Old 16th October 2016, 08:20   #511
sixthsense2k6's Avatar
Thanked: 7 Times
Anyone pls post snaps of tyre upgrade !
Planning a rapid
Whats your opinion about stock size and a change to Michelin XM2
Any difference in comfort ?
I am sure Michelin will last longer but what about comfort?
Any difference from Appolo Alnac ?
sixthsense2k6 is offline   Reply With Quote
Old 16th October 2016, 20:44   #512
rageshgr's Avatar
Thanked: 302 Times
Infractions: 0/1 (5)
Default Re: Volkswagen Vento : Tyre & wheel upgrade thread
Michellin xm2 will be a bit more comfier than alnac. But at its price, you are still getting a low end Michellin
If comfort is paramount, look no further than 195/60 Micgellin P3 ST
If it is ultimate performance you are after, then check out 195/55 R 15 Hankook Ventus v12 evo
rageshgr is offline   Reply With Quote
Old 17th October 2016, 10:47   #513
atlantis0965's Avatar
Thanked: 70 Times
Originally Posted by sixthsense2k6 View Post
Can anyone post pictures of vento with an upsized tyre
Preferably both 195 and 205
I saw Yokohoma S drive 205 in one of the shops, I am very much concerned about the width
I dont want my vento to look like a Thar 😬
So pls update me before i upsize
Hello
Attaching a few pictures like you've asked ;
Size and make should be self explanatory from the pictures.Taken with a mobile phone camera only ,so please don't mind if it's not as expected!
They have already run about 5000km and I am pretty happy about them !
Volkswagen Vento : Tyre & wheel upgrade thread-1476681055486.jpg
Volkswagen Vento : Tyre & wheel upgrade thread-1476681075485.jpg
Volkswagen Vento : Tyre & wheel upgrade thread-1476681113789.jpg
atlantis0965 is offline   Reply With Quote
Old 17th October 2016, 13:08   #514
Thanked: 144 Times
Sorry for the delay mate. I would like to add some more pics from my side.
It fills the wheel well to some extent. The tread is after 12000 Kms usage.
printh is offline   Reply With Quote
Old 4th November 2016, 14:27   #515
Guite's Avatar
Thanked: 187 Times
I have upsized to 195/60 Michelin ST3 but found the ride hard and bumpy. I maintain 32 psi front and 29 psi rear as recommended. However this recommendation is for stock tyre 185/60. A thought just occurred to me: should the tyre pressure be reduced as the tyre size increases? Bicycle tyres has small cross sectional area but the air pressure to be maintained is huge.
Guite is offline   Reply With Quote
Old 7th November 2016, 22:28   #516
Guite's Avatar
Thanked: 187 Times
On Android version I thought I saw a response to my post above.
I got my own tyre inflator with gauge and found out that the pressure was 34 psi (filled by a roadside tyre wala). I brought it down to 30 front and 29 rear. Now it is much more comfortable.
Old 8th November 2016, 10:40   #517
Thanked: 13 Times
I had upsized to 205/55 Conti MC5 and kept 30 psi in all wheels. The ride was very bumpy and felt vibrations on the break pedal. This was more on highway drives. I reduced the pressure to 28 psi in all wheels and felt a huge difference immediately. The ride has become very smooth and the break pedal vibrations have come down drastically.
rama75 is offline   Reply With Quote
Old 8th November 2016, 16:47   #518
ahmadnaik's Avatar
Thanked: 232 Times
After much deliberation - and painstakingly long conversations with myself in my head - I finally settled for 195/60 R15 Yokohama S-Drives.
I would have preferred the 205 ones - but felt like I could use the extra ground clearance and added comfort. The only thing is - it feels a bit more wobbly when at 33 psi for all tyres, which is what I always kept my stock tyres at.
I tried going with 32 psi for all as well - and found it to be slightly better.
Since I have never upsized my tyres before- I'm wondering how low I can go without it being dangerous and/or wrong? I usually have at least 3-4 adults in my car with added luggage about once a week.
So any help would be appreciated.
P.S. - Contrary to what I expected, the road noise has reduced significantly when compared to the stock Goodyear tyres I had replaced them with from the service centre, and this is despite the S Drives being super grippy "sporty" tyres.
ahmadnaik is offline   Reply With Quote
Old 8th November 2016, 18:02   #519
Thanked: 144 Times
Hi ahmadnaik, you can refer to tyre upsize calculator from any website to see the difference in % of the wheel diameter and it's good if you maintain it within 3% or to be extra safe 2%. The 205/55 would've given the same ride quality and least % of difference.
The Yoko S drives ride silently for first half of their life and and thereafter tend to get noisy.
If comfort had been your preference, you could've gone for a brand other than S drive as they are hard compound grip oriented tyres and supposedly less on comfort.
Old 14th November 2016, 11:25   #520
Thanked: 9 Times
Stock tyre is 185/60 R15 in Comfortline and Highline variants.
The second figure in tyre size label is the aspect ratio, example 60 in 185/60 R15.
185/60 R15 has a radius of 301.5mm
195/60 R15 has a radius of 307.5mm, an increase of 6.00mm in ground clearance
205/55 R15 has a radius of 303.25mm, an increase of 1.75mm in ground clearance
As per my understanding,
Stock tyre is 185/60/R15 and will have a Section Height of 111 mm (185 X 60/100).
