figo if there was one
At the time of purchase, I had immediately chosen this tire setup on a friend's advise. He was using the same for his i20. By the way, he owns a renowned tire shop so wasn't a lay man. Hope this answers your curiosity.
fazalmirza is offline   Reply With Quote
Old 16th August 2014, 06:55   #348
batterylow's Avatar
Thanked: 677 Times
With the 185/70 the difference from the stock tire (175/65) is more than 5 percentage.
So you are going much faster than your speedometer indicates.
Do your tires touch the body when the car is fully loaded or on turns?
BTW, I am running on 65 profile on the 185's and they seem adequate to overcome the Figo's low GC.
BL
batterylow is offline   Reply With Quote
Old 23rd August 2014, 12:43   #349
ramharis's Avatar
Thanked: 50 Times
Recently did the tyre upgrade for my Figo from MRF 175/65 R14 ZV2K to Conti EcoContact 3 185/65 R14 (Rs 4600/Tyre at XL Tyre Point AnnaNagar, Chennai).
Initial Impression:
Ride quality has improved a little bit
The mud flaps which often scrap the speedbreakers in my office has reduced considerably.
The Steering feels a little light than before.
Braking has improved a tiny bit.
The car seems to accelerate a bit faster, due to low rolling resistance
Grip level increased a little. Need to test the tyre on mountain roads/Highway to find out the grip levels.
The Downside is, the car seems to jump on bad/bumpy roads, which reduced the confidence level in the car, i guess with some more miles i should get used to it.
And the road noise has increased by some too.
Ford Figo : Tyre & wheel upgrade thread-wp_20140816_13_55_10_pro.jpg
Ford Figo : Tyre & wheel upgrade thread-wp_20140816_13_56_08_pro.jpg
Ford Figo : Tyre & wheel upgrade thread-wp_20140816_13_56_20_pro.jpg
Ford Figo : Tyre & wheel upgrade thread-wp_20140816_13_56_31_pro.jpg
ramharis is offline   Reply With Quote
Old 23rd August 2014, 15:22   #350
batterylow's Avatar
Thanked: 677 Times
You might want to get your air pressure checked, just in case.
Old 25th August 2014, 15:21   #351
ramharis's Avatar
Thanked: 50 Times
I did check the tyre pressure, have 32psi all around (nitrogen). Had a chance to try out wet grip yesterday (heavy rainfall in Chennai last night), the tyres were gripy compared to MRF's.
Old 25th August 2014, 15:55   #352
Thanked: 172 Times
Got HRS wheels installed on my figo. 195/65 14 continental rubber
Ford Figo : Tyre & wheel upgrade thread-1408962217879.jpg
Ford Figo : Tyre & wheel upgrade thread-1408962250926.jpg
desideep is offline   Reply With Quote
Old 25th August 2014, 16:53   #353
tharian's Avatar
Thanked: 2,787 Times
I would suggest 34psi all around.
I have been running the same size CEC3's on my Figo since the last 32000 kms.
Except for the more than normal amount of punctures, I have no complaints. The tyre noise will increase after around 20k kms. I ran with the stock MRF's for just 1000 kms, so can't compare except that I know the ride softened quite a bit and since the contact patch was more than the stock, sharp turns were taken with no slipping or sliding.
Wet roads are were Conti's excel. It is extremely stable on very wet roads and is perfect for a Figo in those conditions. Dry weather grip may not be as good as other tires of the same size.
Overall they are good except that you need to avoid stones and sharp stuff on the road. Till date I have had around 6-7 punctures which included a valve failure and a sidewall puncture. The sidewall puncture tire could not be used again and I bought a new tire of the same type and make. The valve failure was my mistake, ran under-flated .
tharian is offline   Reply With Quote
Old 28th September 2014, 10:01   #354
My Figo Titanium Tdi ran 55600 kms on 3 years 2 months on stock steel rims and tyres (MRF). One of the tyres is badly damaged and the rim also bent beyond repair. The tread of the other tyres have worn out. It is ,time for replacement. I request suggestions from my fellow Figoins on the following.
