Old 8th June 2007, 00:53   #106
iraghava's Avatar
Thanked: 156 Times
Wolf - It should be a balancing issue as KP mentioned so get that checked. Otherwise check & make sure that none of your tyres have sidewall bulges.
Old 8th June 2007, 08:15   #107
wolfinstein's Avatar
No, sidewall bulges, runs fine below 100, but anything above that Issue.
I will get the alignment and balancing done sometime soon.
wolfinstein is offline   Reply With Quote
Old 8th June 2007, 10:04   #108
sAP
sAP's Avatar
Thanked: 16 Times
Arrow Liked the problem description: Misplaced Forcefeedback
  • Balance all 4 wheels
  • Visually check for minor bends in steel rims (on the inside as well, which is not usually accessible)
  • Check tires for abnormal wear patterns
  • Allignment not necessary
sAP
sAP is offline   Reply With Quote
Old 20th June 2007, 20:06   #109
evolve's Avatar
the primary reason for aftermarket wheel vibration is lack of hubcentric rings (spigots).
All aftermarket wheels will usually come with bigger hub centre bores which means the wheels are only held in place by the wheel studs against the hub - this can cause vibration and in severe cases cause your lugs to break!
make sure all aftermarket wheels are fitted with hubcentric rings and then wheels aligned.
evolve is offline   Reply With Quote
Old 20th June 2007, 20:51   #110
iraghava's Avatar
Thanked: 156 Times
Good advice Evolve but the problem is availability of the spigots in our market. Considering that very few percentage of after market Alloys sold in India are
actually made here the rings are not available easily. Also, the sellers selling the wheels are also not experienced/technical enough to know of these solutions off hand and make them mainstream.
Old 20th June 2007, 21:27   #111
sAP
sAP's Avatar
Thanked: 16 Times
Default Steel wheels on Xeta
Wolfinstein's issue doesn't appear to be hub-centricity related; he isn't using an aftermarket alloy wheel.
sAP
Old 24th June 2007, 17:41   #112
evolve's Avatar
you can easily machine a decent set of rings ant any engineering shop. Its just critical to get the dimension absolutely spot on. No wider and no bigger than neccessary. If you read up on forums about your centre bore diameter - you can compensate the difference with accurately machined rings. Also make sure they are tappered correctly.
Old 25th June 2007, 15:38   #113
Guys. Here is a site with very useful information on setting up alloy wheels with other details on PCD and the likes.
Hope it is of some help.
ENKEI::PRODUCTS::KNOWLEDGE
ashwinsaval is offline   Reply With Quote
Old 14th April 2008, 20:14   #114
nirmalts's Avatar
Thanked: 7 Times
Default Hub centric ring required?
After installing new alloys I had steering wobble at speeds between 100 and 120kmph. Got the balacing done and the problem seems to have disappeared (tried until 140kmph). After going through this thread, I removed the alloy cap and inspected. Found that it is currently lug centric. On stock wheels it was hub centric. Thinking of getting hub centric rings. Do you think this is required?
Also even after small rides (say 10kms in city traffic) I find that the front alloys are really heated up. The back wheels are at normal temperature. Is this normal? Could the alloy be rubbing against something?
Nirmal
nirmalts is offline   Reply With Quote
Old 14th April 2008, 21:08   #115
rks
rks's Avatar
Your scenario seems to be identical to that of mine. The old Santro's steel rim has a bore dia of 67 mm (this is the bore at the centre) and PCD 114.3 mm. The PCD matches precisely with those of my alloys (Neo Star SM). But the bore dia for the alloys is mentioned in the website as minimum 58.4 mm and maximum 70 mm. So does this mean that the the alloys have a variable (tapered) bore, so that it will match all hub dias in this range? Not sure of this. In any case I had a problem of the car wobbling at high speeds initially (at ~130 kmph) but this was due to inaccurate tyre pressures. After taking care of these and also proper balancing/alignment, I have no problems at all even at ~160 kmph.
Same observation in my case. But this does not seem to be anything unusual. The heat is generated by the disc brakes and the alloy wheels are supposed to be good dissipators for this heat. I have driven about 26000 kms on these alloys and the braking is superb, as is the car's high speed handling.
Old 16th April 2008, 20:56   #116
rks
rks's Avatar
Yes, I found that the centre bore in the alloy wheels is tapered. So it looks like in my case the wheel is hub-centric. Makes sense because there is no vibration problem even at speeds like ~160 kmph, as I pointed out. But still, I will have to confirm this theory.
Old 18th April 2008, 10:49   #117
Thanked: 711 Times
As far as I know, Santro PCD is 100 & wheel diameter of 54.5mm (measured with vernier caliper). Also, don't feel that wheel dia. would be different for old models(ZipDrive,ZipPlus) compared to new models (Xing).
sukiwa is online now   Reply With Quote
Old 18th April 2008, 11:39   #118
rks
rks's Avatar
No, the Xing's wheel is different from that of old Santro. The old Santro's specs are available from this post, where I have given the source:
http://www.team-bhp.com/forum/tyre-a...tml#post387487
Old 18th April 2008, 15:55   #119
BAKIYA_2K12's Avatar
I also had a vibration problem in my fiesta at 130Kmph while braking the steering starts to vibrate and the problem was taken care now by custom made hub centric rings.They charged me 1200.
BAKIYA_2K12 is offline   Reply With Quote
Old 25th April 2008, 18:09   #120
theodore_ftw's Avatar
Guys - Quick Question.
I own a Maruti Zen (2003) and have installed BSA Racing Alloys (BSA 229) with Bridgestone 165/65R13 Tubeless Tyres on them. The original rim size was 12' and to install the 13' Alloys i had to raise the car (Added spacers into the Shocks). I was going through this post and found a similar problem that i have been facing (Vibrations > 80Kmph). For this particular model of Alloys the PCD is mentioned as 98mm - 114.3mm (Not sure why there is a range provided here) and my Zen has a PCD of 98mm. I'm not too sure if the vibrations are because of the difference. I keep getting my wheels balanced at regular intervals so i dont think its because of that. Also if i need to install Hub Centric Rings, someone please guide me to a guy who can make them in Hyderabad.
Thanks!
theodore_ftw is offline   Reply With Quote
Alloy Wheels - Sai Mag Wheels (Rama Road Industrial Area) tsk13 Delhi NCR 39 12th March 2018 12:24
Problem with my i20 head-unit after installing HID's nikibusa Technical Stuff 24 28th February 2014 09:46
Reset ECU after installing K&N PatienceWins Technical Stuff 20 6th July 2010 16:15
Part 2: Update to Solution for vibrations after installing alloy wheels sAP Tyre & Alloy wheel Section 10 17th December 2009 11:20
Vibrations after upsize Knight Rider Tyre & Alloy wheel Section 14 21st June 2006 20:56
