Old 8th May 2013, 13:05   #121
Sheel's Avatar
Thanked: 3,934 Times
Default re: Skoda Yeti : Tyre & wheel upgrade Thread
Hi Everyone!
One of the tire on the Yeti has gone bust. The Car hasn't even done 15,000 kms as yet.
Now ideally one would think of replacing all the 4 tires.
My question is, if we wish to replace just one tire, should we get the stock tire (costing approx Rs. 7,000)
In case we need to order a set of 4, what should be it?
The intended use is a mix of both. On very good roads, as well as terrible road & construction sites.
The chauffeur deployed maintains very good average speed, hence am thinking of a strong sidewall tire. Road noise & comfort be damned.
Old 8th May 2013, 16:02   #122
Thanked: 32 Times
Hi Everyone!
Hi Sheel. I have suffered from the same problem and I have done just 7000 Kms. The tyre dealer I know is dead against Goodyear tyres. In fact what he has to say is absolutely scandalous . He says Goodyear provides rusted reinforcement and that he proved it before a GM of Goodyear upon which the company bore the cost of the new tyre.
I would certainly suggest a different company.
Carcrazy60 is offline   (2) Thanks Reply With Quote
Old 8th May 2013, 17:57   #123
iTNerd's Avatar
Thanked: 441 Times
Hi Everyone!
You can also try Yokohama Geolander HT or AT. Last I checked, AT was not available at the Yeti's stock size, so I went with HT. And I am really happy with them. I have done around 11K kms in the last 10 months, and I have not had any puncture or sidewall problem with them. Abbey4u also switched to the same HT tyres at the same time, and he often traveled on long trips and has more mileage than my car. I guess he is happy with the performance of the tyres too.
iTNerd is offline   (1) Thanks Reply With Quote
Old 8th May 2013, 18:56   #124
abbey4u's Avatar
Thanked: 100 Times
Yes, I am pretty happy with those tyres. I have covered 27k till date and looking at the tyre condition it should last atleast 40k
abbey4u is offline   (1) Thanks Reply With Quote
Old 8th May 2013, 18:59   #125
Thanked: 32 Times
Originally Posted by abbey4u View Post
Yes, I am pretty happy with those tyres. I have covered 27k till date and looking at the tyre condition it should last atleast 45k
Which size are those tyres? I have been unable to find them in the stock size. Thanks in advance.
Carcrazy60 is offline   Reply With Quote
Old 8th May 2013, 19:05   #126
Thanked: 1,221 Times
I drove another Yeti with the Goodyear tyres and I agree it would be a good idea to move away. The Michelins on my Yeti feel so much better, but of course they are not stock size and people have misgivings about warranty with the size I have on mine. Try any other brand.
Steeroid is offline   Reply With Quote
Old 8th May 2013, 20:38   #127
shankar.balan's Avatar
Thanked: 4,639 Times
What exactly is 'Rusted Reinforcement' please?
Old 8th May 2013, 21:11   #128
Behemoth's Avatar
Thanked: 963 Times
Radial tyres have an internal structure of steel wire mesh over which the rubber is laid to create the tyres. In this case it seems the wire mesh used was already rusted. This seriously impacts the life of the tyre and when the steel wire breaks at any point, it creates a bubble in the tyre. Failure of the tyre mesh in multiple wires simultaneously causes a tyre burst, typically at high speeds, which can be catastrophic.
Behemoth is online now   (1) Thanks Reply With Quote
Old 11th May 2013, 17:51   #129
Sheel's Avatar
I thought iTNerd & abbey4u were using Michelins. I was somehow apprehensive of Yokos because of the fear of soft side walls, but because you guys are using it, may be I will scour for it.
What is the model no.? Tire size is the same? Approx cost?
Steer, you are using Latitudes? Drove any Yeti with Yokos? How would rate both?
How are your tires doing Shankar? You would be changing them to...?
Seems Mahindra Bolero uses the same spec tires, while I can't use those on the Yeti, am sure Bolero can use these as spare tires & I just might fetch good resale
Please keep me posted guys, we think we might change the entire set :-)
Old 11th May 2013, 18:31   #130
Mate.
I m not yet ready for a tyre upgrade. Another one year at least given my very low running average.
When I do upgrade I probably will go for Yokos if I can get them. But I will go with HT's as these are more than sufficient for my general usage.
The Bolero uses 215 -75 -15 size. The Yeti's tyres will not work on a Bolero as it is way too heavy a vehicle. The Yeti's tyres are in the wrong size and are too soft for the typical rough use that Bolero owners put their vehicles through.
shankar.balan is offline   (1) Thanks Reply With Quote
Old 18th May 2013, 18:25   #131
Sheel's Avatar
Yokohama is able to source 215/70 R16 for us. Would the aspect ration of 70 be a bother?
Old 18th May 2013, 19:42   #132
Behemoth's Avatar
Thanked: 963 Times
Yes, 215/70 R16 is too big. Biggest which I know will work with the Yeti is 215/65 R16.
Some options which CMT is showing are MRF Wanderers and Michelin Latitude Tour HP.
Even the Wanderers are supposed to be quite good and are the OE tyres in this size on the Duster and also contribute to the good ride on the Duster. They are also cheap at 7800 a tyre. So if you are considering rough use, you can opt for these.
Old 19th May 2013, 08:48   #133
Sheel's Avatar
MRF Wanders would be a no no. It is very hard to rein yourself driving a 140BHP MT Car with good dynamics.
Now we are looking at either Michelin Latitude Tour HP or at various Duelers by Bridgestone in size 215/65 R16. Any recommendation for Bridgestone?
Thanks again :-)
Old 19th May 2013, 10:31   #134
Thanks again :-)
If you find Bridgestone Dueler HT's in the stock Yeti size please post the details here of where to procure the same.
I like Bridgestone Dueler HT's and as per my experience with them on my Bolero and Scorpio these last 8-9 years, find them to be strong, tough, economical, comfortable and long lasting tyres.
Old 24th May 2013, 19:51   #135
Sheel's Avatar
Bridgestone is available at Siliguri in size 215/65 R16. The tire is this
Though we ideally wanted this, but wasn't available.
We would be looking at Michelin as well. What would guys advise? Michelin has this
I would update hopefully early next week.
Skoda Rapid : Tyre & wheel upgrade thread kryptonite Tyre & Alloy wheel Section 126 28th December 2016 13:52
Toyota Etios & Liva : Tyre & wheel upgrade thread nkrishnap Tyre & Alloy wheel Section 54 27th November 2016 21:38
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 10 29th August 2016 17:08
Skoda Laura : Tyre & wheel upgrade thread deepakvrao Tyre & Alloy wheel Section 311 30th July 2016 17:21
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 635 9th February 2016 06:59
