Old 30th December 2005, 10:38   #1
Shan2nu's Avatar
Thanked: 87 Times
Default Could it be a valve problem?
Recently, i've noticed that the left rear tyre on the Vtec loses pressure drastically but, it doesn't deflate completely. It comes down to around 25psi and stays there.
Yesterday, i'd filled 30psi in the rear tyres and it's already come down to 25psi on the left one. The right one still shows 30psi.
Could it be that the valve on the left one has bcom a little weak and isn't able to sustain pressure, over 25psi?
Has anyone else faced such a problem?
Wanted to clear this doubt before i replaced the valve.
Shan2nu
Old 30th December 2005, 10:46   #2
Looks like "Yes it is" from my review-textbook-read experience. But please wait till some of our senior guys confirm this.
Does it stay in 25 PSI or proceeds to go further down?
Surya
Surya is offline   Reply With Quote
Old 30th December 2005, 11:17   #3
Shan2nu's Avatar
Thanked: 87 Times
It stays at 25 psi. (Which itself, is dangerously low).
Shan2nu
Old 30th December 2005, 11:27   #4
Thanked: 48 Times
May be you have already checked this, but are you sure there is no minute puncture?
RX135 is offline   Reply With Quote
Old 30th December 2005, 11:31   #5
Rehaan's Avatar
Thanked: 22,568 Times
Shan,
Sounds like either a slow leak puncture or bad valve.
The most commonly practiced way of checking if your valve is leaking is to take a huge blob of spit, and dab it over the entire mouth of the valve. If it blows into a bubble, your valve is leaking. (Might also help to over-inflate when doing this test).
Yeah, sounds gross, but all the tire guys do it.
Alternatively, (or for a puncture) you could dump the tire in a tub of water and look for bubbles. Like mentioned in this thread. (Puncture, help!)
cya
R
Old 30th December 2005, 12:42   #6
Shan2nu's Avatar
Thanked: 87 Times
Just checked the tyre by immersing it in a water tank. The leak is from around the valve. The place where the valve sits on the alloy.
Can it be mended or will i have to go in for a new valve?
Shan2nu
Old 30th December 2005, 12:53   #7
Rehaan's Avatar
Best bet would be to just pop in a new valve.
Usually the valve hole is a favourite place for rust, but since you have alloys i guess that isnt the case.
Get the wheel cleaned around the valve hole and a new valve should do the trick.
cya
R
Old 30th December 2005, 15:13   #8
Shan2nu's Avatar
Thanked: 87 Times
UPDATE : Got the valve replaced. Checked again for leaks but, none this time.
Shan2nu
8 Valve SOHC vs 16 Valve SOHC shineshine Technical Stuff 6 12th February 2016 22:23
Ford Ikon: A/c Water Diverter Valve problem Absar Technical Stuff 29 3rd February 2013 13:25
Engine head overhaul for a broken diverter valve problem. shiv Technical Stuff 9 1st December 2011 20:08
Valve problem in P150? _abhishek Motorbikes 2 15th March 2011 14:53
Unicorn Valve Problem manish7 Motorbikes 3 18th June 2009 15:33
