Old 1st July 2013, 14:39   #76
Epic's Avatar
Thanked: 421 Times
Default re: VW Polo : Tyre & wheel upgrade thread
Hey guys!!
After all the possible research, I have still not upgraded my tires yet and one of the major reasons is my confusion in the size. Owing a Polo 1.6 Highline with a stock size of 185/60/R15, I know that the best possible sizes are 195/60/R15 & 205/55/R15 with the latter being closer to stock. But I am concerned whether 205s would be an overkill for the car? Besides the 205/55 size only available with Yokohama S-Drives.
I have now come across another size which is 195/55/R15 which is also more suitable and would not be an overkill to the car. Here are the difference in circumference percentage wise with respective sizes:
195/60/R15 : 1.99%
195/55/R15 : -1.24%
205/55/R15 : 0.58%
What do you guys think?
Epic is offline   Reply With Quote
Old 1st July 2013, 15:34   #77
Nikhilb2008's Avatar
Thanked: 6,379 Times
205/55-15 is definitely overkill.
I will always suggest 195/60-15 because your GC and ride comfort will be better and it is more than enough for almost any type of driving. Also, 195/60-15 has more options for you to choose from.
Old 2nd July 2013, 16:43   #78
Epic's Avatar
Thanked: 421 Times
Hey Nikhil 2008! So which tyre brand do you recommend? Michelin?
Also 195/60/R15 has the highest error among the three.
Old 2nd July 2013, 17:27   #79
Rajesh Rawal's Avatar
Thanked: 153 Times
Pardon my ignorance but woudn't gc remain the same if you have upgrade to say 195/60 ,if it was 195/65 then gc would increase right?
Rajesh Rawal is offline   Reply With Quote
Old 2nd July 2013, 18:07   #80
I was comparing 205/55-15 with 195/60-15.
195/60-15 has a higher sidewall height. So, GC will be higher. If you compare 195/65-15 with 195/60-15, then 195/65-15 will have a higher GC.
It may have the highest error but keep in mind that statistics can be used either way. in the real world, the extra rubber would be benficial.
I wouldnt recommend any brand blindly. Depends on your usage and requirements.
Old 3rd July 2013, 13:59   #81
Epic's Avatar
Thanked: 421 Times
Ok here is the thing. I have used a 195/60 (Goodyear F1 & Apollo Accelere) and a 205/55 (Yokohama S-Drive) size on 15" rims on my previous car which was a Swift. The 60 profile was more comfortable of course but didn't give a sporty look as compared to the 55 profile. The S-Drives also had a brilliant tread pattern which is also something I am looking at for the Polo.
My requirements are in the following order:
- Ride Comfort & Grip in wet and dry
- Looks in terms for sporty tread pattern and profile
Visited the following websites and here are my findings:
195/60/R15
Michelin
- Primacy LC (Plain Tread Pattern)
Bridgestone
- Ecopia EP100A (Plain Tread Pattern)
- Potenza GIII (Sporty Tread Pattern)
- Potenza MY-01 (Sporty Tread Pattern)
- Turanza AR10 (Plain Tread Pattern)
- Turanza ER60 (Plain Tread Pattern)
- Potenza MY-02 (Sporty Tread Pattern)
- Potenza RE88 (Sporty/Plain Tread Pattern)
Yokohama
- A-Drive (Sporty Tread Pattern)
- AVS Decibel (Sporty Tread Pattern)
- C-Drive (Sporty Tread Pattern)
- ES 100 (Sporty Tread Pattern)
195/55/R15
Michelin
- NOT AVAILABLE
Bridgestone
Yokohama
- S-Drive (Sporty Tread Pattern)
205/55/R15
Michelin
- NOT AVAILABLE
Bridgestone
- NOT AVAILABLE
Yokohama
- S-Drive (Sporty Pattern)
Now taking into account that the 205s are an overkill for the car I will need to look at a 195/60 OR 195/55 set of tires. Further that I am looking at ride comfort and sporty looks; I would need to choose between the Yokohamas & Bridgestones.
What would you suggest now?
Epic is offline   (1) Thanks Reply With Quote
Old 3rd July 2013, 16:02   #82
Ride comfort and sporty looks rarely go hand in hand.
Pick one then the choice will be easier.
195/55-15 is not recommended as that is the technically wrong size and the ride quality will be quite terrible!
Old 3rd July 2013, 16:39   #83
Epic's Avatar
Thanked: 421 Times
Hi Nikhil. I am confused. Why is 195/55 a wrong size when it has a marginally lesser error than the 195/60?
In that case the 205/55 would be my choice.
Old 3rd July 2013, 16:50   #84
5% lesser is not a marginally lesser error!
If you want 205/55-15, then the S Drives is your only decent option.
Old 3rd July 2013, 20:23   #85
Epic's Avatar
Thanked: 421 Times
5% error? I think you have made some mistake. Here are the errors for all the sizes:
Stock size is 185/60/R15
195/60/R15 : 1.99%
195/55/R15 : -1.24%
205/55/R15 : 0.58%
I am also surprised to see that none of the top brands like Michelin, Goodyear, Yokohama or Bridgestone have the 185/60/R15 size!!
