Old 17th August 2013, 09:28   #166
Thanked: 1,221 Times
Default re: Skoda Yeti : Tyre & wheel upgrade Thread
My Latitude Tour HP update - one year and 25k kms later, the ones at the front are completely bald and resemble doughnuts. The ones at the rear, which were rotated from the front at about 13k, are only slightly better.
I need new tyres. Do not use this to evaluate the tyres in question without considering the fact that I have never crossed 30k on a set of tyres across several vehicles and tyre brands - my style of driving seems to be rather tYresome.
Steeroid is offline   Reply With Quote
Old 17th August 2013, 13:30   #167
Simple_car's Avatar
Thanked: 529 Times
I have the latitude hp's on my car as well (not the yeti). I have done ~15k kms since installation. I am overall very impressed with the tyres. They will last another 15k kms for sure. Just wanted to know, how did you find these tyres at the end of their lives? Like did the puncture rate increase, or did the tyre noise increase drastically? How would you rate these compared to the other options available?
Thanks,
Simple_car
Simple_car is offline   Reply With Quote
Old 19th August 2013, 14:23   #168
Sheel's Avatar
Thanked: 3,934 Times
Default re: Skoda Yeti : Tyre & wheel upgrade thread
Originally Posted by Nikhilb2008 View Post
Which Michelin?
Latitude Tour HP Tires.
Old 27th August 2013, 14:43   #169
deutscheafrikar's Avatar
Thanked: 297 Times
Originally Posted by iTNerd View Post
Thanks everyone! phew!!
I must say, I was very nervous of zeroing on Geo HT, because there was no reference point for these Geolander HT and all I read are some reviews from some international websites. My main worry is if I would get stuck with a tyre with too much road noise, or with soft sidewalls
Originally Posted by abbey4u View Post
Today it was my turn to go with yoko geo tyres. Thanks to iTNerd i got it changed from the same dealer. Similarly also went for dension five bluetooth module. It can also be switched off and the system will behave like stock factory
Hi iTNerd & abbey4u
I need to buy new tires since the Goodyears have done 44K now, even though they aren't bald yet.. Whats the verdict on the H/T - S G051 ? How many Kms so far on them?
deutscheafrikar is offline   Reply With Quote
Old 27th August 2013, 17:31   #170
abbey4u's Avatar
Thanked: 100 Times
Originally Posted by deutscheafrikar View Post
Hi iTNerd & abbey4u
I have completed 35k and it should be good for another 10-15k. I would recommend them
abbey4u is offline   (1) Thanks Reply With Quote
Old 27th August 2013, 22:24   #171
Thanked: 297 Times
Default Re: SKoda Yeti : Tyre & wheel upgrade Thread.
Please don't go in for the primacy LC for the yeti. The yeti is a heavy car borderin on being an SUV.
It is really sad to see this situation. First of all, the Yeti's size (215/60-16) is a weird size. Youy'll be forced to use car tyres on a heavy almost-SUV.
Hi Nikhil
A Year and a half later what are the options? Was interested in the Yoko's H/T-S G051 but theY seem to be Grey market tires so I can't find any out here. Suggestions?
Old 28th August 2013, 10:41   #172
Nikhilb2008's Avatar
Thanked: 2,603 Times
Well, right now Goodyear Assurance is available.
The Michelin Latitude Tour HPs are available in 215/65-16. Pirellis are available in 235/60-16.
215/60-16 still has a lack of great ootions.
Old 28th August 2013, 11:32   #173
Akshay1234's Avatar
Thanked: 5,337 Times
Nikhil what do you think of CPC2s in 225/55 R16? For regular commuting + some rough roads. No real off road per se.
Old 28th August 2013, 11:39   #174
It should be good! I have always liked the CPC2 and it's ruggedness. I think the CPC2 would be good on the Yeti as long as one is aware of it's limitations.
