Old 24th February 2014, 21:27   #106
Nikhilb2008's Avatar
Thanked: 6,499 Times
Default re: Chevy Cruze : Tyre & wheel upgrade thread
Originally Posted by Familyguy View Post
Hi
I've booked the 2014 Cruze LTZ and will get delivery sometime this week. Although I will definitely change the tyres the moment I get delivery, and most likely the CPC2s, what I am a little confused about is if I should go for R17s instead of stock size. What are the possible side effects of going for a bigger size? Also, what is the buy back price I should expect for the stock tyres?
Thanks!!
Familyguy
You wont have any major benefit upsizing to 17". You will make the ride much harder.
Stick to the OEM size and you will be fine. You should think of a higher quality rubber but in the stock size.
Nikhilb2008 is offline   (1) Thanks Reply With Quote
Old 26th February 2014, 12:03   #107
Thanked: 44 Times
Thanks for the advise! One more thing, does going for 215/225 instead of stock 205 void the warranty? And between the CPC2 and the Michelins which one should I go for? I will take it on the highway quite a lot and drive at decent speeds( 120-180 range). Also, going through bad patches will be inevitable.
Thanks!
Familyguy is offline   Reply With Quote
Old 1st April 2014, 17:24   #108
kapursaket's Avatar
Thanked: 76 Times
I am always in favour of the Stock Tyres even though they may sound a little harsher because the manufacturer will always fit a tyre apropos Suspension, Climatic Conditions and average Road Conditions. Tyre bursts are now more heard of owing to rampant overlooking of Car manufacturers recommendations and buying Tyres with non tropicalized rubber and softer side walls.
Using Oversized Tyres is more of a fad than actual benefit. Bargain is between more fuel consumption, harder suspension for better looks and a little drive comfort.
kapursaket is offline   Reply With Quote
Old 24th April 2014, 13:21   #109
Thanked: 17 Times
Hello Everyone !
I have a Cruze LTZ which i have driven over 58000 Kms
Its time for a tyre change and I am contemplating the various options.
Any suggestions ?
The ones i have been offered are : Michelin, Apollo, JK, Goodyear, Yokohama, MRF
ask4gautam is offline   Reply With Quote
Old 24th April 2014, 13:35   #110
iliketurtles's Avatar
Thanked: 1,049 Times
Go for either the Michelins or the Yokohama's, you won't regret it. Pirelli is also a good option to evaluate. The Michelin's are the pick of the lot, but will be the most expensive too (not by much though). I'm sure no one would recommend Apollo's, JK's or Goodyear's to you. I had heard about some good things about an MRF high-speed tyre, although I can't recall it's name now.
Even so, I'd only look at the Michelin's, Yokohama's or Pirelli's if I were you.
iliketurtles is offline   Reply With Quote
Old 24th April 2014, 20:55   #111
Thanked: 80 Times
Originally Posted by ask4gautam View Post
Hello Everyone !
Any suggestions ?
I had upgraded to Bridgestone Tyres and I am very happy on them for last 1 year.
Check out the price n if it's economical it's worth the try.
RishiSuri is offline   Reply With Quote
Old 25th April 2014, 13:58   #112
kapursaket's Avatar
Thanked: 76 Times
Sensible Option is to get hold of stock tyres J.K Vectra 205/60R/16 at a discounted price from Chevrolet Dealers. Never overlook the fact that Shoes recommended by the brand owners of the Car will fit the best and rest is commerce.
Old 25th April 2014, 14:30   #113
Sommos's Avatar
Thanked: 675 Times
Hello Everyone !
Any suggestions ?
Michelin Primacy 3ST will most probably be the best one to fit if budget permits, followed by the CPC2. For more details and a comparision between the two, you may kindly refer to moderator Mobike's thread.
Sommos is offline   (1) Thanks Reply With Quote
Old 2nd May 2014, 18:54   #114
mobike008's Avatar
Thanked: 8,249 Times
My recommendation. Eyes closed go for Michelin Primacy 3ST.
I have installed the same tyres on my 55K kms done Cruze and have completed 8K kms on these new tyres and loving the experience
They are expensive but, really worth it.
