Old 25th January 2009, 12:47   #151
Tejas@perioimpl's Avatar
Thanked: 5,480 Times
Originally Posted by Tejas@perioimpl View Post
Where will i find these hub centric rings in south mumbai? And cost?
Are these the same as the "O" rings?
Guys. I'm still waiting for an answer... No one in bombay can help me kya? Disappointing!
Tejas@perioimpl is offline   Reply With Quote
Old 23rd March 2009, 01:56   #152
sAP
sAP's Avatar
Thanked: 16 Times
Arrow Delayed response
Sorry I did not get a chance to reply earlier. I am in and out of circuit occasionally.
To answer your question, I no longer use the Corsa, but I would recommend that for any car that uses "lug bolts" (as opposed to lug nuts) to hold the wheel to the hub -- such as the Corsa, Skoda, etc -- to give careful consideration to hub centricity.
In vehicles that use lug "nuts" to hold the wheel, it appears that hub centricity is less critical.
In India, I know Aura makes aftermarket wheels to fit the Corsa hub center without leaving a gap.
Also, it is important to ensure that each wheel is balanced as accurately as possible. You could try the balancing shops others have used and recommended in this thread to attain an appreciably accurate result.
Good luck.
sAP
Originally Posted by raj_7703 View Post
H
Zap,
Are you still with Aura alloys on your Opel Corsa stock tyres. How is it doing? any issues? Iam plannig to go for alloys on my COrsa sedan stock tyres (175/75/R13) and after reading your posts , i feel i should go for Aura. What is your suggestion? Any other alloy brands in your opinion can be fitted with Corsa?
thanks in advance
Raj
sAP is offline   Reply With Quote
Old 23rd March 2009, 07:18   #153
Thanks sAP, I think that is an important piece of information. Fortunately my car falls in this category, and what you said seems to apply! Only proper balancing is enough.
santosh.s is offline   Reply With Quote
Old 2nd November 2009, 18:54   #154
gigy's Avatar
Thanked: 41 Times
Where can i get hub centering rings in north mumbai? i am getting vibrations after crossing 90kmph. openned and checked the alloys and found quite a good amount of gap. i have done the balancing twice but its not helping
Old 5th November 2009, 09:27   #155
gigy's Avatar
Thanked: 41 Times
Can somebody tell me what metal is used in making the rings. i plan to get it worked from local lathe guy, as cant find them in market.
Old 5th November 2009, 13:03   #156
BAKIYA_2K12's Avatar
you can use aluminum metal,make sure there is no gap and it should a tight fit.for reference see this pic
http://www.team-bhp.com/forum/818202-post132.html
BAKIYA_2K12 is offline   Reply With Quote
Old 10th November 2009, 18:09   #157
gigy's Avatar
Thanked: 41 Times
Thanks for the picture, will get it done in aluminum.
Third time balancing seems to have solved the issue and there was nothing noticeable upto 110kmph, but i am not comfortable with the gap so will get it made soon.
Old 27th March 2011, 20:10   #158
Default Re: Solution for vibrations after installing alloy wheels
Came across these ready made rings. Was initially skeptical about "plasticy" looking items, but the manufacturer claims that they are actually better than metal rings as they are hard/strong enough not to deform/break, do not melt, make noise (in case of loose fitting?; which should not be the case in the first place), or damage alloys (if too tight?).
Dirt cheap on ebay, but unfortunately do not seem to be available locally. Got a set from US for my car and alloys dimensions. First impression is that they are pretty good, precise dimensions that fitted quite snugly. Haven't yet gotten a chance to test them beyond 80Kmph, though! Here is a picture after mounting. I think it is high time accessory shops start stocking such rings in India.
Old 29th March 2011, 01:27   #159
sAP
sAP's Avatar
Thanked: 16 Times
Santosh
I am curious that you had an interest in these rings. I thought you said you didn't have a need for them since your wheels were "lug-centric" in an earlier post?
