Old 29th August 2016, 23:45   #496
el lobo 6061's Avatar
Thanked: 1,014 Times
Default Re: Volkswagen Vento : Tyre & wheel upgrade thread
Originally Posted by Guite View Post
Upgraded my new Vento tyres to Michelin P3 ST 195/60 R15. Paid Rs.2,600 per tyre after exchanging it with OEM Apollo Alnac tryes. Ride is now quieter and more comfortable, albeit still a bit too firm for my liking. Pressure is 34 psi on all tyres.
Reduce tyre pressure to 32 psi front and 29 psi at rear. Comfort will increase dramatically. 2011 Vento carried following pressure reading for 2 Pax and 1 suitcase in boot.
el lobo 6061 is offline   (1) Thanks Reply With Quote
Old 30th August 2016, 02:03   #497
Thanked: 9 Times
Hi All,
I have been using Yoko S Drive 205/55/R15 for the past 2.5 years and is my first and best recommendation for all Vento / Rapid owners. I have covered 70K kms overall, with the first set lasting till 45K Kms, solid!
Stock tyre Size is 185/65/R15 , which has an aspect ratio of 120.25 mm.
195/60/R15 has aspect ratio of 117 mm, which is also practically the same.
205/55/R15 has aspect ratio of 112.7 mm, which also doesn't impact the stability, but ground clearance almost by 1 cm, which is notable.
Do know what you are really looking for while choosing the tyre. Happy up-sizing.
Nikz is offline   Reply With Quote
Old 30th August 2016, 11:49   #498
Guite's Avatar
Thanked: 187 Times
Thanks, will try this pressure.
195/60/R15 has aspect ratio of 117 mm, which is also practically the same. 205/55/R15 has aspect ratio of 112.7 mm, which also doesn't impact the stability, but ground clearance almost by 1 cm, which is notable.
Stock tyre is 185/60 R15 in Comfortline and Highline variants. The second figure in tyre size label is the aspect ratio, example 60 in 185/60 R15.
185/60 R15 has a radius of 301.5mm
195/60 R15 has a radius of 307.5mm, an increase of 6.00mm in ground clearance
205/55 R15 has a radius of 303.25mm, an increase of 1.75mm in ground clearance
Guite is offline   Reply With Quote
Old 18th September 2016, 13:28   #499
danlalan's Avatar
Thanked: 135 Times
Surprisingly my 23k kms 2011 Vento hit line shod with stock Apollo acceler tyres have come to the end of its life. Not only that they keep developing punctures.
Out with the old in with the new. But which tyre. My driving is mostly 90% city and 10% highway. I need something comfortable but durable at the same time. And yes less prone to punctures. I would like to stick to the stock size of
185/60- 15.
What do you suggest.
danlalan is offline   Reply With Quote
Old 18th September 2016, 13:58   #500
Thanked: 196 Times
185/60- 15.
Bridgestone Turanza ER 300. I changed about 7000km back. Wonderful ride quality and poise. A sea of difference from the Apollo Aceleres. A lot less noise too.
sunsetorange is offline   (1) Thanks Reply With Quote
Old 18th September 2016, 17:11   #501
185/60- 15.
Only choice that comes to mind is Michelin XM2. They are very durable though being Michelin and comfortable as well. The dry grip is phenomenal whereas the wet grip with stagnant water ain't that good.
Old 3rd October 2016, 13:22   #502
Rajesh Rawal's Avatar
Thanked: 153 Times
Question to those who have upgraded to 205/55/15 (more so on a polo)
When the car is fully loaded with pax ,does the rear tyre touch the car body ? Or does it dwell into the well easily (even though the tyres are wider)
Rajesh Rawal is offline   Reply With Quote
Old 8th October 2016, 23:34   #503
sixthsense2k6's Avatar
Thanked: 7 Times
Can anyone post snaps of your upgraded tyres
I am a big fan of Michelin
But now after going through this thread I realised that Yokohoma would be ideal
Anyways pls help me with snaps of your upgrade
I am planning a vento TDI DSG highline for next week
Should i keep the stock size and change it to a better brand so that my warranty is safe and intact ?
I just want more life and bit more comfort as most the travel is done on bumpy roads and not on highways.
I belong to kerala, so we have monsoon months and hot summer with lots of potholes
If Yokohoma, which one of it ?
Or any other brands ?
My cousin suggested Hankook 🙄
sixthsense2k6 is offline   Reply With Quote
Old 9th October 2016, 13:47   #504
Thanked: 144 Times
Go for stock Turanza ER 300. It will fulfill all your expectations without a fuss. It offers balanced grip, comfort, silence, FE and good durability & longevity, with no warranty violation. All other combinations are a compromise in one or more aspects IMHO.
printh is offline   Reply With Quote
Old 9th October 2016, 22:39   #505
Thanked: 7 Times
I will keep in mind
What abt michelin ?
Old 10th October 2016, 22:44   #506
Thanked: 7 Times
Did an enquiry at a tyre dealer about pricing of MICHELIN XM2
Quoted 5200
If my stock tyres are appolo , for 3200 they will take those
If its Mrf, just 2900 is their value
I am talking about 185 60 15R
Anybody help me
Is it a good deal ?
I am afraid about warranty of suspension
My heart says a bigger tyre to bypass poor ground clearance of vento
But my mind is against an upgrade in size out of fear 😷
Michelin xm2 has lasted long for my amaze and ford classic
Comfort was better than bridgestone
Old 11th October 2016, 06:47   #507
Turbohead's Avatar
Thanked: 284 Times
Quoted 5200
Anybody help me
Is it a good deal ?
Suspension warranty is only 10k kms or 6 months.
Might as well upgrade right away if comfort is priority
From this thread, the popular choices in terms of comfort are
195/60- Michelin P3ST
205/55- Continental MC5
Turbohead is online now   Reply With Quote
Old 11th October 2016, 10:32   #508
Thanked: 190 Times
There is Vredestein Sportrac 5 too. Available in 195/60 R15. Has excellent reviews. Dry grip, wet grip, handling, tread wear, et all.
http://www.tyrereviews.co.uk/Tyre/Vr...Sportrac-5.htm
A person used them on Fiat Linea, and has commented in there. After using for over 40000 kilometers, about half of the tread thickness was still left, as per that person.
Considering the excellent reviews, I am going to get these tyres for my 2010 TDI.
halfbytecode is offline   Reply With Quote
Old 12th October 2016, 06:06   #509
Thanked: 7 Times
Can anyone post pictures of vento with an upsized tyre
Preferably both 195 and 205
I saw Yokohoma S drive 205 in one of the shops, I am very much concerned about the width
I dont want my vento to look like a Thar 😬
So pls update me before i upsize
Old 12th October 2016, 10:07   #510
Thanked: 144 Times
Don't worry about the Thar-like look. It will make the stance very good looking, like how the cars will be in western nations.
If you want I can PM you more pictures.
There is absolutely no sidewall scrape issue even with 5 passengers + luggage onboard. The sidewall height is almost same and so ride quality & GC remain same. The compound of the S drives might give harshness though. The steering feel had improved a lot with the 205s. You can literally feel the wide contact area and the increased grip while driving. But, FE decreases by 0.5 to 1 Kmpl during sedate drives.
To sum up, if you don't really care about that 1 kmpl drop in FE, you can go for 205s eyes shut since it's more near to the stock parameters than 195s (which has more choices though).
printh is offline   (1) Thanks Reply With Quote
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
Hyundai i10 : Tyre & wheel upgrade thread carZest Tyre & Alloy wheel Section 607 25th April 2017 19:32
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
