Old 10th December 2013, 21:35   #31
mints21's Avatar
Thanked: 1,271 Times
Default Re: Single tyre worn out - Replacement dilemma
Originally Posted by Car-riedAway View Post
The spare tyre is a JK tyre from the original set, condition is ok but would it make a difference running on a single different tyre from the rest.
Though, I am little late in responding to you, I think it should not make much difference if it is of a different make till such time it's specification matches with the other three . But your later post updates your decision, I would suggest go ahead with what you like and have miles and miles of happy and peaceful driving.
mints21 is offline   Reply With Quote
Old 10th December 2013, 23:16   #32
HillMan's Avatar
Thanked: 401 Times
Guys, an update- I am planning to go for both front tyres replacement with a suitable new tyre (branded, Indian probably) that do not pinch much on the pocket.
Why not replace the spare in front and get a new tyre for spare. Instead of buying two tyres. Unless you are an enthusiastic driver, it shouldn't rally matter. I am thinking your spare tyre is also worn out a bit. After a year you will have the opportunity change the rest.
HillMan is offline   Reply With Quote
Old 11th December 2013, 06:59   #33
Thanked: 24 Times
Thanks guys for yours inputs, I finally bought two apollo acceleres, same as rear two. The tyre dealer said that the fault was with the alignment that caused the wheels to erode. I asked him to check the camber he said its ok, have to believe him
Have planned a tight alignment schedule now - plan to get it done every 2.5-3k ( or every 1.5 months) for my specific case so that i am well in command if any aberrations do creep in in terms of camber or alignment. Though the dealers and experts herein say alignment can be scheduled for every 5k interval, i need to be extremely cautious, once bitten twice shy.
Plan to change all four next time, if all goes well (fingers crossed), to yoko c drives.
Car-riedAway is offline   Reply With Quote
Old 15th December 2013, 18:30   #34
humyum's Avatar
Thanked: 2,502 Times
Default Re: Single tyre change..Advisable or not?
Can you post the alignment reading reading print out the dealer must have given you after getting the alignment done for the readers here to know 'what' was actually out of spec in your alignment ?
humyum is offline   (1) Thanks Reply With Quote
Old 4th April 2015, 17:23   #35
Thanked: 285 Times
The original JK tyres on my Swift did 53000 kms and then I replaced with Goodyear. These tyres have done around 27000 kms. 3 of the tyres are still decent, but one has been damaged. I need to change it.
Should I buy a single new tyre or is it possible to get a decent used tyre to use till the time it's time to change the other 3? (I don't have a good spare).
I check a couple of tyres shops (need to check more), but they only had tyres which were 5-6 years old. I don't think it's a good idea to put something so old. But if get something 3-4 years old and in decent condition, I guess it should be OK, right? Are 3-4 year old used ones easily available? How much should I expect to pay? And is it OK if one tyre is a different brand (as long as size is same)?
carboy is online now   Reply With Quote
Old 4th April 2015, 21:23   #36
Mr.Boss's Avatar
Thanked: 2,539 Times
Best possible solution,
- dispose the damaged and spare tyre
- Move one of the other 3 as spare
- get a couple of brand new tyres and use them in Front
You can go for different brand keeping the same tyre spec, but the safe bet is to use the same brand.
Do you think risking on a safety critical part is worthy to save few bucks? I suggest not to look for anything older than 2 years.
Mr.Boss is offline   (1) Thanks Reply With Quote
Old 4th April 2015, 21:54   #37
zenren's Avatar
Thanked: 1,725 Times
Fully agree with buying 2 new and moving one of the 3 existing tires as spare. I did the same in my Zen long back when one of the tyres got sidewall damage. However, I've heard differing opinions regarding whether the new tyres should go to the front or rear. Argument for front as I understand is that the engine weight would wear out the tyres faster and hence putting new tyres in front can extend the life of the existing set.
Argument for putting them in the rear is that the new tyres would need a few hundred kilometers before the outer smooth texture wears off and the grip becomes good under braking. Hence it is recommended to put the new tyres in the rear till they run in completely.
Tyre experts, please comment on the best approach.
zenren is offline   Reply With Quote
Old 4th April 2015, 22:02   #38
toiingg's Avatar
Thanked: 85 Times
New tyres should always go at the back. Please search the forum, there are tons of threads explaining why.
toiingg is offline   Reply With Quote
Old 4th April 2015, 22:33   #39
Thanked: 285 Times
It's always a compromise. Otherwise the only car sold will be an Audi with a roll cage.
My other 3 tyres are 3 years old.
Anyway, getting back to my question.
I am trying to figure out if if it's OK if it's a different brand. If that's OK, then I guess 3-4 year old tyre with a similar wear would be fine enough.
How much should I expect to pay for a 3-4 year old tyre?
And I am not planning to replace my spare tyre - it's like 8 years old and hidden under my CNG tank. I don't use it and don't plan to use it even in I have a flat tyre. I'll get my car towed or whatever.
Old 4th April 2015, 22:44   #40
Mr.Boss's Avatar
Nothing wrong with different brands unless the spec remains same.
For a reference, we sold a set of 5 MRF, 2 years old, 10k+ covered tires from Ford classic for 1.25k per tire (a couple of years back) when we exchanged them for Yokohama (upsize)
PS: are you speaking about 3~4 years USED tires or old stock from dealer?
Mr.Boss is offline   Reply With Quote
Old 5th April 2015, 10:14   #41
Thanked: 285 Times
3-4 year old used tyres.
Old 5th April 2015, 13:52   #42
Mr.Boss's Avatar
Should cost you around 1.5k
Try sourcing from a reliable source. You know the history of other 3 tyres (3+ years old) in your car, but when getting a used tyre be it 3 years or 3 months old we aren't sure how bad they were used / abused.
single tyre change for petra shantyrocks Tyre & Alloy wheel Section 2 21st September 2008 22:43
Is it advisable to fit a Roll Cage for Maruti 800 model? vinfriend Modifications & Accessories 8 1st August 2007 22:34
Why it's advisable to have coloured helmets or stickers on helmets ? mithun Motorbikes 12 9th January 2007 16:51
Fiat Palio 1.2/1.6, Is LPG conversion advisable. Dhanan Hatchbacks 9 27th September 2006 18:09
Neon is it advisable kooldude Modifications & Accessories 37 3rd May 2005 14:47
