-   4x4 Excursions (https://www.team-bhp.com/forum/4x4-excursions/)
-   -   Article : Offroad GPS navigation, concepts and software (https://www.team-bhp.com/forum/4x4-excursions/98133-article-offroad-gps-navigation-concepts-software-2.html)
tsk1979 19th March 2011 16:05
Re: Article : Offroad GPS navigation, concepts and software
Originally Posted by mercedised (Post 2284542)
@tsk: Nice information there.:)
BTW, could you please elaborate on 'How to project points using GPS?'.
For e.g. I mark my current location in GPS, and noe from this location I want to mark another point 40-50meters ahead at an angle of 120 degrees? How will I do that? I have Garmin Etrex-H and so far have not been able to use this feature due to lack of knoweldge.
Look at this
Garmin Gpsr Tips And Tricks - Groundspeak Forums
There are many other geocaching software which support projection.
mercedised 19th March 2011 17:06
Originally Posted by tsk1979 (Post 2284598)
Look at this
I am new to dedicated GPS devices, so could you please explain me the concept behind GEOCACHING? I have read wiki but it says it is a game??
And how do I know if my GPS device has compatibility with the particular software?:)
tsk1979 19th March 2011 17:11
mercedised, most handhelds cannot run other software.
The GPS thread in shifting gears(gadgets section) has a lot of information about various GPS devices.
You can post your device details there and get info.
Crazy4Power 19th March 2011 17:15
I used Garmin 62s & 78s during car rallies, I found them quite useful for offroading in desert as well hilly terrain. The best combination for offroading is to have Garmin Birdseye subscription along with these unit.
In bird's eye you can download the high resolution satellite imagery of any area and send it to Garmin device with just a click of a mouse.
Cheers!
Alok
manmohanmaan 22nd March 2011 18:44
TSK1979
Firstly thank you for this informative log, just like all your travel logs very informative and readable. I have purchased a MMI device and its not even accurate on state highways, recently i was on SH from Chickmagalur to Kadur and the display showed me moving on a green background with no sign of any road, I did appear to intersect and then move away from the road I was on as per the GPS, was very disconcerting and my trust in the maps loaded on the device was badly dented. Looked like the road was not tracked properly on the MMI maps. Can anyone tell me, is there any way I can load tracks on this device that are not available with the service provider?
Manmohan.
tsk1979 22nd March 2011 19:52
manmohanman, I do not think MMI devices and software support reading gpx tracks. If you can go to your device software, and click on "about me" or similar button, it will tell you which software its using. Based on that I can let you know whether the ability to show a GPX track is possible in the software or not.
If its not, then the second best option for you is to unlock your device, and use MMI software for normal driving, and when you go to areas without maps, you can use some other software for showing tracks.
headers 24th March 2011 08:59
:thumbs up The best topic on this forum - TSK :thumbs up
I was just about deciding on what to use on my Android..
Thanx
Vikram
tsk1979 24th March 2011 15:02
I suggest you check out the oruxmaps latest beta. They have added a "Backtrack" option in tracks, so with a single click you can backtrack your route.
Really beneficial in OTRs when you are doing hit and trial to reach a destination.
RGK 24th March 2011 21:29
Very good informative thread tsk. But bit technical to understand. Need to go through again and understand.
But heard when friends saying that you can mark your place in your GPS device.
sumathindra 25th March 2011 17:55
Very descriptive and informative info provided on GPS. Yes it is a must have for almost any one.
007 26th March 2011 12:20
My Nokia 5235 map is self learning type.
On a new unknown road if you travel with the GPS positioning On, next time the map will show this as a road.
I remember many such routes ( now showing as roads in map) during my vehicle performance trials.
Sutripta 26th March 2011 20:32
Hi Tsk,
This is/ will become the definitive thread on GPS use on TBhp. As such, I think a more elaborate explanation on vector vs raster maps, moving maps, positional awareness/ navigating/ routing would be in order. Also a bit on how GPS works, esp. on how weak the signals are, the need for the ephemeral table and its relationship with A-GPS, would also be useful.
Great thread.
Sutripta
justwheels 28th March 2011 01:11
It can never get better than this.Brilliantly explained "tsk", I am an absolute novice in this field but this article would be in my hit list of "refer-back" topics. Thanks for such an informative and relevant thread. Will be glued to this as more information flows.
tsk1979 28th March 2011 11:37
Thats not a good idea when offroading. Often on many terrains you would backtrack quite a bit. So imagine you going to that region again, and seeing a maze of tracks, without any idea which was the perfect track to take.
Originally Posted by Sutripta (Post 2293118)
Hi Tsk,
Great thread.
Sutripta
I was thinking of that, but then I refrained. It will make this article lose focus. About technical definitions, and A-GPS details etc., lot of information on google as well in the generic GPS thread in gadgets section. I want this article to be focused on Offroad GPS use.
Thanks justwheels!
classicselva 28th March 2011 13:29
:thumbs up Fantastic explanation on Offroad GPS. Tempting to to try!!
