Old 8th April 2012, 19:55   #61
Epic's Avatar
Thanked: 422 Times
Default re: VW Polo : Tyre & wheel upgrade thread
Originally Posted by Harshavarthan View Post
If you are not planning to change your stock alloy rims which I believe is 6J size or less, stick to 195/60 section tyres. Though theoritically you can fit 205 section, it is not advisable.
Any particular reason for this?
Epic is offline   Reply With Quote
Old 8th April 2012, 20:36   #62
Harshavarthan's Avatar
Thanked: 110 Times
The side wall flex will be more. Google for rim size vs tyre size and you will have a clear idea. Also getting an after market rim of 6J or less is also not easy. I tried a lot to find a 6J size rim for my 195 section tyres but finally settled with 6.5J Lenso.
Harshavarthan is offline   Reply With Quote
Old 30th April 2012, 21:45   #63
Thanked: 53 Times
Hi all,
I was contemplating on a wheel upgrade for my Polo TDI trendline. While doing calculations I noticed something wierd. The polo highline sits ~14mm higher than a trendline or comfortline according to my calculations.
Highline:
R15 = 381mm
Sidewall height = 60% of 185 = 111mm
Total height = 381 + 111 = 492 mm
Trendline/Comfortline:
R14 = 355.6mm
Sidewall height = 70% of 175 = 122.5mm
Total height = 355.6 + 122.5 = 478.1
What am I doing wrong?
Ph03nix is offline   Reply With Quote
Old 1st May 2012, 13:49   #64
Thanked: 110 Times
You are definitely wrong. Check with the tyre size calculator.
www.etyres.co.uk/tyre-size-calculator.htm
Old 15th May 2012, 17:09   #65
Epic's Avatar
Thanked: 422 Times
Hi guys,
I desperately need help with upgrading my tyres on my Polo 1.6. I have been searching for the 205/55/R15 size and the only tyre availble with this size are the Yokohama S-Drives. Apparently no other brand seems to have this size and I have checked with almost all well known tyre shops in Mumbai.
What is going on? This is driving me nuts!!
Old 25th May 2012, 00:20   #66
himanshu_j's Avatar
Thanked: 125 Times
Originally Posted by Epic View Post
Hi guys,
What about Continental CPC2? Check out changemytyre.com
OT: Did you end up upgrading to 205/50 R16s on your swift?
himanshu_j is offline   Reply With Quote
Old 26th May 2012, 14:02   #67
Epic's Avatar
Thanked: 422 Times
As per reviews CPC2 don't cut it. My Swift had 205/55/R15.
I think I may end up with 16" rims on my Polo
Old 26th May 2012, 14:12   #68
himanshu_j's Avatar
Thanked: 125 Times
I am assuming you are going with 205/50 R16s. Are you getting the S drives?
Old 28th May 2012, 16:42   #69
Epic's Avatar
Thanked: 422 Times
Well the size is spot on and S-Drives are an option. Other options are Michelin and Pirelli
Old 28th March 2013, 16:49   #70
abattoir's Avatar
I need some advice on upgrading the tyres in my polo 1.2 tdi. Right now I have the stock 14" 175/70. I used a calculator and according to that 14" 205/60 is also a nice fit. My question is that will it be an overkill for polo? And would the tyres be rubbing against the sides?
abattoir is offline   Reply With Quote
Old 28th March 2013, 23:13   #71
himanshu_j's Avatar
Thanked: 125 Times
Originally Posted by abattoir View Post
Probably an overkill for the TDI as 205 patch is quite wide and will affect both fuel economy and performance. Also see if the narrow rim width of your steel wheels falls within the recommended range for 205s.
himanshu_j is offline   (1) Thanks Reply With Quote
Old 29th March 2013, 15:47   #72
abattoir's Avatar
I have HRS alloys and according to the tyre dealer 205s would fit well on them. If not 205 then how about 195/65? You think they would be any good?
Old 13th April 2013, 10:16   #73
himanshu_j's Avatar
Thanked: 125 Times
I think 195/65 will be a better bet as you will have a wider range of tyre options and maximum sidewall height of -4.99". Do share pictures with us after the upgrade!
Old 16th June 2013, 18:17   #74
mohandasnikhil's Avatar
Thanked: 240 Times
Had got a Polo TDi Trendline last year, and apart from an Audio System and Rear Parcel Shelf hadn't done much else to the stock car. The car was primarily my wife's drive and I used the Fluence and now the Bimmer. I found the Polo and nice lil city run about and for the past year have been procrastinating about a few minor upgrades;
1. Getting the door handles and mirror painted white
2. Tyres and Alloy upgrade.
Never got down to doing it though.
Cut to now, and am beginning to drive and appreciate the Polo a bit more now. Even though I love driving the Bimmer, I don't want to be putting too many kms on it; cos service and maintenance costs are high and I don't want to reduce the resale value of the car much. The problem was that the stock Polo looked a lil dreary with it's puny tyres and black handles, and I didn't like the base variant image.
Last week my wife met with a small accident that necessitated the change of the front bumper, so I took the chance when the car was in the workshop and got the door handles and mirrors painted. This just whet my appetite and I have been looking for a decent pair of alloy wheels for the car. Like many have pointed out on this thread, it is difficult to get Alloys for the car, but finally managed to find a pair that I liked. I wanted a size upgrade so got a 15inch Alloy wheel, with a VW cap. (The Alloys are Chinese and only have the VW Symbol, so they do tend to look Company OE). Changed up the tyres to 195/60 R15s Yokohoma ES100. Ride Quality and Handling has seen an immediate change.
Here are some pics
mohandasnikhil is offline   (1) Thanks Reply With Quote
Old 18th June 2013, 12:22   #75
abattoir's Avatar
I still haven't upgraded the tyres as they are good to go a few thousand km's. Will post a picture once I upgrade them. Here is a picture of my current wheels.
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 15 15th June 2018 16:33
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
Hyundai i10 : Tyre & wheel upgrade thread carZest Tyre & Alloy wheel Section 607 25th April 2017 19:32
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
