Old 6th November 2005, 18:39   #1
passionpurple's Avatar
Unhappy help with bent rim
1)due to heavy breaking and skidding on one day, my palio ended up with a bent tyre rim..
-> now the tyre wobbles moderately while driving.
2)also a few days ago, my santro tyre fell into a hole.. again I had a bent rim..
->the plastic wheel cap does not fit well now..
upon inquiry at some local places they say that the rims can't be repaired and have to be scrapped..
currently both tyres are working as spares.. but that is not the ideal solution to the problem..
NEED MY NET FRIENDS' VALUEBLE ADVICE BEFORE TAKING ANY DECISION....
passionpurple is offline   Reply With Quote
Old 6th November 2005, 18:52   #2
tsk1979's Avatar
Thanked: 16,420 Times
Rims can be repaired. You can go to a big tyre showroom. They have rim straightening machines. But if the bend is so large as it does not straigten you have to get a new rim.
Old 6th November 2005, 19:46   #3
lamborghini's Avatar
Thanked: 1,664 Times
To add to what Tsk says,
a new steel rim isn't very expensive either.
I believe a new rim for Palio is some 750 bucks.
lamborghini is offline   Reply With Quote
Old 7th November 2005, 05:03   #4
Sahil's Avatar
Thanked: 2,712 Times
Well if that lambo says is correct then you might as well get the rims changed for 750 bucks coz even if you repair it, it will cost you a few hundreds....and i would quite trust repair jobs vs new rims... bent rims can get u into big trouble...might as well get new ones if they are coming in cheap. If you do choose to repair then do a proper check on it once its done.
Old 7th November 2005, 06:21   #5
aseem's Avatar
Thanked: 419 Times
Passion, sorry to sound alarming, but STOP your car immidiately and change your rim before driving. This is playing with your life, stop before its too late. 750 Rs is too little a price to pay for the safety of you and your family members.
aseem is offline   Reply With Quote
Old 7th November 2005, 09:20   #6
tsk1979's Avatar
Rim straigtning costs 100rs
Old 9th November 2005, 18:57   #7
nitrous's Avatar
Thanked: 285 Times
Why didnt anyone notice??
Passion, is it a steel rim or an alloy one?? Its very important to answer this.
Steel rims can be repaired if the bend is not too bad.
But, if its an alloy rim...dont think twice get it replaced.
nitrous is online now   Reply With Quote
Old 9th November 2005, 19:04   #8
Thanked: 64 Times
AFAIK, alloys don't bend like rims, they simply crack. This HAS to be a bent rim.
RX135 is offline   Reply With Quote
Old 9th November 2005, 20:18   #9
revtech's Avatar
Thanked: 35 Times
yeahh Rx is right alloys very rarely bend.most of the time they just crack or break.only steel rims bens so it has to be steel and since its steel the replacement cost is one Rs 750 according to lambo so it should be changed asap.
Rev
revtech is offline   Reply With Quote
Old 9th November 2005, 21:36   #10
viper's Avatar
Thanked: 9 Times
Thumbs up
Nitrous,
If you read carefully passion has already said that it is a steel rim (he said wheel caps don't fit) and not a alloy. Also a spare rim costs only Rs150-200. You can get a set of 4 for under Rs1000/- in Mumbai if you have the right source.
In all probabilities your rim can be repaired. What you need to do is get it straightened and the particular wheel rebalanced.
Viper
viper is offline   Reply With Quote
Old 9th November 2005, 22:11   #11
srasania's Avatar
dude,just replace it.. worth the extra few bucks that you pay..it's a matter of safety !..!
sr
srasania is offline   Reply With Quote
Old 9th November 2005, 22:57   #12
abhibh's Avatar
Thanked: 34 Times
Replace the rim man.. Wont cost much.. Safety first...
Old 9th November 2005, 23:38   #13
Awaiting Email Confirmation
original_sin's Avatar
buddy it 1ce hapened with me about 3months back with my skoda 17"inch rims,2 of the left front and back rims got bent and cracked abt 1 inches when i was coming from daman the driver pulled the car down corner of road abt 6inches... what i did was id put the mags on the lathe machine and Gas welded it and made it thru with a OD leveller then grinded well in shape carefully and got the rims buffed and chrome plated working all fine man and yess dnt forget to get it balanced .. take care
original_sin is offline   Reply With Quote
Old 10th November 2005, 09:29   #14
aadix's Avatar
buddy,take it to any good tyre shop, they will straighten ur rim up for 100 rs.
got it done recently for my friend's ikon. the rim becomes perfectly safe.
aadix is offline   Reply With Quote
Old 10th November 2005, 11:55   #15
speedsatya's Avatar
Thanked: 712 Times
also check the side wall of the tire with the bent rim for any bulges...a nd when you fit the new rim get it balanced ...and if possible get the alignment checked as well
speedsatya is offline   Reply With Quote
Pulsar 150 DTSi - Valve bent! Help needed indianvirus Motorbikes 18 17th December 2015 07:46
Bent Rim after hitting a pothole - What effect will it have on the tyre? Bigzero Tyre & Alloy wheel Section 17 14th January 2015 17:06
Slightly Bent Rim - trouble? vista_qjd Tyre & Alloy wheel Section 13 12th September 2013 11:01
Bent alloys drifter Tyre & Alloy wheel Section 16 22nd September 2004 00:10
