Old 30th October 2007, 23:20   #31
kpzen's Avatar
Thanked: 1,655 Times
Originally Posted by adisseril View Post
what is the ideal size of rim/tyre for maruthi esteem
175/70-13 on 5j rims but the stock 4.5j rims will also do
Old 30th January 2008, 03:37   #32
rider60's Avatar
Thanked: 47 Times
Tire Calculator
this calculator gives the rim size difference and error too check it out, i used it to calculate for my swift upgrade!
rider60 is offline   Reply With Quote
Old 13th April 2008, 22:54   #33
Thanked: 660 Times
Tyre Size calculator. (not online/web based tool,)
Its a standalone flash based tool. You need Adobe/macromedia flash player 9.
[COLOR=#0000ff]http://rapidshare.de/files/39107919/tyre_size_calculator.swf.html[/COLOR]
Download and use!
Old 14th April 2008, 00:15   #34
I am using 175/70/13 tires(sorry this time MRF,rough ride)on Cielo. Can I go for 14" ? What affects will I experience? Bridgestones gave me 80000 kms.
Magnan is offline   Reply With Quote
Old 4th October 2008, 15:59   #35
akshay4587's Avatar
Thanked: 1,686 Times
Now this calculator has made me scratch my head regarding the speedo error thing
My car Does 100Km/hr at 2750 RPM on stock tyres.
If I upgrade to 196/60/14 the Difference would be 2.5%.
70MPH would be 71.5 MPH.
that means speedo will show less reading for a particular RPM than stock tyres.
Shouldnt it be more since the overall diameter is increasing and the car would be revving less?
Asking this since my bike used to do 100@6.5K RPM on stock tyres
after upsizing one size it did 100@6.2K RPM
Old 4th October 2008, 19:01   #36
Sudipto-S-Team's Avatar
Thanked: 266 Times
RPM has no connection to your speedo reading. The speedo takes its reading by calculating the number of revolutions in the tyre - so if the tyre becomes larger or smaller the speedo reading will change accordingly.
The RPM reading that you see in the dashboard instrument panel is related to the engine's working speed. Not really connected to the speedo in any way.
Sudipto-S-Team is offline   Reply With Quote
Old 5th January 2009, 18:42   #37
rajchetan's Avatar
Thanked: 60 Times
Hi
Tire size calculator
Another web site that helps you right size the tyre for your Car.
i hope its helpfull
rajchetan is offline   Reply With Quote
Old 20th December 2013, 13:26   #38
schakravarthy's Avatar
Thanked: 4,145 Times
Can someone please solve my confusion??
The stock tyre size of a Fiat Punto Active variant is 165/80-R14, Emotion is 175/70-R14 and Emotion Pack is 195/60-R15 (pre-2012 models).
Now, according to the tyre size calculator, it is not recommended to up-size the Active variant to the tyre size of an Emotion/E Pack variant, or up-size an Emotion variant to Emotion Pack's tyre size.
I for one, don't believe that Fiat would calibrate the meters differently for different variants; it just doesn't make sense.
What's the funda here? Is it a plain goof up on the part of Fiat India or is there some basic reasoning that eludes me?
schakravarthy is offline   (1) Thanks Reply With Quote
Old 14th April 2016, 15:55   #39
ashis89's Avatar
Thanked: 1,351 Times
Default Re: Tire size and Speedo error calculator
I am looking to upgrade the stock tyres (155/65 R14) of my WagonR. Though I have the option of 165/65 R14 I am more interested in 175/65 R14. The error due to the upsize is going to be 4.7% in the latter versus 2.3% in the former. Should I go ahead with this upgrade?
There is another alternative of 175/60 R14(1.5%) but I don't see any tyre brands offering them (available in GY GT3 and Yoko A-Drives only).
ashis89 is offline   Reply With Quote
Pioneer Head Unit Errors. Error 11 and error 17 in pioneer MP3 rajivanoj In-Car Entertainment 33 8th March 2018 12:58
Why rim size is as critical as tire pressures or tire sizes !! speedsatya Tyre & Alloy wheel Section 23 12th July 2011 18:00
my speedo ended !!!- zen needle crosses last point on speedo speed0mania Street Experiences 81 11th August 2006 12:22
speedo & odo error chandan Tyre & Alloy wheel Section 5 22nd July 2005 01:04
