Old 27th January 2009, 23:23   #196
JMaruru's Avatar
Thanked: 107 Times
Default Can i have (155/70 R12) on the rear and (145/80 R12) on the front ?
My alto LX(2001) has done 75K Kms. I have changed the front 2 tyres to MRF Zigma and MRF ZVTS (145/80 R12) in the past one year. Now i need to change the bridgestone stock tyres(145/80 R12) of the rear.
So my question here is, can i go in for (155/70 R12) for the rear 2 tyres ? Or should i stick with (145/80 R12) for the rear as my front tyres are of (145/80 R12) specs ? I am using stock rims.
I do 25+ Kms daily in the city and also frequent the dreaded b'lore - m'lore highway once in 2 months. I have seen on this thread, many are having good opinion on michelin XM1. So would like to know should i have to stick with ZVTS or can i go in for michelin ?
Please advise.
JMaruru is offline   Reply With Quote
Old 28th January 2009, 07:55   #197
akroy's Avatar
Thanked: 29 Times
Please advise.
I would never recommend that. Keep the same size for all 4 tyres.
Michelin is in a different league. Better to buy 5 tyres and fix it and try to sell the present tyres to get a fair deal.
If you dont want to do that, then better you buy tyres which are cheaper (ZVTS, JK etc) and change all to Michelin when you have enough funds to do it because investing 2 tyres of Michelin will not give you that pleasure as running with 4 tyres of Michelins.
Abhi
akroy is offline   Reply With Quote
Old 29th January 2009, 14:36   #198
Heman's Avatar
Got my tyre upgraded from the Stock MRF 145/80 R 12 to 145/70 R 13. Also put in Plati Alloys.
Heman is offline   Reply With Quote
Old 30th April 2009, 22:40   #199
pedrolourenco's Avatar
Thanked: 617 Times
If you are upgrading to 13", you will have to go for a lower profile tyre. The overall dia of the tyre will be the same. So how will it touch anywhere. If you put a wider tyre it may touch. But then even if you put a wider 12" tyre it may touch. So 12" or 13" is not an issue. A low profile 13" will give you better handling and not so much comfort. A 12" high profile will give you good comfort but bad handling. So choose between comfort and handling. Remember the overall dia of the tyre must remain the same in cas of either 12" or 13". I don't understand what all the confusion is about.
pedrolourenco is online now   Reply With Quote
Old 30th April 2009, 22:46   #200
karankapoor's Avatar
@pedro man you had replied to a question, which was asked almost 3 months back.
karankapoor is offline   Reply With Quote
Old 8th June 2009, 01:24   #201
thelord's Avatar
Default Michelin XM1 / Kumho Solus KH17 / ER 60 for Alto
Hi everyone,
I plan to upgrade the default tyres on my Alto to tubeless 165/65/R13.
After doing some reading in this forum, I was almost convinced to go for Michelin XM1 (no XM1+ in R13) but a dear friend of mine recommended Kumho tyres. Yes, dear readers, even I hadn't heard of the brand much, specially in the home car segment.
So I digged up some information and got in touch with the main distributor in Ludhiana who recommended the latest SOLUS KH17 range.
( kumhotire.com/tire/tire_detail.jsp?category_cd=002002002000000 )
The reviews look promising actually and the tyres are available for 2.1k a piece.
Any reviews on how these will fare on Indian roads compared to Michelin/BG ER 60?
I would be driving mostly in city (Chandigarh), so am looking for driving comfort and low noise basically.
Will try to post some pics of the tread pattern if possible.
thelord is offline   Reply With Quote
Old 8th June 2009, 09:59   #202
nishantgandhi's Avatar
Thanked: 151 Times
Originally Posted by thelord View Post
Hi everyone,
Buddy, XM1+ are available in 13 inch. I have 175-70/13 on my Getz.
nishantgandhi is offline   Reply With Quote
Old 8th June 2009, 12:20   #203
predatorwheelz's Avatar
Thanked: 1,122 Times
Default Choices, choices!
