Old 10th June 2014, 12:45   #166
desiaztec's Avatar
Thanked: 91 Times
Default Re: Alloy Refinishing - Painting / Powder-coating / Chroming
Originally Posted by ank.nsit View Post
I never knew about this option.
Can you tell me the costs for the same? Also, is electroplating better than painting? Also, I guess electroplating would involve complete alloys getting same color while painting would provide an option of getting selective parts painted.
Cost for electroplating would vary depending on factors like how easy or complex it is to buff your alloy wheel, what metal you want to be deposited on your wheels.
If the structure of the wheel is complex (curves and lines here and there), it would be a little task to buff the wheel. Further, having Zinc plated on it will have a different price tag attached to it rather getting say Silver or Nickel-Chrome. To make you visualize how a Nickel-Chrome plated alloy wheel would look, refer:
http://www.team-bhp.com/forum/indian...n-scorpio.html (Mahindra launches Special Edition Scorpio)
I presume, a single electroplated in Nickel-Chrome should set you back by Rs. 800- Rs. 1100.
About which of the two coating process is better, it would be a little unfair to be biased to either. Just like the idiom goes; "Its like comparing apples and oranges".
desiaztec is online now   (1) Thanks Reply With Quote
Old 10th June 2014, 14:20   #167
Rehaan's Avatar
Thanked: 25,043 Times
Apart from that will the vinyl sheets be able to take the stress that the wheels are subjected to?
Good question. The regular stresses that the wheels are subject to shouldn't be an issue. What might however be an issue is the heat.
Once again, I'm just speculating here.
cya
R
Old 16th June 2014, 10:57   #168
Thanked: 129 Times
Got the Alloys sanded as there was too much corrosion in the center (near the nut area) & it had started powdering.
Posting the before & after pictures.
Points to be noted before sanding.
If there are "grains" those areas should not be sanded, else the original grains would disappear as the sanding would remove a thin layer of the surface.
Total cost Rs 1,600, did this in mysore, those guys came home & removed one by one wheel & did the job.
Now, job pending:
1. painting on the corners where the yellow arrow is shown
2. Lacker .
Ananth
Ananth_shukti is offline   Reply With Quote
Old 23rd August 2014, 13:17   #169
TheLizardKing's Avatar
Thanked: 489 Times
Have been tinkering for a while with the idea of getting the alloys on my Polo spray painted/powder coated/electroplated to matte black. Looked up the internet, and was swept away in the deluge of too much information. It's just as bad here, but this looks like the best thread to ask.
1. Which is the best process (spray paint / powder coating / electroplating / others I don't know about) from the POV of finish and durability?
2. How strong a dose of Vitamin M will it require?
3. Any recommendations on where I can get this done in and around Andheri?
Thanks in advance...
TheLizardKing is offline   Reply With Quote
Old 22nd September 2014, 10:21   #170
nick17s's Avatar
Thanked: 93 Times
Got a friend's alloy painted from Hyper silver to Matte black finish. This was done with spray cans.
Looks even better in real.
Alloy Refinishing - Painting / Powder-coating / Chroming-img20140921wa0061.jpg
Alloy Refinishing - Painting / Powder-coating / Chroming-img20140921wa0060.jpg
Alloy Refinishing - Painting / Powder-coating / Chroming-img20140921wa0059.jpg
nick17s is offline   Reply With Quote
Old 23rd September 2014, 00:18   #171
joybhowmik's Avatar
Thanked: 1,928 Times
Originally Posted by iraghava View Post
You can get in touch with Pandit & Co. on 41612844. They regularly get wheels powder coated for Vintage/Classic cars and might be able to help you out.
Sorry to bump an old post.
I have a 11 year old Santro Xing AT @ 75k kms, which is at the point, where a bit of "daana-paani" every once in a while keeps it purring sweetly.
Planning to retain the car for next 3 years at least considering everything is mechanically fine.
The wheels are looking well past it - after all these years... see pictures.
At the moment following options
a) Get the paint stripped down to bare metal, and re-paint.
b) Get a set of second hand alloys.
c) Do nothing
What would be the recommended option and why?
