Old 12th September 2010, 00:57   #31
ph03n!x's Avatar
Thanked: 120 Times
Originally Posted by djay99 View Post
Jayanth, i seriously doubt whether our car's shock absorbers are of good quality or are sub-standard?
Well, my rear shocks (both) conked out at ~17k KM, and were replaced on warranty. Oil leak.
ph03n!x is offline   Reply With Quote
Old 12th September 2010, 12:33   #32
furioussphinx's Avatar
Its time to change the tyres of my car. Have CPC2s in 195 size on my car now. Am desperately looking around for Hankook Ventus RS2/RS3. Dont mind driving down to Bangalore for them.
The CPC2s were great tyres, decent on dry and brilliant on wet roads. I had so much confidence that I drive faster on wet than dry now
Where can i get the Hankooks? I will go for 205 this time.
furioussphinx is offline   Reply With Quote
Old 21st September 2010, 12:54   #33
vabs78's Avatar
Thanked: 11 Times
I finally went for 195/55/15 CPC2s at Rs. 4575/- per tire. Fitted them last Saturday. Advans were not available, I waited for a week to see if I can get hold of them.
I am taking it easy as the tires are new, but here is the initial impression from the 3 days of driving around:
The good:
- Steering feel much lighter now
- Ride quality is much much better
- Road noise has gone down significantly especially on rough / broken roads
- Tramlining has reduced significantly (I still have to test this at higher speeds on highway)
The bad:
- Breaking distance seems to have increased (I can't be sure of this, this may also be due to the fact that the tires were brand new when I noticed this)
- Steering feedback has reduced. With PP2s the steering felt much more direct and used to react with smallest of inputs.
- Overall the sharpness in handling has reduced. It feels almost sedate now.
I will update my impression after a highway run this weekend.
vabs78 is offline   Reply With Quote
Old 8th October 2010, 18:56   #34
vabs78's Avatar
Thanked: 11 Times
After spending about 3 weeks and one Pune-Nasik-Pune highway drive with the new tires I must say that I am mighty impressed with the CPC2s. Following are my observations:
- Much much better ride. Wify is very happy with the new tires.
- Road noise has reduced significantly. Especially on rough roads.
- Tramlining has reduced significantly. I feel much more comfortable and confident while driving on patchy roads at high speeds.
- Dry grip is almost as good as PP2s. There may be little reduction in grip but nothing noticeable. Considering I have also gone down to 195 width, this seems quiet impressive to me.
- Wet grip is excellent. I didn't notice any reduction in grip when it suddenly started raining on my way back from Nasik to Pune. I was able drive at same speeds without feeling any kind of discomfort.
- Handling and sharpness of the car have gone down by a little bit. Nothing to cause any worry but I do miss the riding-on-rails like feeling with the PP2s. This was expected because the higher profile of tires. Somebody give me something to improve Getz's handling.
Overall, I am happy with the tire change and I highly recommend the CPC2s.
Old 8th October 2010, 22:36   #35
kpzen's Avatar
Thanked: 1,655 Times
Simple. Get the Monroe rear dampers.
kpzen is online now   Reply With Quote
Old 13th October 2010, 19:57   #36
Thanked: 16 Times
Prajesh - Are you running these on your Getz? I am assuming Yes, please post some more details - how much these cost and the perceived improvements. How are these different from stock? Do they offer a firmer ride? I am really interested.
Beast_of_Burden is offline   Reply With Quote
Old 15th October 2010, 17:21   #37
vabs78's Avatar
Thanked: 11 Times
Update from my side: The breaking distance has definitely gone up i.e. grip has gone down. Strange thing is that I did not feel this on my highway drive. I only observed this while doing short speed bursts in city.
Prajesh - some more details please . And why only rear dampers?
Old 21st October 2010, 01:31   #38
iraghava's Avatar
Thanked: 156 Times
Vabs - Fronts not available, only rears are available.
Old 22nd October 2010, 13:21   #39
vabs78's Avatar
Thanked: 11 Times
If I have to sum up my experience after the tire change in one sentence; "Life is much more comfortable with the CPC2 but wheres all the fun gone?"
I am exaggerating off-course, but you get the idea.
@iraghava, Prajesh, any idea who can source the Monroes in pune / mumbai?
Old 22nd October 2010, 15:20   #40
Default hello
i'm running maxxis za-1 205/r16's on my getz crdi.. blasted past the express way at 170 constant on long stretches.. my car felt absolutely planted.. even on wet roads.. as well as dry - wet transitions..
belsonkoshy is offline   Reply With Quote
Old 27th October 2010, 03:47   #41
iraghava's Avatar
Thanked: 156 Times
Vaibhav - Talk to Pete's directly, they'll deliver to your door step.
Old 27th October 2010, 13:42   #42
raj.barcode's Avatar
Thanked: 61 Times
For Monroes talk to peter but i guess you made a wrong choice of Tyre for a rocket hatch that getz is. I would have gone for hankook rs2 or neovas or ps3
CPC2 is a horrible set your braking distances would be almost 1.3 times more than in pp2 i have personally experienced it in my skoda
raj.barcode is offline   Reply With Quote
Old 11th November 2010, 18:21   #43
vabs78's Avatar
Thanked: 11 Times
Yes will do, I am relocating to Bangalore in couple of months, will do this after settling there.
This is true. The breaking distance has gone up. I wouldn't say its inadequate but you certainly feel it after moving from PP2. Next time I change tires I will sure go back to a more performance oriented tire.
Old 7th December 2012, 13:36   #44
vabs78's Avatar
Thanked: 11 Times
Default Re: What should be worthy successor for PP2 on my GetzD
Time to change the tires again.
My current set has completely worn out and I am afraid to take the car out for long drives. GetZD has just completed 50K kms.
I am not happy with my experience with Conti CPC2. Compared to Michline PP2s that I had earlier, CPC2s have significantly lower dry grip. Wet grip is also not that impressive. PP2s used to work like a charm in wet, almost as if there is no water. Turn-ins also were much sharper with PP2s.
I also think that my choice of tire size was less than ideal. So I am planning to switch back to 205/50/15 or go for 195/50/15.
I want to either go for Michline PS3 or Yoko AD07/08 but they don't seem to be available in these sizes.
Guys, please suggest where to find these tires in Bangalore(I stay near Bellandur/Sarjapur rd). Also tell me if there are any worthy candidates that I should be looking for.
Looking forward to your suggestions.
Old 18th December 2012, 16:44   #45
vabs78's Avatar
Thanked: 11 Times
I am unable to find either Michline PS3 or Yoko Advans in 15" size. I checked 3 different dealers and online portal changemytyre.com.
Only options that I am seeing in 205/50/15 or 195/50/15 are Yoko S.Drive, A.Drive, Bridgestone Potenza G3.
Please advice guys. I know Prajesh is successfully using A.Drives but they are not really performance tires.
Also don't want to go for S.Drives as I have heard they are not that good on wet traction.
Changemytyre.com has Kumho KU31 listed in 205/50-R15 size but i don't know anything about this brand. Is this worth considering?
Thanks for your help.
Indigo Marina - Is it a worthy buy ? mithun Sedans 34 11th May 2010 20:43
Michelin PP2 or Yoko Advan Sport arunjohnpaul Tyre & Alloy wheel Section 2 11th August 2009 17:05
Need Serious Help..Michelin PP2 or BF Goodrich Or Yoko but what Yoko ?? Tool Tyre & Alloy wheel Section 22 25th May 2008 23:37
can Used ESTEEM worthy to buy..pl suggest shapath Sedans 9 20th August 2007 19:45
