Old 10th June 2009, 12:41   #211
predatorwheelz's Avatar
Thanked: 1,122 Times
Originally Posted by amit_mechengg View Post
Reasons for not upsizing:
1. Tried 13" alloys. with 2 heavy people and going at 45 degrees on speed breaker the wheel scraped. tried 2-3 models still they scrapped.
3. i believe that lowering the car handles well than increasing the height. so i dont believe the people who claim that the handling improved by increasing 1" i.e from 12" to 13" .
@Amit_mechengg,
A little clarification. When one upsizes from 12" to 13", the handling improves because the profile of the tyre decreases. Typically a 12" tyre on an Alto will have a 80 profile, while 13" will have 65 or 60 profile. The lower profile means thinner sidewalls, hence lower sidewall flex at high speeds. This is why the handling improves.
Lowering the car will obviously improve handling, due to lowering of the Centre of Gravity. But it will lead to other problems, like scraping on a speed breaker when loaded.
Also, I dont understand how a shift to 13" wheels led the car to scrape a speedbreaker. What profile were you trying out?
@Thelord - You're welcome for taking my suggestion! (I'm shameless)
predatorwheelz is offline   Reply With Quote
Old 10th June 2009, 12:58   #212
breezydrive's Avatar
Thanked: 75 Times
deciding against the upsize went for michelins 155/65 R12
You have actually downsized your wheels
Tyre profile -- Wheel diameter (mm)
145/80R12 ( stock Alto) -- 536.8
155/65R13 ( preferred upgrade) -- 531.7
155/65R12 ( opted by you) -- 506.3
145/70R12 ( stock M-800) -- 507.8
So, your upgrade is even lesser in size than Maruti 800's stock size.
A gross error of 5.4%, be ready for suspension related problems after 5-10K km.
Now, people claiming improvement in handing by increasing the rim size compensate it by reducing the side profile for retaining the same overall diameter ( max. 2-3% variation).
So, it is upto you whether you believe it or not?
breezydrive is offline   Reply With Quote
Old 10th June 2009, 13:06   #213
Technocrat's Avatar
Thanked: 2,589 Times
How are you calculating the wheel Dia?
12 inch = 304.8 millimeter
145/80 = 80% of 145 = 116mm
Am I missing something?
Old 10th June 2009, 15:06   #214
amit_mechengg's Avatar
Thanked: 1,556 Times
Originally Posted by predatorwheelz View Post
@Amit_mechengg,
yes i had the tyre flex in mind. but the thing is 13" plus the spacer = raised height equation didnt go for me. also the dealer didnt recommend.
the car doesnt scrape the speedbreaker. the tyres scrap the wheel arc.
opps sorry my mistake its 155/70 R12. ---- 521.71
for an alto you have to compensate a more than just the side wall thickness. there is a height difference of just 8 mm on the side wall between 155/70 R12 and 155/65 R13.
And if you add spacers to them and increase the height of your ride it will lead to stability problems.
yes one should believe when they try both the configurations on their altos. so that you can believe what you experience. some hard suspension altos dont scrape while some with soft scrap i.e the tyres scrap the wheel arcs.
Old 10th June 2009, 16:19   #215
Technocrat's Avatar
Oops I now got it what I was missing
Old 10th June 2009, 23:02   #216
The Bridgestone India website offers the following sizes as optional sizes for the Alto:
S322 155/65R13 73S Tube Type
GIII 165/60R12 71H Tubeless
GIII 175/60R13 77H Tubeless
For optional sizes, it is advised to check the tyres for body touching after fitment or any other problem.
You may check their website for details:
Indian Tyres, Tyre market, Global Tyre companies
jathin is offline   Reply With Quote
Old 17th October 2009, 13:46   #217
AnonymousCoward's Avatar
Hi folks,
While upgrading the tyre size of Alto from 145/80/12 to 155/65/13, as the RR (rotating radius) decreases (from 268.4mm to 265.85mm), will this result in reduction of GC (ground clearance)?
Thanks!
AnonymousCoward is offline   Reply With Quote
Old 18th October 2009, 19:24   #218
Originally Posted by AnonymousCoward View Post
Hi folks,
Thanks!
*bump*... any info ?
Also, does anyone know if the Plati/League alloys come in 4.5J/5J width in size 13? Thanks!
Old 20th October 2009, 06:05   #219
mithun's Avatar
Thanked: 59 Times
Hi folks,
Thanks!
Yes, surely you GC will reduce by 2.55mm.
Old 20th October 2009, 21:05   #220
Thanks Mithun - but is it 2.55mm or 2.55mmx2 since the former is Rotating Radius?
Old 1st November 2009, 10:21   #221
jkdas's Avatar
Thanked: 1,436 Times
Default Would 4.5J alloys do for a 165 upsize for an Alto ?
Someone I know want to sell off his old Aura alloys that he has on his Alto as the tyres scrapes with 5 people and luggage.
I was quoted 8k for 5 alloys and a almost new MRF tyres ( I forgot if it was 165 or 155 and the rest of the specs).
Now, I would love to get 165 for my Alto. Can it be done with the Aura one's? Its 4.5J .
1) My car wont be used to carry 5 people , mostly 2 within city
2) If not 165, 155 which?
3) If 4 people which is safer? This will NEVER be a highway car.
4) Its an LXi
Old 1st November 2009, 10:39   #222
Vid6639's Avatar
Thanked: 21,060 Times
JK go for 155/65-13 in XM1+ or Turanza ER-60.
Akroy had them on his Alto. He also had 13" aura alloys.
2006 Alto LXi - akroy's Photo Gallery - Team-BHP
Old 1st November 2009, 18:52   #223
Nikhilb2008's Avatar
Thanked: 6,648 Times
4.5j is ok for 165. No worries.
Old 1st November 2009, 21:51   #224
jkdas's Avatar
Thanks Vid and Nikhil.
I would love the 165 as it should give a mean look. Any idea about the pricing of 155 and 165?
And 155/65 and 165/60 ?
Old 2nd November 2009, 10:46   #225
JK, I think (someone can confirm) that GC will be reduced by 8mm+ in 165/60 and 5mm in 155/65. Hope you are OK with that much reduction in GC in 165/60 option.
Maruti Suzuki Swift : Tyre & wheel upgrade thread hemlock Tyre & Alloy wheel Section 2071 18th July 2018 18:23
Maruti Suzuki Ritz : Tyre & wheel upgrade thread funda2max Tyre & Alloy wheel Section 394 18th July 2018 15:45
Maruti Suzuki WagonR : Tyre & wheel upgrade thread iWonder Tyre & Alloy wheel Section 85 7th March 2018 23:56
Maruti Suzuki A-Star : Tyre & wheel upgrade thread JKBKS Tyre & Alloy wheel Section 63 30th January 2018 11:40
Maruti Suzuki SX4 : Tyre & wheel upgrade thread loving_alaap Tyre & Alloy wheel Section 265 2nd July 2017 08:16
