Old 13th June 2012, 21:56   #331
Eminenttismo's Avatar
Thanked: 315 Times
Default re: Maruti Suzuki Alto : Tyre & wheel upgrade thread
Originally Posted by SupratikDebnath View Post
Please suggest me brand options and their approximate prices for a set of 5.
Link
From those available at link MRF,Bridgestone,Apollo are tried,tested and are known to withstand rugged conditions. Coming to prices,if you get them from a local retailer,expect them to be a little less(less by 300-500 for each).
EDIT: You'll have a far safer driving experience if you opt for tubeless tires. Also, Michelin XM2 are good for fuel economy gains provided you drive on well laid roads(not suitable for very rugged conditions. More about XM2's here.
JK Tyres are known to last for a long long time but after seeing this (JK tyres, simply crappy manufacturing quality!),I wouldn't go for them. Anyday.
Eminenttismo is offline   (1) Thanks Reply With Quote
Old 13th June 2012, 22:00   #332
Thanked: 27 Times
Originally Posted by Eminenttismo View Post
Link
Hey thanks. :-)
I happened to go to that site and checked them out already. How is JK tyres?
SupratikDebnath is offline   Reply With Quote
Old 13th June 2012, 23:21   #333
swarnava.m's Avatar
Thanked: 268 Times
I have a 2003 Alto LX. It is running on stock tyres and the odo is at 37K kms. It has endured a lot of bad roads and thus one tyre gave up completely.
Now I am planning to get a set of 5 tyres. I do not want an upgrade, i.e. stick to 145 / 80 R12.
Thanks in advance for your prompt response.
I changed my stock tyres to Michelin 145/80 R12 last december, and am very happy with the decision. It just makes me realise how really crappy the stock tyres were. These have excellent road grip.
Also, these being the first monsoon for my tyres, (and staying in Goa, where it rains non stop), I did put my car through some paces on wet roads, and boy did the tyres do well!! I did some sharp curves in these conditions that I wouldn't have dreamt of with the JK tyres, and am more than a little surprised with the results. Inch perfect grip, and absolutely no loss in traction.
The only issue I am concerned about is the general opinion that Michelin tyres are softer compound than others like Bridgestone, and hence don't last as long as them. This, I will have to wait and see. So far, they have covered close to 7k, and look pretty much new. I make it a point to maintain optimum pressure always.
When the time came to change the tyres, at MASS they had offered Bridgestone at 3200/- per tyre. However, I had already decided to go for Michelin, and am happy I stuck to my decision and did not purchase from MASS.
From a tyre shop, they costed my Rs. 2850/- per tyre, plus Rs.150/- for each valve. Thus a total of 2850x4 + 150x4 = 12000/-.
swarnava.m is offline   (1) Thanks Reply With Quote
Old 19th June 2012, 21:58   #334
Thanked: 27 Times
Just wanted to update you guys about my tire change.
I went for full replacement (5 tires). Chose Apollo 3G (tubeless) @ 145 / 80 / R12.
So I migrated from tube-type to tubeless. Did not change the rims.
So far the ride has been very smooth. Minor road undulations have vanished (the ones which were prominent with my previous Bridgestone ones).
I am satisfied with this bunch. :-)
Costed quite a bit. Rate INR 2600 X 5.
Old 14th October 2012, 23:21   #335
Thanked: 16 Times
hello supratik,
i am also thinking of getting 2 apolo 3g for my alto, now that you've had them for some time, how has your experience been with them?
guptavis is offline   Reply With Quote
Old 15th October 2012, 19:58   #336
Thanked: 27 Times
Originally Posted by guptavis View Post
hello supratik,
@guptavis,
I am satisfied with this purchase and will definitely recommend.
Also, my regular travel road surface is pretty bad and so far the tyres have hold themselves quite well. :-)
I did a rotation last week.
SupratikDebnath is offline   (1) Thanks Reply With Quote
Old 24th June 2013, 15:13   #337
kaushik_s's Avatar
Thanked: 156 Times
Hi All,
Sorry for reviving an old thread. Can anyone tell me what is the current price for tires (145/80/R12) for Alto LXi? The car is 2006 model and needs immediate tire replacement. I'm planning to change to tubeless instead of tubed tires.
