Old 19th December 2005, 15:55   #1
Smile Tyre pressure - Getz GLS
Hi all,
i recently upsized my 13" 175/70R13 stocks with 14" alloys and 185/60R14 tubless Goodyear Ducaro. Arguably since my profile has been reduced by 11.5 mm the ride quality is suffering considerably... Have reduced the tyre pressure from 30psi to 28psi on all 4 tyres. Still the ride is pretty much harsh even when there are 5 passengers...
What would be the ideal pressure so as to reduce the harshness... Is a change of size to 185/65 required or must i reduce the trye pressure still further. How will this affect my millage..
GetzUThere.
GetzUThere is offline   Reply With Quote
Old 19th December 2005, 16:24   #2
speedsatya's Avatar
Thanked: 712 Times
Originally Posted by GetzUThere
Hi all,
GetzUThere.
you have got the right upsize ...but never reduce the tire pressure ...infact as u go lower down the profile ...an increase of 1-2 psi is recommended...underinflation is one of the main reasons of tires bursting at high speeds...
and ur side wall is 185X0.6=111mm instead of 175x.7=122.5mm...so thats the reason for that harsh ride .....but dont reduce the tire pressure
speedsatya is offline   Reply With Quote
Old 20th December 2005, 16:19   #3
Thanks for the inputs. But raising the tyre pressure would make the ride harsher. Most of my driving is gonna be city driving that too Mumbai .... Bumper to Bumper... with the lovely poth-holes to accompany me
Old 21st December 2005, 10:14   #4
viper's Avatar
Thanked: 9 Times
Hey,
Tyre pressure will not solve your problem. It is your tyre which is the culprit. The Ducaro is a hard compound tyre hence your problem.
Viper
viper is offline   Reply With Quote
Old 21st December 2005, 13:01   #5
Originally Posted by viper
Hey,
Viper
Hey Viper...
if ducaro is hard, then which goodyear tyre would be better... i believe F1 would be even harder and also unidirectional which i dont require since i have almost nil highway driving...
thanks
Old 26th December 2005, 18:52   #6
sAP
sAP's Avatar
Thanked: 16 Times
Your sidewall is still a pretty good 4.4"; IMO not that *bad* enough to cause *such* a hard ride. Sorry I am clueless.... maybe its the tires afterall (*I am guessing here*).
Why don't u look up the tire bible here http://www.carbibles.com/tyre_bible.html and see if anything lights up.
sAP
sAP is offline   Reply With Quote
Old 26th December 2005, 20:07   #7
.anshuman's Avatar
Thanked: 9,158 Times
go for the pressure suggested in the owners manual.
Old 26th December 2005, 22:19   #8
kpzen's Avatar
Thanked: 1,655 Times
After having done a tyre upsize you cant follow the manual which is applicable only for the stock wheel dimensions...
KP
Old 27th December 2005, 00:58   #9
.anshuman's Avatar
KP
but tyre size has nothing to do with tyre pressure.
Old 27th December 2005, 08:51   #10
kpzen's Avatar
When we upsize the tyre the sidewalls decrease to keep the same the OD.... Hence the flexing area of the rubber also decreases..
Earlier i had 145/80-12 in my zen and kept the pressure level 24-26 psi as recommended in the manual...Then i got upsized tyre to 165/65-13 and now i'm maintaining a min of 28psi and 30psi for highways..
KP
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
getz GLS to getz GLX or i10 kappa? filcord Hatchbacks 36 30th August 2009 18:28
WANTED: Hyundai Getz GLS in Delhi amitverma Shifting gears 2 25th January 2008 11:32
Getz Prime tyre pressure ??? mogambo Technical Stuff 1 13th December 2007 11:45
Buying a Getz...GLS now or GVS after new year ? gulgulumaal Hatchbacks 28 11th January 2007 16:01