Alloy Refinishing - Painting / Powder-coating / Chroming-fl.jpg
Alloy Refinishing - Painting / Powder-coating / Chroming-fr.jpg
Alloy Refinishing - Painting / Powder-coating / Chroming-rl.jpg
Alloy Refinishing - Painting / Powder-coating / Chroming-rr.jpg
Old 23rd September 2014, 08:56   #172
deetjohn's Avatar
Thanked: 8,008 Times
Are you running tubeless tyres? If so, are you losing air pressure very frequently? If not, the steel wheels are fine just need some cosmetic restoration. The first option in your post.
And if it is leaking air, the best option would be to look at new OEM steel wheels since you are planning to keep the car for 3 more years. They aren't that expensive.
deetjohn is offline   Reply With Quote
Old 23rd September 2014, 09:06   #173
joybhowmik's Avatar
Goodyear GPS 2 tubeless on all 4 corners. Losing air on front right wheel only. But manageable with twice weekly top-ups.
Is a cosmetic restoration cheaper than new steel wheels?
Old 23rd September 2014, 09:27   #174
deetjohn's Avatar
Twice a week is not good. Check that wheel, could be out of shape. Restoration will be cheaper. But, it cant fix bends properly.
Old 29th September 2014, 15:33   #175
nick17s's Avatar
Thanked: 93 Times
Got my i10's alloy painted in Matte black, only the mid spoke.
Alloy Refinishing - Painting / Powder-coating / Chroming-20140615_165727.jpg
Alloy Refinishing - Painting / Powder-coating / Chroming-20140929_090534.jpg
Alloy Refinishing - Painting / Powder-coating / Chroming-img20140927wa0036.jpeg
Alloy Refinishing - Painting / Powder-coating / Chroming-img20140927wa0038.jpeg
Alloy Refinishing - Painting / Powder-coating / Chroming-img20140927wa0042.jpeg
nick17s is offline   (2) Thanks Reply With Quote
Old 20th October 2014, 10:54   #176
Naman_Ferrari's Avatar
Thanked: 50 Times
Hello everyone,
I have a Ford Ecosport with stock alloys and am really looking forward to getting the colour of the alloys changed in Bangalore.
Does anyone know a place where I can get this done?
Thanks in advance.
Naman_Ferrari is offline   Reply With Quote
Old 20th October 2014, 12:16   #177
Thanked: 109 Times
Originally Posted by Naman_Ferrari View Post
Hello everyone,
Thanks in advance.
Check this link
http://www.team-bhp.com/forum/tyre-a...ossible-3.html (Repair Alloy - Is it possible?)
Hope it helps.
hamster is offline   (1) Thanks Reply With Quote
Old 25th October 2014, 08:42   #178
Sheel's Avatar
Thanked: 5,649 Times
Suggestions please -
Should I go ahead and ask the dealership to paint the alloys (in black, the car ordered is black as well), will it look good?
In which process of painting will the paint hold well? I do not want to get it painted every 6 months. Or should I leave it stock? (The new Scorpio)
Old 25th October 2014, 11:27   #179
SumitBahl's Avatar
Thanked: 219 Times
Aftermarket paint is more prone to chipping in case you scrape the rim. Stock alloy would have a scuff.
I would suggest to keep it stock for now, get it powder coated later.
SumitBahl is offline   (1) Thanks Reply With Quote
Old 12th December 2014, 14:26   #180
Captain Slow's Avatar
Thanked: 664 Times
Looking to change the color of the stock alloys, any suggestions for places in Bangalore?
Captain Slow is offline   Reply With Quote
Zen exhaust spitting lots of carbon powder at high revs after cold start!! devrajman Technical Stuff 32 20th June 2010 08:28
Simple DIY - Painting Alloy Wheel Cover of Verna dinu2506 DIY - Do it yourself 9 22nd January 2010 13:43
Powder coating on the engine cover? nitin.dangayach Motorbikes 3 27th April 2009 19:54
S10 Alloys: Powder Coating. Which Color? khan_sultan Tyre & Alloy wheel Section 18 13th June 2008 15:35
Chroming my tank .. buzzin_hornets Motorbikes 5 21st March 2006 13:21
