Old 1st May 2010, 16:23   #16
Saarth's Avatar
Thanked: 202 Times
What is the stock tire profile on the WagonR?
Saarth is offline   Reply With Quote
Old 1st May 2010, 16:35   #17
aargee's Avatar
Thanked: 2,142 Times
Originally Posted by Wind splitter View Post
Just got know that with 2 people sitting in the back and at a decent speed (80+), rear tires touches the body as well.
Boy, mine with 3 adults in the rear & on a bad road gives the scrapping sound & I run on stocks. This is one thing that I do not like in WagonR. But for 4 people, the car rocks.
Old 2nd May 2010, 13:03   #18
thelightening's Avatar
For WagonR VXI its 155/65 R13
thelightening is offline   Reply With Quote
Old 3rd May 2010, 10:58   #19
Vik0728's Avatar
Thanked: 2,291 Times
Guys, sorry on the delay for response, was really busy over the weekend!!
Now, coming to Spacers, I was referring to Tyre spacers and not the suspension spacers.
I have a 15" Alloy on my Santro with a 195/45 profile rubber. To be very frank, once of my friend has a 15" alloy on his santro with a 185/55 profile rubber without any Spacers !!
The reason I went in for Spacers (only for the front wheels) is just to be Safe than Sorry!!
As far as my Knowledge & Experience goes, Hyundai cars have a very limited After market Mods possiblity. But Suzuki cars have much more. The point is that for a Wagon R, if ride quality is not a big deal, one can possibly install 15" without any spacers.
Vik0728 is online now   Reply With Quote
Old 3rd May 2010, 11:01   #20
aargee's Avatar
And for LXi it is 155/70 R13
Old 4th May 2010, 13:19   #21
Wind splitter's Avatar
Sorry for the delayed post, stock tires where 145/70/R13. I think we need suspension spacers for rear end of Wagon R.
I had a same problem with my M800 when I installed 165/60/R12, rear mudgaurd started scrapping the outer wall of rear tires. I got a extra leaf added to stock leaf spring suspension which fixed the issue but ride quality is bumpy without the full load, with 4 or 5 people sitting in the car ride quality improves and tires do not touch the body as well.
Wind splitter is offline   Reply With Quote
Old 4th May 2010, 17:33   #22
vikram_d's Avatar
Thanked: 940 Times
So that means you ned both suspension as well as wheel spacers on your car for all the four sides. This one is going to tricky. Suspension spacers will definitely cause handling issues. Wheel spacers will push the wheels outside the body line but should not cause any handling problems
Old 5th May 2010, 10:49   #23
Ya need both suspension as well as wheel spacers, but first will just try with suspension spacers and if things get better will leave it as it is.
Question is if we need to opt for rubber spacers or metal spacers? need some inputs on this.
Old 5th May 2010, 11:29   #24
Rather than going ahead with spacers and suspension mods, I would like to advice to sell or exchange the 175/60/R13 and buy 156/60/R13 or 155/65/R13.
Old 5th May 2010, 11:51   #25
kpzen's Avatar
Thanked: 1,655 Times
If the outer side of the tire is touching the wheel i would first suggest u to slightly modify the wheel well to accommodate the tires rather than going in for the spacers right away.
Its a easy DIY, all u need is a Jig and hammer as shown below.
Note : Do not hammer the wheel well directly from inside it will result in dent marks on the outside.
Wagon R tire upgrade, inner tire wall touching suspension-jig-wheel-well-mod.jpg
Old 5th May 2010, 19:46   #26
prguru's Avatar
Thanked: 19 Times
Hey Windy why don't you try and exchange the rubbers to say 165/60 R13 if you have that option ? Otherwise you will have to go for spacers.
Can any bhpians tell me are rubber spacers better or the metal ones ? can any of you post a picture of a metal spacer ?
prguru is offline   Reply With Quote
Old 5th May 2010, 20:15   #27
rjstyles69's Avatar
Thanked: 795 Times
Rubber tends to wear out over time. Makes sense to go with the metal spacers, however be ready to compromise on the handling.
Metal spacer looks something like this in the below image. The aluminum part
Name:  Metal spacer.jpg
Rubber spacer
Name:  rubber spacer.jpg
and mind you these are suspension spacers.
Old 5th May 2010, 21:40   #28
vikram_d's Avatar
Thanked: 940 Times
I agree with the above. Get proper size tyres rather than playing around with spacers. The suspension spacers will extend the shock absorber out of its optimum travel range. I have tried then on my previous car and the handling was absolutely horrid. Finally had to get longer struts to correct the problem. But even that did not do much. So instead of spending money on stuff that will spoil the handling. I would recommend that you get correct sized tyres.
Old 6th May 2010, 10:19   #29
speedsatya's Avatar
Thanked: 712 Times
Spacers will spoil the handling ! Change the tires and go for 165/60r13 .
speedsatya is offline   Reply With Quote
Old 10th May 2010, 14:47   #30
Can we try replacing the coil springs of old wagonR with coil spring of new wagonR which can accomodate 14inch wheels, could any one please throw some light on this.
Static Electricity Discharge / Shock when touching front door ramkya1 Technical Stuff 158 17th March 2017 13:38
Esteem - Tyres touching after upgrade joeblack Tyre & Alloy wheel Section 23 16th October 2013 17:48
Toyota Innova 2.5 EDIT - Now touching a Lakh kms raj_5004 Long-Term Ownership Reviews 90 17th August 2013 19:47
Touching the Heart of India abbey4u Travelogues 4 15th July 2008 21:41
Touching Ferrari DINO story! Stratos The International Automotive Scene 7 28th May 2004 11:27
