Old 9th June 2015, 11:47   #286
iTNerd's Avatar
Thanked: 503 Times
Default Re: Skoda Yeti : Tyre & wheel upgrade Thread
Almost 2 years and some 50-60k kilometers later, the latitude tour HP's gave away.
Very happy with Michelin and will recommend
But this time, we went with Yokohama Geolander AT. Cost was Rs. 33,000 with alignment & balancing. Michelin were Rs. 15,000 more expensive then, unsure of the cost now.
Yokohamas as of now are as silent as Michelin and ride/handling is the same, but I will provide more details after driving it a bit more.
Full profile car tire photographs will be loaded after sometime, let the weather improve a bit
I had been using the yoko geo HT for 3 yrs (35k Kms) and happy so far. I reckon it still has around 10-15K kms left to be churned out, but I may get the yoko AT too as the HT is prone to frequent punctures (nails) because of soft nature. I will be waiting for your experience with the AT. Congrats.
PS. Did you get the AT at the stock size i.e., 215/60 R16 ? or was it 215/65 R16?
iTNerd is offline   Reply With Quote
Old 9th June 2015, 12:01   #287
Thanked: 1,503 Times
Default Re: Skoda Yeti : Tyre & wheel upgrade thread
Originally Posted by Nisarg80 View Post
Requesting all who have put on 215/65 R16 on their Yeti to post a few pics, just so everyone else who is a little baffled with the question get some confidence and visual appeal of the vehicle.
Visual appeal is not the primary purpose of the tyres on your vehicle. That said, here you go a pic with the nearly bald Latitudes, just before the change to Falkens:
Skoda Yeti : Tyre & wheel upgrade thread-img_1514.jpg
Steeroid is offline   (2) Thanks Reply With Quote
Old 9th June 2015, 14:32   #288
Nisarg80's Avatar
Hello Folks,
I've finally decided to go for Michelin Latitude Tour HP. Primary reason being there are a few people who have positive experience of it on the Yeti and have used it for quite some time now. I am not prepared to experiment as of now (considering my upcoming trips), and hence taking cue from experience and advice of our fellow auto-enthusiasts.
For the spare I was thinking of 205/65 R16, we have couple of tires available in this size, I believe it should fit well and the difference with 215/65 R16 is just -1.90%.
Cheers!
Nisarg80 is offline   Reply With Quote
Old 9th June 2015, 15:14   #289
Sheel's Avatar
Thanked: 4,981 Times
We always wanted 65 section aspect ratio. The Michelin Latitude Tour HP's were 215/65. GC is increased by few mm's and that is a bonus, as is tire availability.
Sheel is offline   (1) Thanks Reply With Quote
Old 19th June 2015, 22:16   #290
iTNerd's Avatar
Thanked: 503 Times
How is your new yoko AT tyres holding up? I know you might have just run few hundred kms since you switched, but just your initial impression would be great
Old 20th June 2015, 10:14   #291
Sheel's Avatar
I haven't really driven the car much after this change, but the driver has. Some 1000 odd kms. He is happy with them as of now.
I hope to drive some 500 kilometers at a stretch soon, will update accordingly.
But tire noise well concealed [considering an AT design] and its grippy + comfortable.
Old 21st June 2015, 15:48   #292
Hi! I need to buy a fresh set of tyres for my Skoda a Yeti. Ca anyone suggest an outlet in South Delhi where I can get some good quality stuff? I'm currently using Goodyear Excellence 215/60 R 60 which have run 55k kilometers and are quite wornout.
IndranilGoswami is offline   Reply With Quote
Old 21st June 2015, 17:38   #293
Behemoth's Avatar
Thanked: 1,576 Times
Hi IG
Welcome to TBHP!
You can refer back a few pages on this thread. Most Yeti owners have gone for either Falken HT in 215/65 R16 or Michelin Latitude Tour HP. In stock size you can go for Falken Azenis or Bridgestone ER370. If you upsize to 215/65 R16 the ride quality improves and the ground clearance also increases by 10mm. There is a good outlet called BK tyres in Lajpat nagar where you can go to check out tyres.
Behemoth (Sameer)
Behemoth is offline   Reply With Quote
Old 21st June 2015, 18:06   #294
Hey mate! Good to bump into you here. Question- if I upsize does'nt it bring errors into the km gauge?
Old 21st June 2015, 19:34   #295
Behemoth's Avatar
There is a deliberate error margin of 5% built into the speedo to overreport speed (to prevent overspeed fines) so actually speedo will become more accurate. The odometer will be 3% off as the bigger tyres have a 3% bigger circumference. It will show 3% less kms covered than actual, which is not that bad an error margin.
Old 22nd June 2015, 16:41   #296
Ok. And I don't have to change my alloy wheels?
Old 22nd June 2015, 16:57   #297
Behemoth's Avatar
Not at all, the rim size is the same, only the aspect ratio of the tyres is different.
Old 22nd June 2015, 17:34   #298
And it will fit in the trunk?
How would you compare the upsized Falken HT with the Goodyear Wrangler HP A/W. Both are 215/60 R16. The latter has a Kevlar layer.
Last edited by ampere : 22nd June 2015 at 20:49. Reason: merged back to back posts
Old 22nd June 2015, 18:40   #299
Behemoth's Avatar
Avoid the Goodyear Wrangler at all costs! They are quite a few cases of tyre hardness and early failure. The Michelins and the Falkens are much better.
Also for your spare retain one of the existing 215/60 R16 tyres as the bigger ones dont fit easily (they do squeeze in if you remove the plastic retainer screw and the side storage tray).
Old 23rd June 2015, 17:26   #300
mailtosid's Avatar
Did not do much of driving for the past few days and managed only 1k kms after the tyre switch to Falken HT, but my initial impression is the ride is quiet and handles well on straight roads. I do not somehow get the confidence while cornering with these tyres but will confirm after some more driving.
mailtosid is offline   Reply With Quote
Skoda Laura : Tyre & wheel upgrade thread deepakvrao Tyre & Alloy wheel Section 319 18th January 2018 20:38
Skoda Rapid : Tyre & wheel upgrade thread kryptonite Tyre & Alloy wheel Section 137 16th October 2017 17:28
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
