Originally Posted by nitrous
(Post 666285)
The GV has differential locks and 4L. And with its ECU et all, it might understand what the driver is trying to do. In porsche 4x4s, there's something called descent control which helps in maintaining a low speed. |
Originally Posted by Alfa_Kilo
(Post 666311)
The hill descent system, also found in LRs works by using the ABS to brake the wheels and prevent the vehicle fron exceeding a certain speed limit. Electronic systems cannot make any significant changes to engine braking. Exhaust brakes (or exhaust retarders) do make quite a lot of difference though, and are found on most heavy vehicles. |
(Post 666285)
(Post 666311)
Originally Posted by susan3004
(Post 666651)
Exhaust brakes are very effective while decending downhill with loads full at the back, or when negotiating sleet or snow. Ashok Leyland Stallion 4x4 has this system and it gives a lot of confidence driving such a vehicle over others. |
(Post 667466)
I wish manufacturers would provide e-brakes on lighter vehicles too, especially 4x4s. OT: How capable are Stallions and 713s off road compared to MM550s and Gypsies? Does the Stallion have diff locks? |
(Post 678361)
Oh! Light vehicles don't actually require exaust brakes; they hardly take any load! Both Stallion and 713 are good off roaders. These have been going to places where MM and MG have been going. But yes, every vehicle has its limitations....713 is easy to manage than a Stallion. The later looses direction more often than others. It is a shade better when in 7.5 ton mode. There are places where MM is better than MG and vice verca. 713 has got one lever to shift into 4L mode. It does not have a 4H. So to take out the work of 4H, we drive it in the 3rd/4th. Both Stallion and 713 have diff locks. |
Originally Posted by vinod_nookala
(Post 682758)
Hey, I have closely observed both the vehicles, i like TATA 713 both in terms of styling and refinement. Looks handsome beast and on high speeds it is silent than a stallion. Stallion has a typical 4wd tranfer case whine...not to my taste. As far as off road ability is concerned both vehicles are fairly good, though i feel stallion needs more power especially for sand applications. Mere 160 horses not sufficient especially when u have to do speeds with load in 4wd high.May be AL YAK has got better power to weight ratios. Also surprising that TATA 713 does not come with 4wd high. How is that one maintains momentum in sand or how does one manage in slippery conditions in snow in north india? May be one manages with 4wd low in 5th gear for speeds may be.... |