Old 9th May 2014, 13:42   #115
itwasntme's Avatar
Thanked: 1,675 Times
Just posted in the Apollo Alnac 4G thread but thought should highlight here as well:
http://www.tyrereviews.co.uk/Article...-Tyre-Test.htm
2nd: Apollo Alnac 4g
Total: 91.2 / Dry: 18 / Wet: 37 / Rolling Resistance: 9 / Comfort: 9 / Noise: 9 / Overall: 9.2
Positive: Short braking distances on wet roads, a high level of comfort
Negative: None listed
Overall: Apollo present a real surprise and become one of the best on test in wet braking. These tyres have no problem coping with emergency maneuvers, with no unexpected loss of grip. With no obvious weaknesses, Apollo have never never demonstrated such consistencies in all areas
http://www.tyrereviews.co.uk/Tyre/Apollo/Alnac-4g.htm
itwasntme is offline   (1) Thanks Reply With Quote
Old 9th May 2014, 17:16   #116
anb
anb's Avatar
Thanked: 157 Times
Infractions: 0/1 (5)
Apollo has launched the premium Vredestein tyres in India. Vredestein Ultrac Cento is available in stock size for around 10K. I've heard very good reviews about these tyres.
anb is online now   Reply With Quote
Old 22nd July 2014, 11:01   #117
Thanked: 17 Times
Hi Guys !
Time for a tyre upgrade for my Cruze. Have done 60K on the original set of JK Vectras
Have shortlisted the following :
1. Bridgestone Potenza G III - 205/60/R16 92 H - 33000/- for set of 4
2. Michelin - Primacy 3ST - 205/60/R16 92 V - 34000/- for set of 4
3. Falken - Azenis PT722 - 205/60/ R16 92 H - 27000/- for set of 4
4. Hankook - Optimo - 205/60/R16 92 H - 28000/- for set of 4
Which ones would the experts suggest ?
A quick reply will be highly appreciated.
Thanks !
Old 22nd July 2014, 11:53   #118
itwasntme's Avatar
Go for the Michelin P3ST with eyes closed! Your rates are also quite competitive. Source?
itwasntme is offline   Reply With Quote
Old 22nd July 2014, 17:51   #119
mobike008's Avatar
Hi Guys !
Time for a tyre upgrade for my Cruze. Have done 60K on the original set of JK Vectras. Have shortlisted the following :
I concur with Itwasntme. Eyes closed Primacy 3ST are the ones to go for and thats indeed an awesome price of 8.5K/tyre whereas I paid 9.5K/tyre
You can read my review on these tyres here :-
http://www.team-bhp.com/forum/long-t...ml#post3273301
Old 15th October 2015, 13:05   #120
HK1
Default Re: Chevy Cruze : Tyre & wheel upgrade thread
Originally Posted by deb_majumdar View Post
I have been reading several threads, but failed to conclude, so finally decided to write. .....................
I mostly drive in Kolkata, the roads are not so good. They get worse during monsoon. Sometimes I go to the villages, the roads are again not good there. However, I also go for long tours, and surely plan to make more such trips as my son is almost 2 years old and getting fit for tours. Driving on the highways is what made me buy the Cruze. On such trips I try to be at the 140-160kmph range and only occasionally touch 180-190kmph if the road is empty. All these make my case pretty confusing - I do have all kinds of requirements. What kind of tyre should I go for?
First of all....Its good to be a part of this awesome community. Cheers everyone.
I am in the same boat as deb_majumdar in term of my driving conditions. I would very much like to get a tyre that is sturdy, durable, grippy, good FE and the works but have realised no one tyre can give me everything.
So here are my priorities.
Sturdyness - as puncture and cutproof as possible
Safety - decent dry/wet grip, braking etc
I am ready to compromise on FE, noise, cost and the rest.
I have been recommended Bridgestone Potenza G3 and Pirelli P7.
G3 - 205/60/R16 - 7000/-
P7 - 205/60/R16 -7900/-
P7 - 215/60/R16 -8300/-
I am still open for any other suggestions but am planning to buy really soon.
Currently running stock garbage .
HK1 is offline   Reply With Quote
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 15 15th June 2018 16:33
Chevy Beat : Tyre & wheel upgrade thread slayer87 Tyre & Alloy wheel Section 168 20th March 2017 19:11
Chevy Optra : Tyre & wheel upgrade thread throttleking Tyre & Alloy wheel Section 33 4th December 2014 18:03
Chevy Spark : Tyre & wheel upgrade thread djay99 Tyre & Alloy wheel Section 50 28th September 2014 08:57