195/60/R15 will be having a section height of 117 mm (195 X 60/100) - 6 mm increase in ground clearance. [117 - 111] mm
205/55R15 will have a Section Height of 112.75 mm (205 X 55/100) - 1.75 mm increase in ground clearance. [112.75 - 111] mm
We can forget about the alloy for the time being as the size of it doesn't change and has no impact in ground clearance in this context. The only thing that changes is the Section Height and the same is explained above.
Please correct me if the figures provided above are wrong. Also, please explain how you got the figures 301.5 mm, 307.5mm and 303.25mm.
Could you please elaborate.
Thanks,
Nikz.
Nikz is offline   Reply With Quote
Old 14th November 2016, 14:05   #521
Guite's Avatar
Thanked: 187 Times
Thanks,
Nikz.
It's just two ways of looking at one subject. Please note that the figures I gave are RADIUS of the complete wheel (alloy + rubber tyre) whereas you had put aside the alloy size as a constant and did not consider in your calculation.
If you add size of alloy wheel to your calculation you will arrive at same figure as mine. In tyre size nomenclature R15 means the (alloy) wheel diameter is 15 inches. In mm this is 15x25.4 = 381mm. Radius = 381/2 = 190.5mm. From your calculation section height is 111mm. Add 190.5 and 111 will give overall wheel radius = 301.5mm.
Old 28th November 2016, 17:24   #522
Thanked: 33 Times
Hello everyone!
Its finally time to change the stock tyres on my 2012 Vento Tdi Highline (stock size - 185/60 R 15).
Although they have enough tread left to last another 5-10K kms, the tyres have hardened up considerably and the road noise has increased drastically.
Went through the major part of this thread and learnt abt the popular tyre choices and sizes and am left a lil confused. Really need some inputs to help me make a decision.
I am not a very enthusiastic driver and I use the car 90% in city with a few weekend drives on highways and limit my speeds to abt 120kms max.
My requirements are (in order)
1) Comfort & low noise
2) Good dry and wet grip
3) Durability.
Having recently changed my Innova stock Bridgestone tyres to Yoko Earth 1s, I am very impressed by them Yokos and have more or less decided to go for them for my Vento unless anyone can suggest something else.
I am wanting to upsize to 195/60 but am concerned if the larger width and higher unsprung weight of the tyre would wear the suspension and steering components faster. Specially since i drive in the city and parking my car mostly requires a lot of manouverung and lock to lock steering.
Would like your feedback/suggestion on whether to upsize to 195/60 or not and anyother tryes that i can consider.
ASVA.
ASVA is offline   Reply With Quote
Old 29th November 2016, 01:23   #523
karansm4u's Avatar
Thanked: 81 Times
Originally Posted by ASVA View Post
Hello everyone!
ASVA.
I think its safe to upsize to 195's since many folks have done the same and none of them complained about it. As a matter of fact i have been running 205/55/R15 S-drive on my vento since Mar 2011 and covered 70K distance (First set changed at 45K and other set of S-drive has completed 25K). Still my suspensions are working fine and no steering issue as well. Only thing i got changed after 6 years in suspension system is bushes, link rods etc which are standard replacement after this much duration.
If comfort is your priority than do not go beyond 195. In fact i am also planning to change to 195's for my third change.
karansm4u is offline   (1) Thanks Reply With Quote
Old 25th December 2016, 14:37   #524
ahmadnaik's Avatar
Thanked: 232 Times
So - I finally realised that the 195/60 R15's were a bad idea. In fact - scratch that, a terrible idea. Obviously this is personal preference - but one thing I've learnt from my rather expensive mistake is this - even a 12mm increase in diameter is enough to drastically change the driving dynamics of your vehicle. And I repeat - it was drastic indeed.
I decided to go for the 195's since my car used to bottom on some of the mountain peaks the authorities in Mumbai call "speed breakers", and I thought a slight increase would be welcome, and not affect the driving dynamics noticeably. And I was wrong.
So - I've switched to 205/55 R15 Yokohama S-Drives, barely 2 months after I had switched to the 195's - and the difference is immediately, without doubt, noticeable. Acceleration and Braking is both increased - and by my estimate, the traction control engages way lesser than before.
So - in conclusion, without further ado - I hereby pass my experienced, albeit a bit premature, judgement -
If you want to upgrade your Vento tyres, and care about better grip and handling - go for the 205/ 55 blindly.
Seriously - just literally walk up to the guy with a blindfold and tell the tyre change dude I want the 205's. Period.
I got my tyres changed from Pal Tyres at Laminton Road in Mumbai. There's a gentleman there by the name of Mr Gagandeep who's really helpful and has a ready stock of Yokos.
Old 25th December 2016, 15:13   #525
Thanked: 190 Times
That is very contrasting to my experience. Two sets of Yokohama C-drives have been phenomenal in 195/60 R15 in my car. Traction levels, braking distance, et. al. has been great. I felt improvement in driving dynamics too.
What tires were your 195/60 R15s and what was the tyre pressure?
On a side note, my car is 2010 manufactured and has Euro-spec heavy duty suspension. This difference plays a huge role too.
halfbytecode is offline   (1) Thanks Reply With Quote
Hyundai Grand i10 & Xcent : Tyre & wheel upgrade thread jkdas Tyre & Alloy wheel Section 18 8th July 2018 21:32
4th gen. Honda City : Tyre & wheel upgrade thread Screwdriva Tyre & Alloy wheel Section 350 9th May 2018 19:30
Hyundai i10 : Tyre & wheel upgrade thread carZest Tyre & Alloy wheel Section 607 25th April 2017 19:32
Fiat Palio : Tyre & wheel upgrade thread shahmotors Tyre & Alloy wheel Section 637 26th March 2017 12:56
