Old 30th April 2010, 10:28   #1
Wind splitter's Avatar
Default Wagon R tire upgrade, inner tire wall touching suspension
Guys, one of my friend got Yoko 175/60/R13 with Accelere alloys, ride is good except that the front tire inner walls (both right and left tire's)are touching the suspension, what could be done to fix/avoid this?
Will post pics as soon as get them.
Wind splitter is offline   Reply With Quote
Old 30th April 2010, 10:42   #2
Vik0728's Avatar
Thanked: 2,308 Times
Hey Wind Splitter I have a 15" 195/45 running on my Santro and its rollin' perfectly fine !!
The Reason, I have Alluminium Spacers in the front. May be You should try these or atleast advice your friend on the same.
But please do await responses from all the experts on this forum before you make the decision.
Vik0728 is offline   Reply With Quote
Old 30th April 2010, 13:41   #3
aargee's Avatar
Thanked: 2,143 Times
Add spacers & all will be fine
Old 30th April 2010, 13:51   #4
thelightening's Avatar
165/60 is the perfect upgrade, else 155/65, which comes on WagonR VXI. Now you need to look for spacers.
thelightening is offline   Reply With Quote
Old 30th April 2010, 14:04   #5
ImranShahnawaz's Avatar
Adding spacers will solve the problem but I guess driving quality will go down.
ImranShahnawaz is offline   Reply With Quote
Old 30th April 2010, 15:02   #6
ElantraGT's Avatar
You are absolutely right, Santro is already a tall boy design. Adding spacers will affect the handling a bit.
If the tires are hitting the side walls then will adding spacers will solve the issue? If i am not wrong spacers incerase the vertical height. In this case the inner walls are rubbing the wheel arch.
ElantraGT is offline   Reply With Quote
Old 30th April 2010, 15:31   #7
vikram_d's Avatar
Thanked: 940 Times
They are talking about wheel spacers and not suspension spacers.
Old 30th April 2010, 16:44   #8
rjstyles69's Avatar
Thanked: 795 Times
Where have thy been ? BTW am sure he was talking about suspension spacers and not wheel spacers. See his post ..
Am sure he was hinting at the suspension spacers and not the wheel spacers. Coz with wheel spacers how does the driving quality go down ?
From what I have read here on this forum its only decreases the flex on a normal vehicle.
winsplitter please add a few pics.
Old 30th April 2010, 18:46   #9
ElantraGT's Avatar
My bad buddy. First I thought that they are talking about suspension spacers.
I also found that I mentioned the vehicle as Santro. Again this is a oversight on my part.
Thanks buddy. You are correct, I have seen a lot of threads talking about handling issues with suspension spacers and that caused this confusion. Now lets wait for some pic of the wheel.
Old 30th April 2010, 18:59   #10
aargee's Avatar
Whoa!!! Is there a spacers for suspension too? I'm not aware of this? Could someone point me some links on this as where & how it is added? Till date I'm aware only about wheel spacers as you upgrade the tires & you add spacers to wheels & how does suspension come to pic? Educate me
Old 30th April 2010, 19:05   #11
rjstyles69's Avatar
Thanked: 795 Times
Whoa!!! Is there a spacers for suspension too? I'm not aware of this? Could someone point me some links on this as where & how it is added? Educate me
You could check this thread here , a nice discussion.
Usually its made of rubber or aluminum and is added when you generally face wheel scraping issues in the wheel arches after a tyre upgrade.
Here's what it looks like
Old 30th April 2010, 19:35   #12
What a confusion . My mistake, I thought suspension spacers.
Old 30th April 2010, 19:49   #13
There is about one finger gap between the suspension rod and almost no gap between the coil spring, so when the suspension rocks and the tire moves up, at that point of time the inner wall touches the coil spring, so I think spacers should do the job, how ever I will post pics for better understanding.
Old 30th April 2010, 21:23   #14
aargee's Avatar
Thanks for the link & pics RJ; I'll check them out. Appreciate your help.
Old 1st May 2010, 15:29   #15
Just got know that with 2 people sitting in the back and at a decent speed (80+), rear tires touches the body as well.
Static Electricity Discharge / Shock when touching front door ramkya1 Technical Stuff 158 17th March 2017 13:38
Esteem - Tyres touching after upgrade joeblack Tyre & Alloy wheel Section 23 16th October 2013 17:48
Toyota Innova 2.5 EDIT - Now touching a Lakh kms raj_5004 Long-Term Ownership Reviews 90 17th August 2013 19:47
Touching the Heart of India abbey4u Travelogues 4 15th July 2008 21:41
Touching Ferrari DINO story! Stratos The International Automotive Scene 7 28th May 2004 11:27
