Old 15th November 2008, 13:49   #181
Thanked: 31 Times
Today I tested Alto with 145/80 R12 XM1+ with Plati Alloys and drive started from Mysore road Shell Bunk. Did Tank Full and then drove towards Kengeri then turn left to NICE expressway and reach till Bannergatta road end and take right U turn come back and proceed in NICE road untill Tumkur road end and then right U turn and back to Mysore road and fill in same Shell Petrol Bunk for really full tank.
80km consumed 4.17 ltr, we filled very slowly and shaked the car to make sure tank is full.
FE: 19.1kmpl , No use of AC.
Speeds: 60-70kmph and 10km real fast drive of 120+ upto 140kmph to test the tyres.
Speeds over 120kmph Car vibrates slightly, but still its much much better than stock tyres.
Excellant Braking ability with brilliant handling.
OT: Imagine Innova with Michellin MXV8 225/60 R15 tyre. Man I cant wait to buy Innova and upgrade the tyre to Michellin.
Possible -ve point about Michellin tyre: If not driven carefully I am sure tyre won't last long in indian condition. Its soft rubber make tyre mess (less life) for sure :( when we bump into sharp potholes with high speeds/full load.
Conclusion: If Michellin lasts around 30,000km its still very much worth Its Silent and gives real comfy ride.
Ravi.
ravibhat is offline   Reply With Quote
Old 15th November 2008, 18:54   #182
sai_ace's Avatar
Thanked: 185 Times
Originally Posted by amit_mechengg View Post
@ Ravi, i think u should go for 155 instead of 145.
if you keep the two tyres 155/65 R13 and 155/70 R12 you will hardly find any difference at all.
I second that.. My alto Vxi is running on 155/65 R3 Michelins XM1 and its brilliant... and in the wet its super... lots of confidence!
sai_ace is offline   Reply With Quote
Old 16th November 2008, 00:03   #183
amit_mechengg's Avatar
Thanked: 1,542 Times
i am enjoying every milimeter of drive with the michelins. i observed that on my office road when i used to accelerate till 70 and then pull off my leg from the accelerator my alto used to climb the slope and then come down to 40 before i used to brake at the signal.
now the same patch when i pull off my leg from the accelerator the car keeps moving at the same speed and i have to brake at speeds of 60. there is hardly any rolling resistance. ultra smooth , pin drop silence.
Old 16th November 2008, 09:15   #184
Thanked: 31 Times
Very much true, I never thought Michellins are so good! Hope they continue same quality and don't start manufacturing in India because I really feel once they put up plant here quality might come down :(
Ravi.
Old 17th November 2008, 21:46   #185
can someone tell me whats my speedo error as i have downgraded from 145/80 R12 to 155/70 R12 ?
can someone please tell me how to calculate it??
Old 17th November 2008, 22:06   #186
nitrous's Avatar
Thanked: 282 Times
Ravi.
A lot of their tyres sold here come from China.
Old 17th November 2008, 23:54   #187
mail4ajo's Avatar
Thanked: 222 Times
Use this to calculate speedo error:
Tire size calculator
mail4ajo is offline   Reply With Quote
Old 18th November 2008, 09:02   #188
akroy's Avatar
Thanked: 29 Times
Ravi, your car was vibrating at higher speeds not because of tyre but because of faulty alignment.
I did 140kmph from Dobbspet - Tumkur and didnt realize that i am going that fast (I was following Vaseem's SX4). Mainly tyre noise was same and handling at corners were always great.
The best part of MIchelins are on wet roads. It is as if you are driving on a dry roads. This is the biggest difference I saw from my Stock tyres to the present set.
Now coming the soft tyres and all. That will not make much difference as you are not doing rally or skidding every now and then. My tyres are done 22K kms now and it looks new. I am sure it should last more than 30K km. I do 5 wheel rotation, balancing, alignment every 5K km.
OT: Great that you finally drove your car yourself. hope you are enjoying.
Abhi
akroy is offline   Reply With Quote
Old 14th December 2008, 02:03   #189
Heman's Avatar
Default Exchanging tyres for Alto.
Hi All,
I am planning to buy an Alto. Was thinking of exchanging the stock tyres with tubeless tyres. The dealers quoted me 4000 for all the 5 tyres in exchange . After going through some of the threads, I saw that alloys can be purchased for 13k-15k with exchange of stock tyres.
So do you suggest to go for the change from stock to alloys right now. i.e at the time of delivery from some after market shop or stay with the stock tyres for a year and then change it to alloys?
Also if anyone can suggest me some good shops in Mumbai giving good options of Alles for Alto & WagonR(a friend of mine going for it)
Thanks.
Last edited by aah78 : 14th December 2008 at 02:41. Reason: Moved to existing thread.
Heman is offline   Reply With Quote
Old 14th December 2008, 12:26   #190
Thanked: 31 Times
My suggestion:
If you have budget get set of 5 Michellin XM1+ 145/80 R12(1900/- each tyre) and Alloys(2500/- each alloy). If you would like to buy Alloys later thats fine as well. Tyres can be fitted on alto steel RIMS.
You can find big differance in ride quality because stock tyres come on Alto are crap.
Ravi.
Old 16th December 2008, 00:45   #191
Heman's Avatar
My dealer quoted me Rs. 4000 for Bridgestone tyres in exchange. Can you suggest me the tyre size and the sub brand.
Old 16th December 2008, 09:03   #192
akroy's Avatar
Thanked: 29 Times
What is the size of the tyres? Tyre price depends on the size of the tyre for a particular brand.
For Alto in 12inches, 145/80R12 (stock) or 155/70R12 go with 12 inches rim.
In 13 inches, preferred upsize is 155/65R13 and 165/60R13.
And none of the above sizes cost Rs4000 as you mentioned. Bridgestone Potenza GIII cost about 3K on the 165/65R13 profile. Other profiles costs lesser in any brands.
Pls do further research and post your exact requirement.
Abhi
Old 16th December 2008, 10:19   #193
rohan_fonseca's Avatar
Abhi
I think he means he is paying an extra of 4000 for tubeless on all 5 tyres. That would be Rs 800 a tyre.
rohan_fonseca is offline   Reply With Quote
Old 3rd January 2009, 20:43   #194
Heman's Avatar
Yes, In exchange for the new stock tyres with the car, I need to pay extra 4000/- for the tubeless tyres.
The tyre is the stock tyre.
I need suggestion whether to go for 13" or 12".
Would going just for tubeless tyres now and then after a year going for alloys make sense or taking both the tyres & the alloys at the time of delivery itself?
Old 3rd January 2009, 23:40   #195
Would be advisable to get both together if there are no cash constraints.
Maruti Suzuki Swift : Tyre & wheel upgrade thread hemlock Tyre & Alloy wheel Section 2062 13th December 2017 17:22
Maruti Suzuki WagonR : Tyre & wheel upgrade thread iWonder Tyre & Alloy wheel Section 80 19th September 2017 09:34
Maruti Suzuki SX4 : Tyre & wheel upgrade thread loving_alaap Tyre & Alloy wheel Section 265 2nd July 2017 08:16
Maruti Suzuki Ritz : Tyre & wheel upgrade thread funda2max Tyre & Alloy wheel Section 384 3rd June 2017 20:36
Maruti Suzuki A-Star : Tyre & wheel upgrade thread JKBKS Tyre & Alloy wheel Section 57 20th December 2016 13:19
