Old 22nd October 2014, 19:04   #106
karizma9292's Avatar
Thanked: 210 Times
Default re: VW Polo : Tyre & wheel upgrade thread
Hello BHPians , booked a polo 1.5 TDi comfortline . Looking to upgrade the wheels , presently it comes with 185/60-15 . Please help me with the pros and cons of the mentioned upgardes , 205/55-15 or 205/50-16.
karizma9292 is offline   Reply With Quote
Old 23rd October 2014, 12:29   #107
Thanked: 210 Times
Originally Posted by F2005 View Post
Thanks, I went to Madhus and changed to 205/55 R15.. The car looks sexy now
Hey F2005 , the tyre upgrade looks good from the back . Is it on stock wheels or aftermarket alloys? Could you post close up pics from the side
Old 27th October 2014, 14:00   #108
F2005's Avatar
Thanked: 55 Times
Hi Karizma,
The tires are on stock 15` wheels. Hope this pic helps.
VW Polo : Tyre & wheel upgrade thread-ed.jpg
F2005 is offline   (1) Thanks Reply With Quote
Old 28th October 2014, 12:33   #109
Thanked: 210 Times
Hi Karizma,
Looks good buddy , What is the difference you feel in terms of ride quality , handling , fuel efficiency after changing to these from 185/60-15 Apollo tyres ?
Old 28th October 2014, 14:16   #110
F2005's Avatar
Thanked: 55 Times
I changed the tires on the delivery day itself. So, can't comment on the stock Apollo tires.
Coming to the S-Drives, the car has done 3600 kms and I feel the grip is more and the car feels more planted at high speeds and cornering. I am getting a fuel efficiency of around 18 kmpl average with equal city and highway driving.
The tire noise is also less now. Have to see when more kilometers are done.
F2005 is offline   Reply With Quote
Old 26th February 2015, 20:32   #111
Thanked: 114 Times
Guys need some advice on Polo tyres.
I just had my 3rd servicing at 34k kms. Service personnel mentioned that there is some wear on front two tyres, even though he said they will probably do another 10k kms.
I later went to a wheel balancing center and even the mechanic there mentioned that there is some wear on the tyres and may need to change in next few thousand kms.
My question is that what is a general life of the OEM tyres. I generally drive in the city with 2-3 yearly long drives. I do use a lot of engine braking (VW said that my brakes are still good for another 15k kms at my 3rd service). - just to give you a reference of my driving and hence tyre wear.
What can I expect a normal life in kms for the tyres?
Second question is that what size should I change to - 170/70 or upgrade to 185/65 (I do not plan on buying alloys, will retain the 14 inch steel rims). There is also 195/60 but that may be too much for the power at hand.
Given these size options, should I retain the Acelere (or Alnac) or is there a better choice for these sizes?
vivekz is offline   Reply With Quote
Old 26th February 2015, 21:08   #112
Thanked: 114 Times
Adding tyre size calculations. Please advice.
VW Polo : Tyre & wheel upgrade thread-polo-tyre-calculator.jpg
Old 26th February 2015, 23:06   #113
Schoudhury's Avatar
Thanked: 470 Times
185/65/14 should be good. And tyre life depends on a lot of factors, but 40k kms is also not bad. I will suggest rotate the tyres and use the tyres for 5-6k kms more and then change them .
Schoudhury is offline   (1) Thanks Reply With Quote
Old 4th March 2015, 14:46   #114
Thanked: 114 Times
Yes I have rotated them, generally have followed a 6-7k interval for balancing and rotation.
Now they should work till around 40k.
Any suggestions on the tyre make and model?
Old 7th May 2015, 12:55   #115
Thinking of upgrading Polo Highline's stock Acelere 185/60 R15 to MRF ZSport 205/55 R15. Any reviews/suggestions?
nvssudheer is offline   Reply With Quote
Old 8th May 2015, 01:13   #116
Thanked: 870 Times
Reading this thread it seems that the 185/60 R15 and 195/60 R15 are both valid upsize alternatives for the Trendline (replacing the stock 14 inch rims with 15 inch).
I am, however surprised, that changemytyre.com does not mention the 195/60 R15 as an alternative. It lists the 195/55 R15 and 205/55 R15 as choices (within 15 inch).
To add to the confusion, forum member Nikhilb2008 had earlier posted on this thread that
"195/55-15 is not recommended as that is the technically wrong size"
"205/55-15 is definitely overkill."
Now I am confused. Are these two sizes unfit for the Polo with 15 inch rims?
I am leaning towards the 195/60 R15 for the extra ground clearance but if its a no-no will settle for the 185/60 R15.
Kumar R is offline   Reply With Quote
Old 8th May 2015, 07:14   #117
deetjohn's Avatar
Thanked: 8,008 Times
The Trend is 175/70 R14 right?
You can pick from
1) 185/60 R15
2) 195/55 R15
2) 205/55 R15
All are well within the safe upgrade limits. The new 1.5L Diesel engine can take the extra load from 205. So, no need to shy away from that.
195/60 is a wrong upgrade as its outside the safe limit of 2%. Is simply too tall a tyre for the Polo.
My pick would be the 195/55. The only problem is the lack of options.
deetjohn is offline   (1) Thanks Reply With Quote
Old 8th May 2015, 09:51   #118
Vik0728's Avatar
Thanked: 2,301 Times
+1 to deetjohn.
The beauty about the German and Japanese cars is no matter how high you go with the tire upgrade (within sanity of course), they do not protrude out of the chassis.
W.r.t the 1.5 TDi, it can easily handle 195 & 205 width tire without any major issues on both performance & economy.
I personally recommend 205/55/R15 (if you are looking to upgrade to 15") as I have been using it for over 15K kms on my GT and have had no issues. Its a decent balance between performance & comfort, and I think also looks aesthetically much better .
Vik0728 is online now   (1) Thanks Reply With Quote
Old 8th May 2015, 20:18   #119
Thanked: 870 Times
Originally Posted by Vik0728 View Post
+1 to deetjohn.
Thanks, deetjohn and Vik0728. Much appreciated.
Yes, Trendline stock is 175/70 R14.
Both these options (195/55 R15 and 205/55 R15) appear attractive.
195/55 has 0.51 cm less diameter than my 175/70 R14 stock tyres so my hope of adding a little Ground Clearance will be dashed.
205/55 -- Seems ideal (and adds 0.60 cm ground clearance) but reading your replies I'm not sure it should be mated to my 1.2 L standard Petrol engine.
Old 8th May 2015, 21:49   #120
deetjohn's Avatar
Oh! Don't put the 205 for the 1.2L petrol variant. That car will lose all its peppiness.
And please note, whatever that you might gain by an upsize will go away once the tread wears. But if you want 195/55 R15 so badly, go for it and bump up the air pressure by a bit, if loss in Ground Clearance is a big concern.
My suggestion will be 185/60 R15 all things considered.
deetjohn is offline   (2) Thanks Reply With Quote
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
Hyundai i10 : Tyre & wheel upgrade thread carZest Tyre & Alloy wheel Section 607 25th April 2017 19:32
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
