Building A Rubicon
https://www.team-bhp.com/forum/4x4-technical/81205-building-rubicon.html)
Hi Folks, I Bought A 97mod Mm550 2wd In Jan 09 And This Is My First And Only 4wheeler. Now I Am Planning To Customise It Into A Rubicon Look-alike. I Plan To Do It On A Step By Step Basis As I Cant Invest Much At A Time.
Initially I'm Planning Wider Axles And Wider 16'' Or 17'' Tyres. Kandisa Told Me Of Bolero 4x4 Axles And Maxx Pickup Axles.
Are The Width Of Both The Axles Same? What Might Be Necessary Changes Involved? What Might Be The Cost?
hi kandisa, went through the threads you had mentioned in your previous post. regarding 4wd conversion, change of the axles is necessary. so im planning wider axles at the same time. as such mods are unknown at my place, im depending on you people to get precise knowledge on what parts to source. even i have sent a pm to Arka n im awaiting his reply for sourcing the parts. regards, Govindraj.
Hi Bhpians, Finally My 550 Has Gone In For Body Work. Right Now Ill Not Be Doing The Axle Swap, Instead Im Goin In For Hub Change. As Per The Advise Of Kandisa, Im Changing To Marshal Hubs For Pcd Change. Coming To The Body Work, Im Planning A Bolero Windshield Frame And The Dome Behind The Bonnet And The Panels On Which The Door Hinges Fit. Im Also Planning To Reduce The Bonnet Height. Ill Get The Front Part Done First, Then Plan The Rear.
If you stick to stock gypsy or jeep rim, with a decently wide tyre, no change of hub would be required. My suggestion, just be bit clear about what exactly you are trying to do with your jeep. Change of hub is not that important if you don't plan alloys soon. If you are not going for the 4wd conversion now and only want to focus on doing the bodywork, 1st complete that. Tyres & wheels are easy to fit and won't take much of time if you 've funds, so is the hub change. So get your jeep sorted out mechanically and aesthetically and keep the tyre & wheel as the last step. You never know, you 'll change the decision on size of tyres and types of rims once the look of the jeep is complete. And i once again request you to go ahead with the 4 wheel drive conversion, you can enjoy the real character of a jeep only with that.
Hey man,
Read about your plans,
One option to Gypsy rims are the easily available FC (Forward Cab) rims available in the second-hand market, They are very sturdy as they were built for a load-carrying vehicle and fit into the 540 PCD so you don't need to change the hubs. I fitted those on my jeep and they are 5.5s so you'll be easily able to fit 235s and even 255s on those rims. Try looking out for them.
About changing axles, not sure you should widen them unless you've a strong reason for it. Changing the existing 2wd setup only requires a shift from a left off-set (left when you look at it from the rear) to a right off-set differential-axle setup which is largely a lathe job. Ofcourse you'll have to source the front differential and axle from a similar Mahindra vehicle (My 540 got its crown jewels from a Marshal which is a direct fit).
Also while you are at it, try sourcing the 9/44 crown pinions for the front and rear which give a good balance between off-roading and highway cruising compared to the 5.38s which are great offroad and the 3.xx which come in the scorpio. Getting a good KMT transfercase is also required. Good luck with your conversion and drop me a line if you need help!
Cheers,
Adi
Hi BHPians, I'm back with my 550. Had he'll lot of struggle with it to get it done. Finally it's running, but I'm not totally satisfied with the work. Still have a few issues to be settled. Please comment on the pics.
Pardon me, but I don't see any change in the Jeep except, maybe, a little straightened fenders, lowered bonnet lid and Bolero windscreen
Originally Posted by Ashley Nair Pardon me, but I don't see any change in the Jeep except, maybe, a little straightened fenders, lowered bonnet lid and Bolero windscreen |
Sir, did you miss the rear door, the wide tyres, the ps unit, bolero dash board, car type seating, etc. Of course I have not elaborated the changes in my post. The work done may look very meagre, but to get it done at my place, I had to struggle a lot.
Originally Posted by gr137
(Post 2832683)
Sir, did you miss the rear door, the wide tyres, the ps unit, bolero dash board, car type seating, etc. Of course I have not elaborated the changes in my post. The work done may look very meagre, but to get it done at my place, I had to struggle a lot. |
Gr137, The PS unit, Bolero Dash, Car type seating are not visible in your pictures. No offense meant.
Ya, that's right, they're not visible. Shall post some pics with better details. Also need some help on certain issues from you people. I've fitted the bolero dash and instrument cluster on my 550, but I couldn't get a suitable Speedo cable to match the 550 worm & bolero cluster. Please help.
Some more pics of my 550
PCD adapter of my MM550
Hi gr137, could you post the details of the front passenger seat mod for making it double flip. Which car seat is that?
Also the front facing rear seats look extremely well done. Could you disclose which seats are those.
Thanks a ton in advance sir.
All the seats are from a Sierra. The rear seat is original and it also has double flip. The front seats were in the sierra but doesn't belong to it originally. I believe it is a mid row seat from some MUV.
