Old 19th June 2012, 18:55   #76
abbey4u's Avatar
Thanked: 107 Times
Default re: Skoda Yeti : Tyre & wheel upgrade Thread
how is yoko A drive in comparison to C drive. Both in terms of variation and noise factor
abbey4u is offline   Reply With Quote
Old 19th June 2012, 19:12   #77
Behemoth's Avatar
Thanked: 1,576 Times
A Drives are also fine, but rated lower in terms of load and speed rating and performance than C Drives. They are also cheaper than C drives.
I would recommend Conti CPC2 in case you are not able to get the C drives. The CPC2 also in this size are 99V XL rated and should be good
Behemoth is online now   Reply With Quote
Old 2nd July 2012, 18:52   #78
twinoctober's Avatar
I am in search of Tyres for my Yeti. After being on the phone for most part of the day No one has a solution. Available(read common) tires profiles are not yeti specific, now my only option is to source Apollo 225/60 R16. I am sure i dont want to drive on OEM tires. Well i have never driven on OEM tires to be honest. I have got in touch with my reliable source hope he gives me some good news before weekend.
twinoctober is offline   Reply With Quote
Old 3rd July 2012, 16:15   #79
iTNerd's Avatar
Thanked: 503 Times
I got to know an importer in delhi who informed me they have Yokohama Geolander 051 (HT) in 215/60/16. But I don't know about the speed rating and load ratio. It says, HT, I am told it is an SUV tyre. Any tyres Guru, please give your comments on this tyres for the yeti.
iTNerd is online now   Reply With Quote
Old 3rd July 2012, 17:25   #80
shankar.balan's Avatar
Thanked: 5,331 Times
HT stands for Highway Terrain.
These will be tougher than the stock OEM Yeti tyres.
Plus Yos have a good reputation.
I would buy these because of the very bad roads in and around Bangalore that I drive around on, daily.
The size is correct as per the stock size so there should not be any problem with warranties etc.
Old 3rd July 2012, 17:36   #81
Thanked: 651 Times
There are various brands discussed here, such as Michellin, Yokohama, Bridgestone, Pirelli etc. Out of these which would be the best to go for, assuming you want a tough tyre that you can drive on rough roads and at high speeds on the highway?
Which is a good tyre & wheel shop in Bangalore?
nitinbose is offline   Reply With Quote
Old 3rd July 2012, 17:42   #82
Suggest you PM nikhilb2008 our resident tyre expert. Of the shops, Madhus in Richmond Road is great as is the TyrePlus shop in HSR Layout. TyrePlus is a chain. Madhus is a standalone where you get excellent personal service. i like them very much and have been using them consistently for years ut now have become lazy and this is why I go to TyrePlus near my home nowadays.
Old 3rd July 2012, 18:04   #83
iTNerd's Avatar
Thanked: 503 Times
I am given the options of Yoko Geolander 051 (HT tyres) and yoko db ES-501 (summer tyres). The dealer is recommending the later, as he says, its very quite, whereas the geolanders are very noisy. Wanted to know how noisy would it be with the HT tyres? The yeti is pretty good in NVH, so I am assuming most of the noise would filter away inside the cabin. what say?
Old 3rd July 2012, 18:09   #84
Behemoth's Avatar
My recommendation is for the HTs if you can get them. The DNA decibels are too road biased and won't be any good off road and would get damaged.
Behemoth is online now   (1) Thanks Reply With Quote
Old 3rd July 2012, 18:24   #85
iTNerd's Avatar
Thanked: 503 Times
Just ordered 5 pieces of geo 051, for fitting tomorrow. I am getting a buyback of 5500 for the stock tyres.
Old 3rd July 2012, 18:48   #86
Good choice on that. Also very lucky you got these tyres as they are pretty rare overall to find in the size the Yeti requires!
Enjoy!
Old 3rd July 2012, 20:20   #87
Thanked: 24 Times
Congtrats iTNerd..welcome to the Yeti Club
..and another congrats on getting the right tyre for the Yeti. Most of our roads need this tyre.
contessa is offline   (1) Thanks Reply With Quote
Old 3rd July 2012, 20:26   #88
Thanked: 24 Times
Upgrading tyres on Yeti is indeed a huge improvement as Behemoth has already explained. I took the plunge following Behemoth's lead. The upgrade was definetly worth it and makes the Yeti feel more complete. Getting a good tyre is the challenge though !!
I have upgraded to Pirelli P6, which the website indicates can be used for MPVs (not sure it means anything !!) . Its UTQG is only slighly higher than the GY Excellence (Pirelli UTQG is 260) - but the overall ride quality and drivability is a huge improvement.
Thanks Behemoth.
Old 4th July 2012, 23:25   #89
iTNerd's Avatar
Thanked: 503 Times
Finally, got new shoes on my yeti
The tread are thick and I am hoping it would take rough roads with ease. Initial impression is very positive. Very minimal road noise. And I can feel the grip has improved manifold. Handling even beyond 120+ kmph is good. And looks good too
Old 5th July 2012, 03:05   #90
Looks very good indeed.
I am going to use up my OEM GoodYears first and then go for these same Yokos. Hope I get them when I need them!
Skoda Laura : Tyre & wheel upgrade thread deepakvrao Tyre & Alloy wheel Section 317 24th December 2017 18:31
Skoda Rapid : Tyre & wheel upgrade thread kryptonite Tyre & Alloy wheel Section 137 16th October 2017 17:28
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