That looks like a good fit though. Nice find. They make them out of ABS plastic out here. Had them on my previous Acura Legend with Konig wheels.
sAP
Old 29th March 2011, 12:13   #160
Santosh
True, I was not so desperate to get these. As mentioned earlier, I had faced severe vibrations in the beginning which smoothed to a good extent after proper balancing alone. In spite of that, I always thought it would be a good idea to have centering rings as well (irrespective of type of mounting) for additional benefit. Because every time you remove a wheel and mount it back there is a possibility of new imbalance, or it could develop over time merely due to regular stress that wheels have to undergo while driving. In last several years, vibrations did in fact appear again but severity would be less and the speed at which it happens was also high (120+ kmph), hence did not bother much. Balancing reduces vibrations, but it doesn't make it as smooth as what I experience in Palio with stock wheels (a precise hub fit). Hope these rings should raise Baleno's high speed ride quality close to that.
Was aware of these ready-made rings (as it is mentioned right in the first post!), but was discouraged due to material being plastic, and feeling that rings sold in US may not have a right fit for my car and alloy combination. Well, until I changed my mind now . After hunting for the right fit, it seems both hub diameters of various cars and even after market alloys are actually a set of "standard" numbers, so finding a right fit is actually much easier than what I thought. Earlier, had tried to get metal rings locally or to get them custom made at a lathe shop, but gave up due to hassles involved.
sAP
Seller claims it is "poly carbonate". Is it the same as ABS plastic?
Old 29th March 2011, 20:24   #161
sAP
sAP's Avatar
Thanked: 16 Times
Polycarbonate is a tougher material than ABS plastic, so its actually better. ABS plastic replaces polycarbonate though since its cheaper and "almost" as strong.
sAP
Old 30th March 2011, 00:00   #162
kkg
kkg's Avatar
Thanked: 75 Times
My bad that I bumped into this thread today only. I have neo alloy wheels in my Spark for the last three years. Whenever I hit the highway I get vibrations on the steering around 100-120kmph.
Many wheel balancing sessions done but the problem never got fully resolved, only the speed range of the vibrations changed i e these days steering vibrates around90-100kmph.
How to solve this issue and from where to get these rings as i do not know the numbers of my alloy wheels and the hub of my car. Also, as I have run my car around 46000kms on this configuration, would this have affected the strength of my lug bolts and nuts in any way??
kkg is offline   Reply With Quote
Old 2nd April 2011, 10:12   #163
goandude's Avatar
Thanked: 455 Times
After going through 11 pages of this thread I find serious disadvantages of putting on anything but OE alloys. Must keep checking the classifieds. Anyone selling OE swift/ dzire/ ritz alloys?
goandude is offline   Reply With Quote
Old 16th May 2011, 11:28   #164
sAP
sAP's Avatar
Thanked: 16 Times
Bought a 2nd set of wheels for winter tires. Had to be BMW OEM. Though I did consider getting a set from Beyern -- which makes BMW-only wheels.
Not taking any chances with the driving quality of these vehicles. It's a matter of precision now.
Old 9th September 2011, 23:20   #165
Thanked: 45 Times
I think, even an Nylon 66, Acetal rod can be machined for rings, which is better than ABS. and much stronger than ABS. I am also planning to get an set of machined rings made by these polymer.
But , do we need it for all four wheels? or just front wheels are fine?
rajivanoj is offline   Reply With Quote
Alloy Wheels - Sai Mag Wheels (Rama Road Industrial Area) tsk13 Delhi NCR 39 12th March 2018 12:24
Problem with my i20 head-unit after installing HID's nikibusa Technical Stuff 24 28th February 2014 09:46
Reset ECU after installing K&N PatienceWins Technical Stuff 20 6th July 2010 16:15
Part 2: Update to Solution for vibrations after installing alloy wheels sAP Tyre & Alloy wheel Section 10 17th December 2009 11:20
Vibrations after upsize Knight Rider Tyre & Alloy wheel Section 14 21st June 2006 20:56