My choice would've been Michelin XM2 but Michelin might not be available in the place where the car currently is. So what other good options should I look for? Bridgestone/MRF/Apollo should be available as far as I know. Need some tires which have decent road grip but also longer life.
kaushik_s is offline   Reply With Quote
Old 24th June 2013, 16:12   #338
saket77's Avatar
Thanked: 5,051 Times
Originally Posted by kaushik_s View Post
Hi All,
Sorry for reviving an old thread. Can anyone tell me what is the current price for tires (145/80/R12) for Alto LXi?Need some tires which have decent road grip but also longer life.
You can go for Bridgestone. They are good as well. The current price for this size should be around 3K per tyre. Do try to trade off your old tyres. You can get 400-500 bucks for 4 tyres!
saket77 is offline   (1) Thanks Reply With Quote
Old 26th June 2013, 20:40   #339
mpksuhas's Avatar
Thanked: 4,131 Times
Guess the prize for Bridgestone Turenza 60 is in range of Rs 3200.
mpksuhas is offline   Reply With Quote
Old 20th July 2013, 18:41   #340
Thanked: 16 Times
Turanza ER60 145/80 R12 is around 2700/tyre in chandigarh. should be a little cheaper in bigger cities.
just visited the market today for the same, here are the quotes.
apollo 3g/4g ~ 2000
mrf zvts ~2250
jk ultima xp ~ 1750
Old 20th July 2013, 19:18   #341
jkdas's Avatar
Thanked: 1,436 Times
apollo 3g/4g ~ 2000
mrf zvts ~2250
jk ultima xp ~ 1750
Do check out yoko A539. They keep your car on road as if on rails. Not sure how much it cost now. Check out the review of it at tbhp.
Old 20th July 2013, 21:57   #342
Thanked: 16 Times
the yokohama india site does not show any tyre in 145 width. the minimum width is 155 and the maximum aspect is also 75. they show nothing near a 145/80 R12.
http://www.yokohama-india.com/product.aspx
The size available in A539 is 165/60 R12 which is in my opinion too wide for an alto and would also require a change to thicker 5J rims.
any other ideas?
Old 22nd July 2013, 21:15   #343
jkdas's Avatar
any other ideas?
Using it on OE rims. No issues. I also think few others use the same on their alto too here at TBHP.
Old 22nd July 2013, 22:29   #344
Thanked: 16 Times
Wish i had asked earlier. Which year Alto is it? are your rims 4J or 4.5J? Mine is 2007 Alto Lx and I believe mine has 4J rims.
I got apollo 3g fitted yesterday in stock 145/80 R12 Total Rs. 8K. fresh stock week of mfd 1713. Its only been ~40Kms but i dont have any complaints yet
Old 11th March 2015, 14:11   #345
saikatmandal04's Avatar
Thanked: 23 Times
Sorry for bumping an old thread.
I am contemplating new rubbers for my Alto LXi, the old ones are quite worn out. I plan to stick with the stock size of 145/80 R12. This is my 2nd car with usage restricted within city limits, mainly to commute between home and work place.
My car has done a little under 30K kms in over 7 years and I am in no mood to sell this for another 1.5-2 yrs. What would be some value-for-money options to be considered for my upgrade.
Please suggest.
saikatmandal04 is offline   Reply With Quote
Maruti Suzuki Swift : Tyre & wheel upgrade thread hemlock Tyre & Alloy wheel Section 2071 18th July 2018 18:23
Maruti Suzuki Ritz : Tyre & wheel upgrade thread funda2max Tyre & Alloy wheel Section 394 18th July 2018 15:45
Maruti Suzuki WagonR : Tyre & wheel upgrade thread iWonder Tyre & Alloy wheel Section 85 7th March 2018 23:56
Maruti Suzuki A-Star : Tyre & wheel upgrade thread JKBKS Tyre & Alloy wheel Section 63 30th January 2018 11:40
Maruti Suzuki SX4 : Tyre & wheel upgrade thread loving_alaap Tyre & Alloy wheel Section 265 2nd July 2017 08:16
