Old 13th July 2009, 17:07   #121
Sportsmind's Avatar
Thanked: 28 Times
Cool
Does anyone know where a re powder coating can be done to the alloys in Bengaluru. Two of my alloys have the coating come of is small patches. Who are the best guys on this job, what is the cost and how much time does it take to have this done. Will the coating last for a long time.
Sportsmind is offline   Reply With Quote
Old 13th August 2009, 22:58   #122
ashwanth's Avatar
Question Painting steel wheel rims in black colour
Hi gang
What paint should I buy for painting steel wheel rims in black colour - Are they called 'rubberized paint' (Which gives a powder coat like rough finish)? Should I use a primer ? And where do I get this paint - in hardware stores or in a automobile spares shop ..
thanks!
Ashwanth.
ashwanth is offline   Reply With Quote
Old 14th August 2009, 08:44   #123
Thanked: 45 Times
Its an matt finish paint, and its like just an ordinary paint. But go for automotive paints, atleast Duco. If there is paint, just use sand paper and then wash, dry then paint using spray gun. Sand paper is to roughen the surface and remove loose paints, so use light one. (soft) if it is old rim which have been repainted several times, then you have to use putty for the fillings , so that the finish will be fine.
rajivanoj is offline   Reply With Quote
Old 14th August 2009, 09:30   #124
pramodkumar's Avatar
Thanked: 947 Times
Go to a automotive paint shop ask for a can of bosiny paint in black ~200 INR. Wash all your rims let them dry and then spray on them. You can do a great job by snading them and applying fillers and putty but usually its not required. Happy DIYing
Old 15th August 2009, 13:46   #125
ashwanth's Avatar
Many Thanks Guys.Will try that out!
cheers
Ashwanth
Old 20th September 2009, 17:33   #126
Glifford's Avatar
Thanked: 46 Times
Default Repainting Ford Fusion + OE Alloys (Hyper Silver)
Hi Everyone,
I luckily found this thread, as I was about to commit the sin of creating a new one!
Anyway, I am planning to change / upgrade the stock tyres on my 2005 Ford Fusion + (that have done 48,000+ km already) and before I do that, I want to repaint the alloys as they have got scratched and have a few nicks here and there. Add to that brake dust and water stains.
Any suggestions in where I can do them in Bangalore.
The OE alloys are Hyper Silver and need to be painted in the same colour (or Ford Moondust Silver, the colour of the car).
I guess powder coating would not do, and spray painting would be needed. The central plastic nut cover would also be needed to be painted (with the Ford logo masked off).
Attached is the image of the rim in current shape.
Last edited by Glifford : 20th September 2009 at 17:51. Reason: Added Bangalore and brake dust stains.
Glifford is offline   Reply With Quote
Old 29th September 2009, 15:54   #127
Glifford's Avatar
Thanked: 46 Times
Since I got no responses and also got varying (and sometime ridiculous) quotes from dealers, realised the scratches were not all that bad
Decide to take the DIY route and am almost done. Lots of effort, but fun as with every DIY. Will eventually post the results and process tomorrow (as a separate thread) when I am done (I hope).
Old 30th September 2009, 23:52   #128
Glifford's Avatar
Thanked: 46 Times
It got done. Here (DIY: Ford Fusion+ OE Alloy Wheel Restoration) is the thread as promised. Will keep updating there.
Old 6th November 2009, 23:02   #129
Thanked: 9 Times
amazing work glifford
M124 is offline   Reply With Quote
Old 8th December 2009, 13:14   #130
Raj2010's Avatar
Here's a good DIY if you are inclined. If you properly prep they will turn out great.
Painting your wheels
I did these myself.
Raj2010 is offline   Reply With Quote
Old 8th December 2009, 15:37   #131
Glifford's Avatar
Thanked: 46 Times
Thanks M124!
I did these myself.
That's an excellent looker. I assume the one on the right is post your DIY.
Which paint did you use?
Aah, see that you are in the US, so I assume you used DupliColor
Great work!
Last edited by Jaggu : 26th January 2010 at 15:28. Reason: Please avoid Quoting posts along with the picture. Thanks
Old 9th December 2009, 10:08   #132
Raj2010's Avatar
Thanks M124!
Great work!
Thanks you are correct Duplicolor. Its all about the prep. I went from Silver to Gold and now Black.
Old 26th January 2010, 14:16   #133
SumitBahl's Avatar
Thanked: 219 Times
Hi there
I want to paint OE Punto Alloy wheels to matt black.
Can anyone tell me where it could be done in chd.
Matt black finish is achieved by painting or powder coating?
Please guide.
SumitBahl is offline   Reply With Quote
Old 26th January 2010, 18:41   #134
vikram_d's Avatar
Thanked: 940 Times
Powder coating is stronger and more durable.
Old 26th January 2010, 21:08   #135
SumitBahl's Avatar
Thanked: 219 Times
Can we achieve matt black finish with powder coating.
From where can i get the powder coating done?
Zen exhaust spitting lots of carbon powder at high revs after cold start!! devrajman Technical Stuff 32 20th June 2010 08:28
Simple DIY - Painting Alloy Wheel Cover of Verna dinu2506 DIY - Do it yourself 9 22nd January 2010 13:43
Powder coating on the engine cover? nitin.dangayach Motorbikes 3 27th April 2009 19:54
S10 Alloys: Powder Coating. Which Color? khan_sultan Tyre & Alloy wheel Section 18 13th June 2008 15:35
Chroming my tank .. buzzin_hornets Motorbikes 5 21st March 2006 13:21