@thelord - First of all, its a bad decision preferring Kumho over an established brand like Michelin or Bridgestone. They hardly have an established after sales network in India. Besides, my friend's Elantra CRDI came with Kumhos as OEM. He's pretty unhappy regarding noise levels and wet road grip. So I think it makes much more sense to go for Bridgestone.
That size you're looking for (165/65 R13) will not come in Michelin XM1s. But its the default size for Indica V2s, so you're spoilt for choice otherwise. Why dont you try Yokohama A-Drives in 165/65R13s? I recently scrapped the OEM Goodyears on my Indica and replaced them with tubeless A-drives. Have been very happy with the noise levels and wet-weather performance of the tyre. Truly an allrounder.
Otherwise you can always go for Bridgestones in that size.
predatorwheelz is offline   Reply With Quote
Old 8th June 2009, 12:27   #204
thelord's Avatar
@nishantgandhi
Thanks for the info, I actually checked the Michelin India website and asked the authorized dealers here in Chandigarh. I'll have to check if XM1+ is available in the 165/65/R13 profile. Anyone here running XM1+ in this profile.
@predatorwheelz
Don't go for the upsize or Don't go for Kumho?
I've already decided on the upsize and will be doing the necessary adjustments so as not to damage the wheel archs.
Old 8th June 2009, 12:31   #205
Default Upsize!
@predatorwheelz
I meant dont go for Kumho! Upsize at all costs. It will give your car improved stability and performance, at the minor cost of fuel efficiency.
Old 9th June 2009, 09:40   #206
Thanked: 712 Times
@ Nishantgandhi: Michelin XM1+ is not available in two sizes in 13", namely 155/70R13 & 165/65R13. XM1 is available in these two sizes. Surprisingly, XM1+ is also available in 12" but not in these two sizes in 13".
@ thelord: Upsize looks fine but stay with a known brand/patterns like Michelin XM1/ Bridgestone Turanza/ Yokohama A-drives.
sukiwa is offline   Reply With Quote
Old 10th June 2009, 00:05   #207
thelord's Avatar
@sukiwa
You are right. No XM1+ in 165/65/R13 profile. Confirmed this with Michelin.
I visited a few dealers today and a lot of them are recommending Yokohama A-Drive. Priced around 2.4k, I guess I've finally made my choice.
Thanks for the recommendation guys!
Old 10th June 2009, 09:44   #208
Thanked: 66 Times
i have been using 165/60/12 potenzas on my alto lxi it has done 20,000km, no issues so far.
streetracer_919 is offline   Reply With Quote
Old 10th June 2009, 12:27   #209
amit_mechengg's Avatar
Thanked: 1,556 Times
deciding against the upsize went for michelins 155/65 R12. i am finding them very comfortable and the wet road grip and braking has improved to a large extent.
Reasons for not upsizing:
1. Tried 13" alloys. with 2 heavy people and going at 45 degrees on speed breaker the wheel scraped. tried 2-3 models still they scrapped.
2. not convinced with the spacer idea. the dynamics and handling change.
3. i believe that lowering the car handles well than increasing the height. so i dont believe the people who claim that the handling improved by increasing 1" i.e from 12" to 13" .
conclusion : Saved cost on tyres as well as alloys and got the desired performance
Old 10th June 2009, 12:32   #210
Technocrat's Avatar
Thanked: 2,589 Times
How much did they cost Amit?
Maruti Suzuki Swift : Tyre & wheel upgrade thread hemlock Tyre & Alloy wheel Section 2071 18th July 2018 18:23
Maruti Suzuki Ritz : Tyre & wheel upgrade thread funda2max Tyre & Alloy wheel Section 394 18th July 2018 15:45
Maruti Suzuki WagonR : Tyre & wheel upgrade thread iWonder Tyre & Alloy wheel Section 85 7th March 2018 23:56
Maruti Suzuki A-Star : Tyre & wheel upgrade thread JKBKS Tyre & Alloy wheel Section 63 30th January 2018 11:40
Maruti Suzuki SX4 : Tyre & wheel upgrade thread loving_alaap Tyre & Alloy wheel Section 265 2nd July 2017 08:16
