Old 6th December 2011, 16:11   #16
KiloAlpha's Avatar
Thanked: 1,596 Times
Default Re: Can I fit 15 inch wheels in Indica/Indigo?
Originally Posted by kumargandharva View Post
By MISTAKE, I got the Indigo's wheels upgraded to 175/65 R15!!!
What negatives would be there because of it?
Can I live with it now?
Are you saying you changed your stock wheels to 15" (stock wheels on the Indigo are 14") and then went on to change the tyres to 175/65 R15?
If so, I would suggest you change your tyres ASAP. The size difference between stock wheels/tyres, and the ones you have fitted right now, is well over the permitted 3% tolerance margin.
However, if the tyres you fitted are 175/65 R14, then the size is perfectly correct - it is the stock size.
KiloAlpha is offline   Reply With Quote
Old 25th September 2014, 16:16   #17
Ne0N's Avatar
Thanked: 26 Times
Default New rubber for my 2008 INDIGO LX
HI Guys
This is my first post since getting my membership approved
I have been revving around in my brothers 2008 Indigo LX (sedan) and need your help in replacing the tyres (tubeless) on the black beauty.
The car still has its original manufacture provided tyres and i am looking to change them in mumbai.
The issue is that i live in an area where the roads still havn't been laid with tar. And it doesn't seem like the BMC plan to tar the road within next couple of years either
So there's a lot of mudding around and hence need the rubber to handle some abuse. I am looking for your advice as to which brand should i go for. The car carries 3 people, at most 4 and does monthly
about 500 kms and occasional highway runs. I am looking to spend under 20Gs on them.
Also i will be waiting until December to do the changing and my spare tyre has almost given way/ there are cracks and the edges have hardened . is it possible to put a tube in the spare tyre and keep in case of emergency/ puncture
PS: Mods please move as you fell appropriate
Mod Note: Congrats on your new membership- please be sure to SEARCH the forums before starting a thread and ensure that you post in the correct section as well. Have moved your post to a relevant thread.
Last edited by noopster : 25th September 2014 at 19:15. Reason: Refer mod note inline
Ne0N is offline   Reply With Quote
Old 26th September 2014, 16:25   #18
Thanked: 103,378 Times
Default Re: New rubber for my 2008 INDIGO LX
If you're looking for rough & tough tyres on a budget, check out Apollo Acelere. I've tried them out on a couple of review cars and have been pleasantly surprised. They're no Michelin Pilot Sports, yet very decent for rubber from an Indian brand. Good grip.
GTO is offline   (1) Thanks Reply With Quote
Old 26th September 2014, 16:55   #19
Ne0N's Avatar
Thanked: 26 Times
Thanks a TON GTO, will check them out..
Honda Fit (Jazz in India) gets a fit-ting facelift sidindica The International Automotive Scene 16 17th August 2011 10:03
Are Indica NA speedos' calibrated for 14 inch wheels? Zappo Tyre & Alloy wheel Section 9 17th June 2010 09:40
13 inch versus 12 inch wheels for the ZEN raghuram.cg Technical Stuff 5 30th March 2006 08:10
can i fit 14 inch tyre on my ikon flair 175/70 r13 ravi Tyre & Alloy wheel Section 1 29th October 2004 10:33