1. Should l go for upsize and if yes what size.
2. What brand- I have shortlisted Michelin and Yokohama.
3. Should I change to alloys? And if yes what brand.
I intend to keep this vehicle for another 2 years.
please share your valuable suggestions.
envyravi is offline   Reply With Quote
Old 5th October 2014, 06:41   #355
nishantbhatia84's Avatar
Thanked: 259 Times
-- Stick to 14in rims with 185 section tyres.
-- Yokos have proven to be good, Michelin is good too but they're softer imo.
-- If you have the budget then try to source ford oem alloys available with the current gen Figo, they look really cool for stock alloys!
nishantbhatia84 is offline   Reply With Quote
Old 5th October 2014, 12:27   #356
Thanked: 132 Times
envyravi,
1. I believe you should certainly upsize. The Figo rides a lot better and benefits from the increased Ground Clearance. I got 195/70R14 mounted on a friends Figo and the car has been running for over 3 years and worn out a complete set with no complaints.
2. Both are good, for a good quality vs. price point, I got Yokohama A Drives.
3. You could, but they will not fetch you much value when you sell the car. Besides, people spend lots of money for a very small change in size. If you do intend to go in for alloys, I would suggest directly going to 7x16" with 195/55R16 tyres. You could put a sticker on your call calling it the King of Figoland or something with that! But honestly, I would not spend the money.
bharatsomany is offline   Reply With Quote
Old 5th October 2014, 12:40   #357
Thank you bharatsomany. I upsized to 185/65 Michelin XM2 tyres for Rs 19900 inclusive of fitting, wheel balancing and alignment. The ride is now smoother and the upsize added to the GC and I am now able to go over speed breakers more confidently. I agree with you regarding alloys and decided to continue with the old steel rims.
Old 17th October 2014, 19:06   #358
keshav1426's Avatar
Thanked: 19 Times
Guys, My figo tdci has run 34,000 Kms and needs a tyre change, currently running on MRF and there is uneven wear . I have shortlisted Bridgestone B290 and Yokohama Earth-1 of stock size ( 175/65 R14). Please let me know which might be better for the figo. I am looking at low noise , better handling and I dont want brands with soft sidewalls. Prefer to keep the new tyres for the next 30-40,000 kms
So let me know your views on this.
Keshav
keshav1426 is offline   Reply With Quote
Old 22nd October 2014, 19:59   #359
shifu's Avatar
Thanked: 353 Times
Originally Posted by vineet@bulbule View Post
You are a life saver!!! I just found out and one of the dealers is quoting 4050/- with free fitting and the free vaccum cleaner. Do you think its a good deal?
Hi Vineet - Just wanted to get your feedback on the tyres and the dealer you bought it from (in Hyd?). I wanted to go for MRF ZLO, but looks like that is not available in Figo's stock size (175 65 R14). Earth 1 is the next best choice and I am looking forward to your review. Thanks!
shifu is offline   Reply With Quote
Old 22nd October 2014, 20:38   #360
satan's_valet's Avatar
Thanked: 173 Times
Keshav
Keshav, Go with Yoko Earth1. I've had them for 10k kms now, and have absolutely no issues with them. Just one thing, do upsize to 185/65. The ride will be lot better and the increased ground clearance won't hurt as well.
satan's_valet is offline   (1) Thanks Reply With Quote
Ford Figo / Aspire : Tyre & Wheel Upgrade Thread arunphilip Tyre & Alloy wheel Section 151 12th January 2018 09:17
Ford Ecosport : Tyre & wheel upgrade thread dish Tyre & Alloy wheel Section 229 4th January 2018 00:39
Ford Fiesta : Tyre & wheel upgrade thread anarchy_99 Tyre & Alloy wheel Section 430 23rd October 2017 17:41
Ford Ikon : Tyre & wheel upgrade thread dkhatau Tyre & Alloy wheel Section 28 22nd February 2016 10:28