Old 3rd July 2013, 20:37   #86
mroptimist's Avatar
Thanked: 361 Times
Post re: VW Polo : Tyre & wheel upgrade thread
195/60/R15 : 1.99%
195/55/R15 : -1.24%
205/55/R15 : 0.58%
Hi epic I am also in the same boat as you. Even I own a car with this unfortunate stock size 185/60 R15 (Etios VX). No good tyres in this size, only slightly better tyres are Bridgestone Turanza ER300 and I am not too happy with them. They wore out pretty fast (33,000 on the odo) plenty of tyre noise and okay grip. Not so puncture resistant also.
I want to upsize to 195/60 R15 Bridgestone Turanza ER60 88H but unfortunately no dealer seems to have them in stock. When I called up Bridgestone office they were also not sure about when they will be available. Bridgestone toll free number does not work. This company seems to care least about India.
No Michelin XM2 also in this size but they have in Swift ZXi/ZDi size, 185/65/R15 which is not the recommended size for Etios (odo error ~3%).
Thoroughly frustrated.
mroptimist is offline   Reply With Quote
Old 3rd July 2013, 20:52   #87
Epic's Avatar
Thanked: 421 Times
Had mentioned this in my post above but re posting for your convenience. These are the acceptable upsizes available in the top brands for a stock 185/60/R15 tyre.
195/60/R15
Michelin
Bridgestone
Yokohama
195/55/R15
Michelin
- NOT AVAILABLE
Bridgestone
Yokohama
205/55/R15
Michelin
- NOT AVAILABLE
Bridgestone
- NOT AVAILABLE
Yokohama
Epic is offline   (3) Thanks Reply With Quote
Old 22nd July 2013, 13:08   #88
Thanked: 7 Times
Does the upgrade from 185/60 R15 to 195/60 R15 has any substantial effect on the fuel efficiency? Say 1 or 2 kms drop? I am getting my Polo Petrol HL with 185/60 R15 OEM this week and I am planning to go for 195/60 R15 Bridgestone Turanza EF60.
Any one has done this specific upgrade? Howz the overall experience? The upgrade is going to cost 10K. Is it worth?
alexanish is offline   Reply With Quote
Old 22nd July 2013, 21:32   #89
mroptimist's Avatar
Thanked: 361 Times
Thumbs up re: VW Polo : Tyre & wheel upgrade thread
Originally Posted by alexanish View Post
Does the upgrade from 185/60 R15 to 195/60 R15 has any substantial effect on the fuel efficiency? Say 1 or 2 kms drop? I am getting my Polo Petrol HL with 185/60 R15 OEM this week and I am planning to go for 195/60 R15 Bridgestone Turanza ER60.
Anyone has done this specific upgrade? Howz the overall experience? The upgrade is going to cost 10K. Is it worth?
I have driven around 1000kms in my car after upgrading from stock size Bridgestone Turanza ER300 185/60/R15 84H to Bridgestone Turanza AR10 195/60/R15 88V. Here are my brief observations:
1. Steering response: slightly heavier.
2. Drivability: much better especially on pot holed ridden roads.
3. Tyre noise: less but still not as much as expected. {By the way tyre noise is always relative}.
4. Road grip: excellent on both wet and dry surfaces (stock tyres' grip was not too bad either).
5. Effect on fuel efficiency: apparently not significant. (Disclaimer: I have not calculated F.E strictly, too lazy to do it).
6. Conclusion: If I had foresight that drivability of my car would improve so much by putting upgraded and better rubber I would have got it done immediately after purchase of my car.
For cars with stock size 185/60/R15 upgrading to 195/60/R15 is the perfect upsize, don't hesitate go for it. You did not mention what tyres come as stock (not just size but brand etc) in your car.
Bridgestone Turanza ER60 are all rounder tyres with at least 50,000kms durability, so infact you will be gaining overall.
You can also wait a week for new tyres from Bridgestone, Turanza AR20 which are I think better than ER60.
Hope it helps.
mroptimist is offline   (1) Thanks Reply With Quote
Old 23rd July 2013, 12:20   #90
Thanked: 7 Times
Hope it helps.
You came from the same Turanza brand and there is a noticeable difference? So I guess even different series of same brand have vastly different characteristics. I was informed by the VW sales person today that once I go for profile change the warranty will become void. That mean I may have only few options to change to a better tyre like ER300, if its still available. By the way, the stock tyres I will be getting is Apollo Acelere (185/60/R15).
If AR20 is a new entry to our market, then I suppose it must be costly. If it has 185/60/R15 then I will pick it, even if its slightly costly
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 12 20th March 2018 21:25
Hyundai i10 : Tyre & wheel upgrade thread carZest Tyre & Alloy wheel Section 607 25th April 2017 19:32
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