Old 28th August 2013, 11:56   #175
Akshay1234's Avatar
It would be tough enough to not slow down for rough patches, etc right? I don't intend to do rock crawling or anything, but hopefully it can take as much abuse as the stock Goodyear Assurance?
In that case I will probably keep this is mind when the tyre change is due.
Old 28th August 2013, 14:17   #176
Behemoth's Avatar
Thanked: 963 Times
Hi Nikhil,
What is your opinion on Pirelli P7 in 215/60 R16 and Falken AzenisPT722 ? Will they be rugged enough for Indian road conditions?
Both are available here for around 8200-8400 per tyre.
Behemoth
Behemoth is online now   Reply With Quote
Old 28th August 2013, 23:31   #177
Thanked: 297 Times
Hi Nikhil,
Behemoth
Hi Behemoth
I think this one would be what the yeti needs {Falken WILDPEAK HT01 Tubeless P 215/65R 16 98H}
if you are going a size up.
Details
Four large circumferential straight grooves
enhance both anti-hydroplaning and wet grip performance new stylish sidewall design paired with high tension casing ply and special hard bead apex provides good looks and driving comfort
variable pitch shoulder design provides flat, even wear and reduces tire noise
multi-wave lateral spies improves wet traction and increases all-season performance
symmetric non-directional 5 rib tread design
provides optimal handling/stability and comfort, while allowing multiple rotation patterns to help fight irregular wear
UTQG 600-A-B
60,000 miles / 96,000 km limited warranty
I feel the car tire s wont suit it with the slightly heavier weight. Searching searching but not able to get the right size
Old 28th August 2013, 23:48   #178
Hi Nikhil,
Behemoth
The Falken Azenis is a high performance tyre. Sidewalls will be soft and it will not be very good for the Yeti.
The Pirelli P7 should be good though.
Old 29th August 2013, 09:33   #179
Behemoth's Avatar
Thanked: 963 Times
Hi Behemoth
UTQG 600-A-B
Hi deutscheafrikar,
I had seen this option too in the Falken wildpeak, which should be suitable, but what I have heard is that Falken also has a soft sidewall, which also makes it prone to sidewall damage. Good thing though is that when I searched online, I found that Changemytyre is also offering road hazard insurance, which can cover such conditions.
In terms of load bearing capacity, anything above 95 rating is good as the standard OE tyres are 95H rated. 95 rated tyres can take 690 kg per tyre and 98 rated can take 750 kg per tyre, which is more than enough for the Yeti, which has a GVW of max 2075kg for the 140 Bhp 4x4.
If you meant the weight of the Tyre, yes, I also have a concern there as a 215/65 R16 tyre is almost 10% heavier than 215/60 R16, which will definitely put a bit more stress on the suspension.
Thanks for your feedback Nikhil! I am also leaning towards the P7's now if I go for the stock size, else if upsize to 215/65 R16, I may go for Bridgestones. There is a 3% differential in the OD size.
Sheel had put Michelin Latitude Tour HPs on his Yeti in 215/65 R16, which have gone nearly bald in 25K Kms - will this upsize really bring down the life from expected 40K to 25k, or are the Michelins too soft? Will appreciate your expert opinion.
Thanks!
Old 2nd September 2013, 20:03   #180
I havent used the Michelin Latitude Tour HP. It may have worn out in 25k kms due to many reasons but I wont be surprised that the tyre is really that soft! It is a tyre aimed at comfort and grip and not at long life.
Skoda Rapid : Tyre & wheel upgrade thread kryptonite Tyre & Alloy wheel Section 126 28th December 2016 13:52
Toyota Etios & Liva : Tyre & wheel upgrade thread nkrishnap Tyre & Alloy wheel Section 54 27th November 2016 21:38
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
Skoda Laura : Tyre & wheel upgrade thread deepakvrao Tyre & Alloy wheel Section 311 30th July 2016 17:21
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 635 9th February 2016 06:59
